veraarem Samba Member
Joined: January 03, 2016 Posts: 3 Location: Netherlands
Posted: Mon Jan 30, 2023 10:23 am Post subject: Original Color on Brake Drums 1955 Oval?? |
I am restoring a pretty original 10/55 Oval. Body is still first paint and interior is still original (both with necessary wear obviously). I will leave body and interior as is and am redoing all what is underneath the car and would like to coat all parts in original color where possible. Does anyone know what color the brake drums were originally from the factory? |
aa390392 Samba Member
Posted: Mon Jan 30, 2023 12:46 pm Post subject: Re: Original Color on Brake Drums 1955 Oval?? |
Black? _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
finster Samba Member
Joined: May 26, 2012 Posts: 7801 Location: north o' the border
Posted: Mon Jan 30, 2023 1:19 pm Post subject: Re: Original Color on Brake Drums 1955 Oval?? |
from photos in 'als der kaefer laufen lernte' they look to be semi gloss black. would it be paint or chemical blacking as it would need to be heatproof. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
splitjunkie Samba Member
Posted: Mon Jan 30, 2023 4:50 pm Post subject: Re: Original Color on Brake Drums 1955 Oval?? |
Based on the pictures in the 'als der kaefer laufen lernte' book, and other pictures I have seen, the front axle assemblies were built of from all unpainted parts except the shocks. Once they were assembled, the entire assembly was spray painted black. This included all of the rubber pieces. Yes, the rubber parts all got painted. It was a shiny black paint but since none of the surfaces were sanded, primed, sanded again and then painted like the bodywork would have been, so the finish is uneven but does have some shine. My guess is it is gloss lacquer. It will have some shine but to get a glass smooth shiny finish, it has to be color sanded and polished so when you don't do that and apply it to suspension components you get a dull gloss.
The rear axle tubes appear to have been built from unpainted parts and then painted. I believe the drums were painted separately. The parking brake cables appear to have been installed before painting so the ends of the cable housings where they are attached to the backing plates got painted. The axle boots appear to have been stretched over the inner flange after the axle tube and retainer plate were painted. There is no paint on the boots or clamps.
From what I could tell, the insides of the brakes were left unpainted. This means the inside of the drums were unpainted along with the inside of the backing plates and all of the brake parts inside. _________________ Chris
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1036 Location: Germany
Posted: Tue Jan 31, 2023 6:42 am Post subject: Re: Original Color on Brake Drums 1955 Oval?? |
splitjunkie wrote: |
From what I could tell, the insides of the brakes were left unpainted. This means the inside of the drums were unpainted along with the inside of the backing plates and all of the brake parts inside. |
Yes, to correct it a little, also the drums have been painted after the whole assembly, front and also rear. The reason for painting the already assembled parts: It's easier, as all flanges keep free from paint as they should. The paint will have been the same black, as for all the engine tins and chassis and more parts. That paint was thin withpout primer and filler. |
Posted: Sun Mar 05, 2023 6:04 am Post subject: Re: Original Color on Brake Drums 1955 Oval?? |
Thank you all for the information and tip for the book with factory pictures (I ordered it - it is great). I will go with black paint but will get all the parts coated separately and then assemble it. |
