DesertG Samba Member
Posted: Sun Jan 29, 2023 10:04 am Post subject: Battery Tray Vent Drain |
I found a battery tray with a drain. Given all the carnage from battery acid in these cars, has anyone drilled a hole in the pan, installed a grommet and ran a drain hose out side the car. This part is for a 1961-1971 Jaguar.
Thank you
_________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Sun Jan 29, 2023 10:16 am Post subject: Re: Battery Tray Vent Drain |
Drilling a hole in the pan for a drain, is not a recommended practice.
Buy one of these battery mats and place it in the Jag battery tray you show above.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=ZVW113 _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Jan 29, 2023 12:26 pm Post subject: Re: Battery Tray Vent Drain |
The problem with the mat is, I still have to keep looking to see if it leaked. A drain would solve this. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Sun Jan 29, 2023 12:37 pm Post subject: Re: Battery Tray Vent Drain |
Where would you drain it to? (Battery acid will eat its way into concrete garage floor, at least that's what it has done me.) |
viiking Samba Member
Joined: May 10, 2013 Posts: 2667 Location: Sydney Australia
Posted: Sun Jan 29, 2023 1:29 pm Post subject: Re: Battery Tray Vent Drain |
Just stop the acid from leaking in the first place! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
splitjunkie Samba Member
Posted: Sun Jan 29, 2023 2:12 pm Post subject: Re: Battery Tray Vent Drain |
Being on the lowest part of the car, water would easily get in whenever driving in the rain. The battery would be much higher in the car in the tray's original application so this would not be a problem.
Find a tray with no drain and use the aforementioned acid mats. Under normal circumstances with no charging system issues, acid shouldn't be leaking. A periodic check of the battery should be part of a standard maintenance routine on an air cooled VW. _________________ Chris
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 29, 2023 9:03 pm Post subject: Re: Battery Tray Vent Drain |
Batteries unless completely sealed always sweat some acid. Battery mats only work for while and all too soon just end up soaked in so much acid that the mat just becomes a super acidic mat. If one has an earlier beetle with the strap over hold down, personally have gotten a close enough plastic battery box. Throw the lid away cut down the sides and if need be cut it down lengthwise and do some plastic welding. _________________ In Stereo, Where Available! |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Mon Jan 30, 2023 4:08 am Post subject: Re: Battery Tray Vent Drain |
No worries about leakage if you use an AGM battery. _________________ '65 Sunroof Bug |
