J Charlton  Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Tue Jan 29, 2008 1:09 pm Post subject: what to take - what would you take |
We're planning about a 3500km 2 week trip to the Gaspe region in early July. Our newly aquired '85 westy seems to be in good shape - I haven't driven it more than a couple of hundred Km since getting it. I'll be doing some more on it before leaving - replacing the fridge, adding a second battery, adding a fifth seat etc etc.
What I'd like to know is from the perspective of experienced westy campers, what are the essential tools and other bits and pieces (not camping related) that you would take with you. I don't want to take all of my tools, but I want to take a reasonable estimation of "enough" Any replacement bits and pieces that should be taken along  |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Jan 29, 2008 1:19 pm Post subject: |
Before you replace anything like the fridge, you should go over the engine and the drivetrain, and replace any worn or suspect parts.
I've seen it happen a few times on the board, one member comes to mind.
They talked about their dream of traveling the country, redid the inside of the van, had it painted, and did very little to the engine, and sure as shit they broke down a couple hundred miles from home.
If you fix it up right you won't really have to worry about what you need to take as much as what you want to take. |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Tue Jan 29, 2008 1:31 pm Post subject: |
If you are planning to camp at Parc Forillon in Gaspe, you NEED a reservation!!!
http://www.pc.gc.ca/pn-np/qc/forillon/index_E.asp
The camping is great there and the park is magnificent but reservations are a must.
Make sure you take your Bentley. That way, even if you can't fix whatever goes wrong, most decent mechanics, even if they don't know Vanagons, can do a pretty good job in a pinch. _________________ -- 1987 Westfalia automatic (Captain Vino)
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Tue Jan 29, 2008 2:00 pm Post subject: |
try to time your travel with the Quebec Westfalia camping club grand campout
http://westfalia.qc.ca/activites.aspx
easy to hook up with like minded folk, get maintenance and tech assistance as well as possible travel buddy for part of the trip in caravan.
replace or repack CV joints, axles and bearings. as well as rubber boots and seals. replace or repack front tie rods.
check and be happy with ALL 5 tires.
inspect EVERY IN OF COOLING HOSES underneath. inspect and replace clamps that would be difficult to handle on the side of the road.
CLEAN ALL electrical GROUNDS esp the trans ground and cluster under the dash, and on the engine.
clean all battery to starter connections, if you don't want to service items in your driveway. how are you going to feel about them when on a trip? _________________
| Abscate wrote: |
| These are the reasons we have words like βwankerβ |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Jan 29, 2008 3:19 pm Post subject: |
Anytime you plan to take a vehicle on a trip, and the vehicle is questionable in the area of it's mechanics, do this:
Make it your "driver" for about a week or two. Drive it to work every day, to the store, to where ever you need to go. Do this for at least a week. If there are any 'questionable" issues pertaining to the driveability of the vehicle, they will pop up during this time, which will be more convienient to repair then when you are on a vacation. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Posted: Tue Jan 29, 2008 3:27 pm Post subject: |
| mightyart wrote: |
Wish this was a little more true, but alas something new always seems to come down the pike. My last trip from which I just got back was pretty uneventful, but not perfect. Of all things I had an alternator housing break into. Cost me $100 and about two hours of my time to be on my way again. Without having the proper tools it may have taken more than a day and cost many times more.
Here is a list of what I unloaded from my tool box and under seat storage at the end of a 7500 mile trip in my 84 Vanagon:
Tube high temperature silicone
JB Weld
Tube anti-seize
Tube Loctite
Roll plastic electrical tape
Remnant of a roll of rubber electrical tape
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2 Tape measure
Jumper cables
Brake fluid
Motor oil
1/2 drive sockets 15mm-22mm
1/2 breaker bar and extensions
3/8 socket set regular and deep
3/8 spark plug socket
3/8 ratchet and breaker bar, plus extensions
Metric allen wrench set
17mm tool for tranny fill and drain
Feeler guage and spark plug wire gauge set
12 point adapter for CV joint bolts, long
Hex adapter for CV joint bolts, long
Screwdrivers:
3/8 flat, long
#3 phillips
Replaceable tip #1, #2, 3/16, 5/16
Replaceable tip, jewelers
Radiator hose tool
Small rattail file
Half round file
Cresent wrenches, 4", 6", 12"
10 x 11mm tubing wrench for brake lines
8mm - 22 mm combination wrench set
6mm - 19 mm box end set
3/8 - 5/8 English combination set
VOM meter
Wiring multi-tool with misc asst of wire terminals
Diagonal cutters
Snap ring pliers, two styles
Channel-locks 10"
2# ball peen hammer
Vise Grips, large and small
Battery drill, with bits 1/16 - 1/4"
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two |
tikibus Samba Member
Joined: July 07, 2006 Posts: 834 Location: Rochester, NY
Posted: Tue Jan 29, 2008 4:31 pm Post subject: |
Bucko is on the money!!
I drive mine everyday during the Summer. I get to know the clicks and the clacks, the wizz-bangs and farts. She knows me, I know her.
Only thing I would add to the pile of stuff is Listed above:
Spare Fuel Pump.
Beer Money.
 _________________ Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC |
Posted: Tue Jan 29, 2008 5:36 pm Post subject: |
Thanks guys - ththese are the sort of suggestions that I was hoping for. I will be driving the van extensively once the snow and ice have disapeared around here (Toronto). I don't want to expose the body (which is great) to the salt that our roads are loaded with.
I know that I have a leak in my expansion tank, I think its cracked around the seam, I'll replace it, bleed etc. The van was purported to have all new coolant lines when I bought it - all that I can see certainly look new and in good shape, I'll certainl;y go over them all very carefully.
I have most of the tools mentioned above and I will aquire the fluids etc from the top list. What I don't have I'll just have to buy (of course I need it dear, its on the list!!!)
I've had 3 bugs and 2 aircooled vans in the past so I know that once I begin to work on one thing it will lead to another and another - I also know that its way better to be prepared and have nothing happen than to be unprepared no matter what happens.
Keep the suggetions coming, I'm sure that its not just I who will find them useful.
JC |
Posted: Tue Jan 29, 2008 6:21 pm Post subject: |
Hot Snot! Gotta show the Vanagon!
The True Canadian Winter Campout '08 is just around the corner.
Feb. 16th/17th Valens Conservation Area, outside Hamilton.
I'll be there. Last year was a blast! -17C, but good people, good food, good times, makes the Cold go away!
Check the link below my Sig.
Cheers! Don't worry if you don't want to take your Vanagon out just yet, just gotta put a VW emblem on the ride you got and you'll be welcome  _________________ Happy Trails!
Mark
______________
1984 Westy - Tiki
Randy in Maine Samba Member
Posted: Tue Jan 29, 2008 7:45 pm Post subject: |
If you are cruising the north side over to Saguenay to see the belugas, take your kayaks, some good binoculars, and your camera.
If you are crossing over to Trois-Pistoles, get to the ferry early in the day.
We also took some extra lawn chairs, some sharp cheddar, and met lots of great folks out there and generally had a great time.
That lighthouse at Gaspe is quite a hike to get to but worth it. Literally tons of whales right off shore.
We saw quite a few Westies on our trip. |
bucko Samba Member
Posted: Wed Jan 30, 2008 6:43 am Post subject: |
| Wildthings wrote: |
| mightyart wrote: |
JB Weld
Tube anti-seize
Tube Loctite
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2 Tape measure
Jumper cables
Brake fluid
Motor oil
Screwdrivers:
3/8 flat, long
#3 phillips
Radiator hose tool
Small rattail file
Half round file
VOM meter
Diagonal cutters
Channel-locks 10"
2# ball peen hammer
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two |
Are you kidding me? Where are you going to put the "normal" trip supplies? If I thought I'd have to carry all this with me to take a trip in my Vanagon Westy, I'd just fly to the destination and rent a car! _________________ Current VW drives: 1984 Westfalia
Posted: Wed Jan 30, 2008 10:13 am Post subject: |
| It all fit quite nicely under one section of the middle seat. Even had a pair of boots and some other items stuffed in there as well. |
Posted: Wed Jan 30, 2008 10:34 am Post subject: |
| Wildthings wrote: |
Let me guess, you are single with no kids?
With a wife and two teenagers I am limited to the space under the digifant for all tools and spare parts. My travel tools list is much, much smaller. I limit what I bring to what I can reasonably accomplish on the side of the road. Anything more and it's my CAA card that takes over. _________________ -- 1987 Westfalia automatic (Captain Vino) |
kevinbassplayer Samba Member
Posted: Wed Jan 30, 2008 10:35 am Post subject: |
I carry all that and more!
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Wed Jan 30, 2008 11:07 am Post subject: |
| Yeah, when I travel longer distances I carry more or less what Wildthings listed and most of it fits under the rear seat, too. I also take an oil drain pan, local shops will usually let me use a spot behind their shop to change the oil/filter and will take the old oil. I also take along 2 jack stands, but I'll admit that the Westy is packed to the limit at that point. I do travel alone though, with my dog that is. One thing I plan on doing differently in the future is finding a better jack. Using the stock one in uneven terrain is too sketchy. |
Posted: Wed Jan 30, 2008 11:43 am Post subject: |
| Perales wrote: |
| Let me guess, you are single with no kids? |
Not hardly, got a standard mid aged wife and two kids in their early twenties.
Everything but the jumper cables, motor oil, and ground cloth fits into a tool box that contains only 1 cubic foot. The ground cloth lays under the mattress and the motor oil (a gallon by the way) is absolutely necessary in my $400 junker that uses almost a quart for every tank of fuel. This only leaves the jumper cables eating up what little space they do. |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Sat Mar 29, 2008 2:38 pm Post subject: |
| Wildthings wrote: |
JB Weld
Tube anti-seize
Tube Loctite
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2 Tape measure
Jumper cables
Brake fluid
Motor oil
Okay, I have a few (newbie mechanic) questions . . .
What is the vaseline used for?
What is "dry gas"?
What is FI cleaner (fuel injector?
What is BP Blaster? _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Raynor Shine Samba Member
Posted: Sat Mar 29, 2008 3:22 pm Post subject: |
I always have a 24" breaker bar , a 12v air compressor and a pair of gloves. I can keep filling if I get a flat some where until I get to a station.
I carry a bag of tools not as many as Wildthings, but close. I don't have them stashed under the seat due to camping gear. So they are basically in the way, on the floor. |
bmwloco Samba Member
Joined: March 19, 2006 Posts: 1093 Location: Asheville NC
Posted: Sat Mar 29, 2008 4:38 pm Post subject: |
I drive my '85 daily.
It's set up and ready to go camping at any moment. Down sleeping bags, a teapot and whatever else is necessary for a meal.
Last weekend I drove to a mate's house, he let me in his fortress gate, and I slept like a proverbial log that night. Got up the next morning to clean up the party zone, got in my Westy, dropped the top and motored home.
Gotta love a well sorted Westfalia.
Viva la Pop Tops! _________________ '85 Vanagon Westfalia |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24356 Location: NYC/Upstate/ROW
Posted: Sun Jun 25, 2017 5:24 pm Post subject: |
| Wildthings wrote: |
| mightyart wrote: |
JB Weld
Tube anti-seize
Tube Loctite
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2 Tape measure
Jumper cables
Brake fluid
Motor oil
Screwdrivers:
3/8 flat, long
#3 phillips
Radiator hose tool
Small rattail file
Half round file
VOM meter
Diagonal cutters
Channel-locks 10"
2# ball peen hammer
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two |
Good thread reply on tool lists for two recent posters _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
