rubbachicken Samba Member
Posted: Mon Dec 26, 2005 2:27 pm Post subject: power steering on a split bus |
ave any of you guys out there fitted power steering to a split bus
i am trying
i don't know the GM equivalent, i'm using a power rack from a vauxhall vectra and an electric power steering pump from and a vauxhall astra van
the rack
first trail fit, with booster inplace
with the booster removed, as it'll need a bit more tweeking
and finaly the power fluid pump
i'd be grateful for any help, advice, idea's
thanks for reading |
Rex Surewood Samba Member
Joined: February 21, 2004 Posts: 274 Location: Denmark - yes, around the planet..
Posted: Mon Dec 26, 2005 2:52 pm Post subject: |
Why..? People has been driving buses without powersteering since 1950 and nobody got hurt..
Anyhow.. The biggest problem, as I see it, is getting the steering wheel connected..? Have you thought of any solutions to that? |
busracer Samba Member
Posted: Mon Dec 26, 2005 2:58 pm Post subject: |
why?...why?...so you can run a 10 inch diameter chain link steering wheel. thats why. |
Posted: Mon Dec 26, 2005 3:14 pm Post subject: |
the reason for doing this, well i have a few
first off i want to drop the bus a few more inches, the first thing that hit the ground on a lowered split bus is........... the steering box
next off there's the feeling at speed that the van moves across the road in the wind, even when there is no wind
my final want, just to make the thing easier in traffic, parking etc etc
and just incase i find a normal decent woman, it'd be good if it were easier to drive
as for a way of getting it to the steering colum, i think i have a solution for that
i'm going for something similar to this, using the steering box from a vanagon
rather than going across from one side to the other i hope to be able to squeeze in all on the one side, notching the chassis i hope to be ble to get the steering box up and safly level with the chassis out of harms way
maybe i can tub it and slam it, if it works |
Posted: Mon Dec 26, 2005 3:21 pm Post subject: |
busracer wrote: |
nah mate, the stock wheel is too pretty to want to give up on, unless i could find one of the banjo wheels
i don't see any reason to not bring the steering up into the 21st century
many people bring the engines and transmisions and braking systems up to date
why not do it to the steering |
Stocknazi Samba Member
Posted: Mon Dec 26, 2005 6:29 pm Post subject: |
why are you wanting to put power steering on your bus again?
i think its unneccessary and will devalue your bus.
the reason for the wandering at speed is probably worn suspension componants. why not service the front end and try to eliminate your steering problems? replace or repack wheel beARINGS, check for play in your drag link and king and link pins, grease everthing, and change the oil in your steering box. check drag link and other conponants for play BEFORE you try to adjust your steering box. it may need adjustment, but most of the time other steering conponants are worn and the box is not to blame.
again , i and 95 % of people in this forum will advise you NOT to add power steering and try to improve? your bus. if its not broke, dont fix it.
maybee you need a nice vanagon, its more modern and more complex to repair  _________________ WANTED:
Thomas Jefferson |
classictint Samba Member
Joined: August 20, 2004 Posts: 285 Location: Garden Grove,Ca
Posted: Mon Dec 26, 2005 7:13 pm Post subject: |
Fellow Bus owners..
I think he was explaining how hes going to install it, not asking permission.. |
AndrewM Samba Member
Joined: February 18, 2002 Posts: 496 Location: Charlotte, NC
Posted: Mon Dec 26, 2005 10:13 pm Post subject: |
It looks like you're already doing a "hell of a job" without anyones input. Why not just update the whole bus. Switch out some of the body panels with vanagon stuff, that would be cool too. And you should loose the steering wheel, maybe a GT wheel would look RAD. You should definately put some AUDI seats in it, oh oh and a DVD player. If I were you I would have an artist paint "Big Pimpin" on it. Oh snap, that would be awesome. By the way, what part of the UK are you from?  |
Braukuche Samba Member
Posted: Mon Dec 26, 2005 10:48 pm Post subject: |
rubbachicken wrote: |
I think a ridiculous power steering conversion is the least of this Bus's problem. Again, why buy a vintage vehicle if you want the comforts of a modern vehicle??
--Dan |
Posted: Mon Dec 26, 2005 10:55 pm Post subject: |
Braukuche wrote: |
--Dan |
He might want to drive around with his family... and he wanted to upgrade the steering..was he asking you to contribute to the project?? shut your pie hole then.. rubbachicken .. looks good... post more pics later |
scoot1958 Samba Member
Joined: December 21, 2005 Posts: 4 Location: Rogue Valley, Oregon
Posted: Mon Dec 26, 2005 11:37 pm Post subject: |
Some of the coolest trends in old automotive and motorcycle conversions have come out of Europe; I say you are one daring *.$.#. - GO FOR IT, and I want to see more pics throughout ...
Naysayers beware; classictint and I will be crawling under your busses at the shows to see who gives in and installs one of rubbachickens' "kits" when he gets the kinks worked out and goes into production!
STOCK: 60' SC, 60' VERT,
Slightly modified 81' Caddy |
Posted: Tue Dec 27, 2005 3:52 am Post subject: |
whoa, it seems i must have found a forum for unmodified busses
and people with no desire to improve the handling of their pride and joy
i don't see it as devaluing my bus, it's a keeper, one day i'll be burried in it
abeed: putting pwer steering on it again ??
it's not about worn out steering componants, i have driven bay for years, when i get them every part of the steering is replace, i have found that each and every one of them wanders across the road so i figure this one will get an up date
Braukuche: pray tell, wht are the rest of the problems with my bus, appart from it's nutbag owner
again i ask, how many of you out there have modified the engine, trans nd the braking systems, so what's the big deal with wanting it to have better, more responsive, and POWER steering
i have an idea, if you don't like what i am doing, please do not waste you time and mine telling me i am wasting my time and riuning my split bus
to those with positive thought's about what i am trying to achieve, thanks for your thought's |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Tue Dec 27, 2005 7:17 am Post subject: |
and people with no desire to improve the handling of their pride and joy |
Not true. There are many of us here who like tricking out our buses. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5937 Location: Middle of a corn field
Posted: Tue Dec 27, 2005 7:31 am Post subject: |
do what you like- it's yours.
i wonder if there was the same talk when people began running disc brake conversions, bigger engines, etc- who gives a damn. if that's what you want, more power to you. just keep that in mind when you try to sell it. _________________ Even YOU can prevent FIRES!
Click to view image |
Posted: Tue Dec 27, 2005 7:39 am Post subject: |
mynameismud wrote: |
i wonder if there was the same talk when people began running disc brake conversions, bigger engines, etc- who gives a damn. if that's what you want, more power to you. just keep that in mind when you try to sell it. |
Narrowed beams, drop spindles, etc... Everyone has an opinion on how your bus should be. My personal opinion is that if you can bolt on the goodies than go for it. It can be easily reversed even if sold that way. I do keep all the OG parts just in case. I also making things work better. The challenge of makeing parts come together to function better than stock. Theres nothing like driving freeway speeds in an old bus and knowing it can handle it. Do it as you like and are capible of. _________________ Why buy what you can build.
lammyrider Samba Member
Posted: Tue Dec 27, 2005 7:51 am Post subject: |
welcome to the samba rubbachicken and you thought that VZi could be aurgumentative
think you'll find the resto boys will think your an idiot and the custom boys think your a mad genious they dont hold back their opinions on here,see the rant section  |
Posted: Tue Dec 27, 2005 9:27 am Post subject: |
lammyrider wrote: |
i think i got the idiot covered
not sure about the mad genious, i think nutbag sums it up  _________________ lucy our westy
lucy's BIG adventure
meet 'burni' |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12538 Location: Over 2002 posts deleted!
Posted: Tue Dec 27, 2005 9:33 am Post subject: |
I do like your idea also. Though my '65 Dormy with a fatchick disc brake front beam does pretty well even with the 13 inch Grant steering wheel, power steering would definitely make things a lot easyer for tight parking and such. However, it pretty much only helps there since at speed, too sensitive a "steering" could be more detrimental than helpful.
I remember way back when small japanese cars like the Honda started coming out with power steering. Even with the engine in front these vehicles were too light to have full on power steering. So they had a set up that the power steering cut off as yuo get to speed. Do some more research. Maybe your electric pump already has such a "cut off" switch or you can make one.
In the mean time and for whatever it is worth, I too have been told many a time "You just can't do that!" "It can't be done!" By some "experts" even! Then when I've come back to show them and they start asking me "How'd you do it?" I tell them to just try and find out for themselves!
Good luck on this project!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Tue Dec 27, 2005 11:16 am Post subject: |
I think its a great idea!
I was/am in the process of fitting a rack n pinion set to my bus.....by why not go all the way? The modern power racks are very compact and strong. I was using a manual rack but have spotted some power racks that would be great.
Are you bolting it straight to the frame rails using some fabbed mounts?
One word of caution; Don't mount the rack too far back/forward of the steering pivot points. If the tie rods are angled too far, there will be considerable bump steer when going over ruts, etc. |
Posted: Tue Dec 27, 2005 11:28 am Post subject: |
the rack will be mounted on home made brackets, i like to over engineer so they will be heavy guage steel
and yes i already figued that i need to mount it as close to the beam as i can, but i do have to work it around the booster, but i am confident i can sort it
to the doubters that have replied, so far 99% of the bit i have done to my bus can be reversed if the need ever arised
but as far as i'm concerned this is a keeper so it doesn't matter[/b] _________________ lucy our westy
meet 'burni' |
