Gutte Samba Member
Posted: Fri Jan 27, 2023 6:53 pm Post subject: Turbo diesel help |
Hey all
my current setup is a 1.9 diesel engine with a 5 speed adh gearbox, I would like to put in a 1.9 Turbo diesel with a mechanical pump(no drive by wire) do i need to do anything to the wiring??
Thx for the help
Cheers Gutte |
?Waldo? Samba Member
Posted: Fri Jan 27, 2023 6:55 pm Post subject: Re: Turbo diesel help |
Simplest would be to add a turbo to your current 1.9 diesel. |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Fri Jan 27, 2023 7:25 pm Post subject: Re: Turbo diesel help |
waldo-
would the aux. water pump system used on the 1.6 td be needed ? or does the 1.9 have that already? oil cooler etc? just curious. also what sized turbo woudl be used for a 1.9? _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Fri Jan 27, 2023 11:47 pm Post subject: Re: Turbo diesel help |
outcaststudios wrote: |
would the aux. water pump system used on the 1.6 td be needed ? or does the 1.9 have that already? oil cooler etc? just curious. also what sized turbo woudl be used for a 1.9? |
I am not waldo, but:
The aux pump is not as necessary especially if it not works. You can bypass te pump, or use the NA diesel return hose or mod the piping to have a 1.9 style coolant routing (there is a Samba topic somewhere). Adding an oil cooler is always wise.
The 1.9 IDI engines also had K14 turbos like the JX (a slightly different variant, 7000 series rather than the 6000) so you can use those with the JX manifold. Or the JX turbo. Then you can use the JX engine mounts and exhaust.
To OP:
If you use the JX coolant flanges and coolant senders then no need to modify the wiring. If you have the late JX with two pin senders and plastic flanges then just swap the senders. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
RolandD Samba Member
Joined: January 15, 2017 Posts: 247 Location: Menomonee Falls, Wis
Posted: Sat Jan 28, 2023 4:29 pm Post subject: Re: Turbo diesel help |
Does your block have oils sprayer for the pistons/ ETKA will show is it does.
Roland |
Posted: Sat Jan 28, 2023 7:47 pm Post subject: Re: Turbo diesel help |
All of the 1.9 diesels had piston cooling oil jets. |
Posted: Sun Jan 29, 2023 8:35 am Post subject: Re: Turbo diesel help |
Zoltan, as usual a wealth of information, thanks for the answer! _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
chrissev2 Samba Member
Posted: Mon Jan 30, 2023 11:59 am Post subject: Re: Turbo diesel help |
Gutte wrote: |
Hey all
Thx for the help
Cheers Gutte |
I converted my Vanagon (1986 WBX) to a 1.9 TD (AAZ) and found the wiring to be plug and play. The glow plug wiring was even already present, just not being used. I just had to add a glow plug light to the cluster and a glow plug relay to the engine bay. The vanagon wiring loom accommodated this and I did not have to run any additional wires anywhere.
It seemed that every Vanagon was built to accept either a diesel or a gas engine, as they already were wired for either.
You will find that your AAZ turbo pump has all sorts of weird plug ins on it, depending on the year. I researched this issue and also spoke to a person who rebuilt my pump and was told just ignore these. The only one you need is the stop solenoid.
So converting your 1.9 NA to a 1.9 TD would be easy. As stated above, you could also just add a turbo to it and change the injection pump for one that has the LDA on top. The blocks are the same other than I believe you have to figure out the turbo oil return line issue. _________________ 1986 westfalia auto 1.9TD
2023 VW Atlas 3.6 VR6 Highline
2019 Golf Wagon 4 motion
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
