dhenry Samba Member
Posted: Fri Jan 27, 2023 4:41 am Post subject: Electrical diagrams |
Hi, (newbie) we bought a 1981 Mexican VW Beetle. It’s electrical has been tampered with. High and low beams are on at the same time. I’m looking for an electrical diagram. I found a 1960 to 1967 diagram but it’s not quite the same. I’m hoping someone has one or info on how to get one. Why can’t I find anything on Mexican beetles? |
VW_Buggsy Samba Member
Posted: Fri Jan 27, 2023 6:48 am Post subject: Re: Electrical diagrams |
I'm not sure why there are no diagrams specific to the Mexican beetle, but I'm guessing that one of the latter diagrams available in the technical section of this site will get you very close.
https://www.thesamba.com/vw/archives/info/wiringt1.php
A general understanding of how the beetle headlight circuit works is probably all you need to figure that problem out and reverse it. The prior owner may have done it on purpose to get more light when the high beams are on. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Jan 27, 2023 8:34 am Post subject: Re: Electrical diagrams |
when I have to work on Ford truck wiring I look at all the drawings for years before and after the one I'm working on, between all of them I can usually figure it out.
Maybe if you were to look at years before and after (water cooled?) on what you have you might get a better idea of what's going on than looking at a specific year and model _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Starbucket Samba Member
Posted: Fri Jan 27, 2023 8:44 am Post subject: Re: Electrical diagrams |
Your hi/lo switch has failed, test it, if it's good you have a short between the headlight power wires. |
