kmbrown Samba Member
Posted: Thu Jan 26, 2023 8:10 pm Post subject: Knockout for side mirror? Never seen this before |
Just got my 72 Notchback. Want to install a passenger side mirror.
There seems to be a hole for mounting, just like the one on the driver's door.
It seems to be filled with a plug(?) but there's no obvious way to replace the plug with the mirror mount and there's no way to get at the other side to see what it's all about.
Has anyone seen this before? Can I just dig out the plug? ... and will I find a threaded hole here similar to the one on the driver's side?
Once I start messing with it, there's no return, so just wondering if anyone knows anything about it??????????????
beetlenut Samba Member
Posted: Thu Jan 26, 2023 8:32 pm Post subject: Re: Knockout for side mirror? Never seen this before |
You get to the inside of that area by removing the inner door panel. There should be a "U" shaped piece of metal welded to the inside of the metal on the backside of that hole. They make a special mirror anchor nut that slides into that "U" shaped piece of metal, which keeps the nut from spinning when you screw the threaded end of the mirror arm into it from the outside through that hole.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sat Jan 28, 2023 5:06 am Post subject: Re: Knockout for side mirror? Never seen this before |
Great info BeetleNut.
Thank you!! |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Jan 28, 2023 4:32 pm Post subject: Re: Knockout for side mirror? Never seen this before |
It is quite possible that a threaded nut already exists inside the door. I’d look first.
I say this because I have seen LH doors in RHD cars which already have these nuts. This is opposite to LHD cars obviously. I can’t see that they would have the hassle of trying to worry about which door was for which market (even understanding the RHD market was small) when they had to have separate part numbers for RHD and LHD doors. They probably just made all the doors the same(?).
It has happened on some not all RHD doors I’ve worked on. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sun Jan 29, 2023 4:58 am Post subject: Re: Knockout for side mirror? Never seen this before |
Thanks Viking.
I'll let you know what I find. |
Posted: Sat Feb 04, 2023 11:26 am Post subject: Re: Knockout for side mirror? Never seen this before |
Bingo.
Popped the plug out and found a nice set of threads in there.
Problem solved. No muss. No fuss.
Thanks for the notes! |
