Ghia coming home
Page: Previous  1, 2, 3 ... 18, 19, 20, 21, 22, 23  Next
halbug
halbug is offline
PostPosted: Wed Jan 18, 2023 11:13 pm    Post subject: Re: Ghia coming home Reply with quote
Small stuff in between:
Convertion to E-switch.
Thank you for the inspiration Volker, if you read this Wink
Cheers
Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0
TRS63
TRS63 is offline
PostPosted: Thu Jan 19, 2023 1:45 am    Post subject: Re: Ghia coming home Reply with quote
"Invisible" modification improving the experience..well done !
Antoine
Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
halbug
halbug is offline
PostPosted: Thu Jan 19, 2023 10:32 am    Post subject: Re: Ghia coming home Reply with quote
Hi Antoine, Thanks - I have converted switches to e-pump before, but this nice and very clean looking way I copied from someone else Wink
halbug
halbug is offline
PostPosted: Sat Jan 28, 2023 6:44 am    Post subject: Re: Ghia coming home Reply with quote
The rear end is done! Cool All components have found a place, everything clears and fits:
More details on the transmission oiling in the below linked thread.
Now I can take the rear end appart again and concentrate on body fitment and the front.
Thanks for watching
Cheers halbug
TRS63
TRS63 is offline
PostPosted: Sat Jan 28, 2023 1:33 pm    Post subject: Re: Ghia coming home Reply with quote
One good step achieved on that project Cool
Antoine
Antoine
Ian Godfrey
Ian Godfrey is offline
That is great work there. A lot of hose connections Shocked . Do you have a pressure tester for hoses? Is there a little tank for the gearbox oiling system, or does it just recirculate?
As well as being functional it looks great! WELL DONE
halbug
halbug is offline
PostPosted: Sun Jan 29, 2023 1:15 am    Post subject: Re: Ghia coming home Reply with quote
Thanks guys!
@Ian - pressure testing will happen on the go Wink BTW there will be below 1bar in the system. No tank, just filtering, cooling if needed and distribution to the gears.
Inchpincher61
Inchpincher61 is offline
PostPosted: Sun Jan 29, 2023 6:42 am    Post subject: Re: Ghia coming home Reply with quote
halbug wrote:
Wheels are back from acid dipping and cathodic dip painting (KTL) Cool . Even thought this is only the base coat, I could not resist to check how the wheels would look like in black paint and chrome trim.
What do you think? Gloss Black the way to go?
Of course! That's going to be sweet Cool
By the way: This one of the craziest Ghia builds here. I am really I'm really impressed and excited about the final result!
Can you explain why its necessary to have this oiling system? That would be very interesting to me.
Cheers
halbug
halbug is offline
PostPosted: Sun Jan 29, 2023 9:40 am    Post subject: Re: Ghia coming home Reply with quote
Thank you InchPincher, to answer your question in short: To clean and cool the transmission oil and positively lubricate the fifth gear in its own housing...
All the details and the discussion on this modification can be found in an extra thread, linked below in my signature under My Berg5:
Steve Arndt
Steve Arndt is offline
PostPosted: Tue Jan 31, 2023 2:52 pm    Post subject: Re: Ghia coming home Reply with quote
Holy SH!T on the trans oiling setup! Smile
Steve
Steve's 87 Syncro project
halbug
halbug is offline
PostPosted: Wed Feb 01, 2023 10:43 pm    Post subject: Re: Ghia coming home Reply with quote
I'll take that as a compliment Laughing
halbug
halbug is offline
PostPosted: Sat Feb 11, 2023 11:38 am    Post subject: Re: Ghia coming home Reply with quote
Very Happy Very Happy Very Happy
Picked up the painted wheels today. 185s front and 205s rear
Impressions
Ian Godfrey
PostPosted: Sun Feb 12, 2023 3:49 pm    Post subject: Re: Ghia coming home Reply with quote
Shocked Very Happy Very Happy Very Happy
sputnick60
sputnick60 is offline
PostPosted: Sun Feb 12, 2023 9:47 pm    Post subject: Re: Ghia coming home Reply with quote
They do look nice
Remember to remove the paint where the nuts contact the rims to ensure the nuts don't loosen wearing through the paint
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
halbug
halbug is offline
PostPosted: Wed Feb 15, 2023 11:55 am    Post subject: Re: Ghia coming home Reply with quote
sputnick60 wrote:
They do look nice
Nicholas
Thanks, will do!
halbug
halbug is offline
PostPosted: Wed Feb 15, 2023 12:11 pm    Post subject: Re: Ghia coming home Reply with quote
Question: can someone here share pictures and/or explain how exactly VW build the isolated contact ring onto the steering shaft?
I'm working on my steering column and need to add a feature to get current isolated onto a cable leading to the horn button. The steering column assembly will ground the power. Similar to the pre 58? VW's. The contact brush is clear to me but I like to know how VW assembled the isolated ring onto the shaft to maybe copy it.
Cheers
halbug
halbug is offline
PostPosted: Fri Mar 03, 2023 11:46 am    Post subject: Re: Ghia coming home Reply with quote
Here is my Frankenstein steering column (SC) Laughing
SC tube, and turn signal switch from my 65 Ghia
SC shaft from an early super beetle, so that the old steering wheels fit. Cut in half to adjust the length.
Shoulder machined to fit two ball bearings onto the shaft.
Standard industrial ball bearings installed on VW spacer. I used two bearing because they are pretty small to fit into the old SC tube.
Adapter fits into SC tube and holds the bearing in place.
Completed with a custom plastic spacer just like VW did on super beetles. This set up gives me exact 2mm (VW spec) clearance between turn signal and steering wheel.
Lower end: Standard industrial needle bearing with adapter into SC tube, original race and a proper seal to keep water and debris out.
To run the current from the horn relay to the horn button I choose the principle and a carbon brush from pre 58 VWs.
The steel nut will be soldered to the SC tube. Threaded tube is made from plastic to isolate and brass cap leads the current from the inside to the connector. Cap will be painted black on the outside to isolate and so it looks better.
Again pre 58 principle with insulator plastic ring and brass race, including connector. Wire will be run through the shaft to the horn button. The column will be grounded so the current will find the battery Very Happy
That's it Twisted Evil Once I know the correct length SC tube needs to be shortened and and shaft welded together again.
Ian Godfrey
PostPosted: Fri Mar 03, 2023 2:53 pm    Post subject: Re: Ghia coming home Reply with quote
Some very creative and skilful work there. I'm looking forward to the finished result Smile
halbug
halbug is offline
PostPosted: Wed Mar 15, 2023 10:35 am    Post subject: Re: Ghia coming home Reply with quote
Always wanted to do this Cool
Today I took some time to see if it works:
It did! I used an adtermarked knob made from thermoplast.
halbug
halbug is offline
PostPosted: Sat Apr 01, 2023 8:05 am    Post subject: Re: Ghia coming home Reply with quote
After getting my trasmission project done: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=80
I put the battery in place and disassembled the rear end today:
Steering and completing front end is next Razz
Page 19 of 23
