BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed May 20, 2015 10:18 am Post subject: |
desert westy wrote: |
The JB Weld Is shaped like a square above the rod for the number 1 cylinder |
If nothing else got damaged then it is mostly cosmetic. If you can make it not splash-leak then it should go forever like that. |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Wed May 20, 2015 1:39 pm Post subject: |
Third owner and with second owner's kids knocking on your door bringing you original parts....... Doesn't get much better!
Makes me sad that I had to sell my original, rust free '59 15 window which was also SWR/BG.
But I'm very happy for you
Absolutely brilliant! _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Tue May 26, 2015 2:32 am Post subject: |
Yes this is a heart warming story, I'm glad there are still busses hiding and are showing up. I, along with others are glad you are doing the right thing in the repairs and not changing a lot of stuff. If the 2nd owner shows up with a OG seat and you want to sell that one, I need one for my 63 , 15 window _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Fri Dec 30, 2016 5:42 pm Post subject: Re: My first split window bus. 1963 15 window |
Just read this cover to cover. Awesome bus and story! Every now and again somebody is in the right place at the right time and the bus ends up in the right hands. I'm so glad you chose to preserve it rather than restore...
Was the middle seat the bus was born with ever found? _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sat Dec 31, 2016 1:57 pm Post subject: Re: My first split window bus. 1963 15 window |
One of the nicest original paint desert finds ever! I love this bus. Thanks for sharing.
RHD Notch wrote: |
Was the middle seat the bus was born with ever found? |
_________________ Brandon |
desert westy Samba Member
Joined: October 01, 2011 Posts: 103 Location: Twentynine Palms, Ca
Posted: Wed Jan 25, 2017 8:31 pm Post subject: Re: My first split window bus. 1963 15 window |
Thanks for the compliments. Bus has not been reunited with its original middle seat yet, but I did make an interesting "find" today. I was cleaning out the garage and found a set of what I am thinking are the original splash pans. When I first found this bus, I did not know a thing about split windows. The bus was used as a storage shed so I grabbed what I thought was VW and left everything else behind. Now that I've learned a few things, I am certain that I missed a few things. Next time, I am taking everything.
Also, I have been collecting parts for a new motor. Plan is to build a 1600 single port that will look the a 1500 that came in a 63 bus. Here are some of the parts:
All of these parts have been sourced/rebuilt by Samba members. I'll be using a new case, new heads, counterweighted crank and would like to use a doghouse cooliing shroud. Generator is 12 volt, but fits in a 6 volt stand. I will be driving to shows soon... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jan 25, 2017 8:55 pm Post subject: Re: My first split window bus. 1963 15 window |
If you are going with 1600 P&Cs, might consider going with a 74 mm CW crankshaft instead. Will need little to no clearancing, and a little shimming between case and cylinders to keep the compression down. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69826 Location: Phoenix Metro
Posted: Sun May 12, 2019 5:53 pm Post subject: Re: My first split window bus. 1963 15 window |
New motor is almost done. 1600 single port with a dog house oil cooler and 12 volt generator. Built to look like a stock 1963 1500. All parts purchased from or rebuilt by TheSamba members |
Posted: Sun May 12, 2019 6:01 pm Post subject: Re: My first split window bus. 1963 15 window |
Looks nice!
The vacuum line needs some TLC to keep fuel getting into the distributor vacuum can, ruining the rubber diaphragm. _________________ In Stereo, Where Available! |
Posted: Sun May 12, 2019 6:05 pm Post subject: Re: My first split window bus. 1963 15 window |
Metal fuel pump to carb line is also a nice item to have.
From the early 1963 model bus Owner Manual:
Posted: Mon Oct 28, 2019 4:53 pm Post subject: Re: My first split window bus. 1963 15 window |
I have had this tent for a few years. It's a Sundial Pent-Tent. Realized I put it on backwards after it was on the roof. Not sure if I am brave enough to climb up the ladder. |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Mon Oct 28, 2019 6:18 pm Post subject: Re: My first split window bus. 1963 15 window |
I definitely wouldn't climb the ladder with it on the long panel like that. Sweet tent thought. _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
Posted: Mon Jul 12, 2021 8:22 pm Post subject: Re: My first split window bus. 1963 15 window |
Broke down for the first time. The outlet tube on the fuel pump popped off resulting in a gas soaked distributor. This is a nicely rebuilt fuel pump purchased from a reputable samba member. The tube seems to be the same on both sides and I am wondering if simply presses back into the fuel pump. I doubt that I'll reuse this pump, probably order another and keep this as a spare. Time to order a Blazecut extinguisher.
Fuel pump is the one pictured a few posts above. |
Posted: Mon Jul 12, 2021 9:43 pm Post subject: Re: My first split window bus. 1963 15 window |
Just put the tube back in and use a center punch around the hole to crimp it back in. Can also do a poor mans knurl on the tube end to go back into the hole. _________________ In Stereo, Where Available! |
Posted: Sat Jan 28, 2023 11:11 am Post subject: Re: My first split window bus. 1963 15 window |
Finally installed a headliner. Just need a few more windows and feel like I’m done. |
oakman Samba Member
Posted: Sat Jan 28, 2023 11:26 am Post subject: Re: My first split window bus. 1963 15 window |
Headliner looks great!!! I'm sure it's really quiet now when you're driving. _________________ Brandon |
Posted: Sun Jan 29, 2023 10:12 am Post subject: Re: My first split window bus. 1963 15 window |
Octavio recommended and installed Dynamat under the headliner. Made a huge difference. |
