RCJH77 Samba Member
Joined: March 27, 2022 Posts: 191 Location: Johnson County, KS
Posted: Tue Jan 31, 2023 6:23 pm Post subject: Stop gas flow [RESOLVED] |
I pulled the motor from my bug and while I'm working on replacing the clutch, the gas line is dripping a constant flow of gas, despite the fact that I've turned the gas lever to the OFF position, clamped the line in two separate locations, and raised the line as high as it can go under the car.
Any suggestions on how to stop the gas flow? At this point, it'll empty the tank in the garage by morning.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Tue Jan 31, 2023 6:33 pm Post subject: Re: Stop gas flow |
Stick a M6 bolt in the end of the hose and put a clamp on it. _________________ Glenn
Member #1009
#BlueSquare |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Tue Jan 31, 2023 6:35 pm Post subject: Re: Stop gas flow |
When you say "gas lever", does your car have the early style in cabin fuel reserve lever sticking through the firewall, or is yours something different?
If you have the early style, straight up (I believe) is full on, 90 degrees downward to the right is reserve, and half way between these 2 positions (45 degrees from vertical (full on)) is the off position. Make sure yours is in the 45 degree position or you'll never shut it off.
If the early style isn't what you've got then all this is irrelevant.
Good luck
Ted
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Tue Jan 31, 2023 6:39 pm Post subject: Re: Stop gas flow |
Shove a golf tee into the line, or shave a pencil down and stuff it in.
If it's a non vented tank, seal over the fill neck with a plastic wrap and prevent air from getting in.
I drilled two holes thru a few inches of 1 1/2" dowel, then sawed it in half lengthwise. Couple of bolts and nuts later, put the two round sides against soft fuel line and bolt thru the flats. Tighten till it stops dripping. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
my59 Samba Member
Posted: Tue Jan 31, 2023 6:41 pm Post subject: Re: Stop gas flow |
If the rubber disk in the fuel tap is degraded, the tap will likely leak and not shut off.
You could simply drain the tank into a couple of gas cans... _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
House Minutia Militia
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
RCJH77 Samba Member
Posted: Tue Jan 31, 2023 7:22 pm Post subject: Re: Stop gas flow |
fl59bug wrote: |
Good luck
Ted |
Well, I'm embarrassed to say that I did NOT, in fact, have it in the correct position. I had it in the Reserve position. Damnit. Thank you, sir! |
