veedubcrazy Samba Member
Joined: February 14, 2005 Posts: 2178 Location: La Porte, Tx.
Posted: Mon Oct 31, 2005 7:50 am Post subject: Converting a type 3 engine to a type 1 |
Has anyone ever done this before? I aquired a good, used type 3 block and want to convert to a type 1 engine for a future project. the block-off plate for the dipstick is easy. BUT, drilling and tapping for a oil pressure sensor and drilling and fitting a dipstick tube will be a bit difficult. Is there a way to do this or just leave it as a type 3? thanx, dave. _________________ 1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer" |
DSF Samba Member
Posted: Mon Oct 31, 2005 9:16 am Post subject: |
Type 3 blocks are an easy sell-- heck, I need one!
Trade it for what you need (or better!). |
Brian T. Samba Member
Joined: April 04, 2003 Posts: 194 Location: Hemet Ca.
Posted: Mon Oct 31, 2005 10:11 am Post subject: |
Some vw shops have jigs to accomplish this. I had a similair case awhile back. The oil sender is a easy tap. The dip stick is a dip more of a tricky.
Brian |
Rome Samba Member
Joined: June 02, 2004 Posts: 10706 Location: Pearl River, NY
Posted: Mon Oct 31, 2005 11:33 am Post subject: |
| I've had such a conversion done a few years ago, by Rimco in Calif. Nice job. Another detail is, if the T3 block you have is out of a fuel-injected model, and you plan on using a stock Beetle fuel pump, then you will need to install slightly longer studs for the fuel pump. The stock T3 ones are about 1/2" too short. If you will use an electric fuel pump that is mounted up front near the tank, then you can use those stock studs on the engine and just make up a cover out of sturdy sheetmetal. |
Posted: Mon Oct 31, 2005 12:01 pm Post subject: |
so these jobs are possible. thats great. this case is a orig 72 block from a fasty, is an as41, but could not find the serial #'s on it. looks to be unmolested as well (line bore and thrust cuts). i do know it was rebuilt at one time on account of a mexican rear main seal behind the auto flexplate. dont think wolfsburg imported them from mexico. _________________ 1967 Deluxe Sedan
