climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Jul 24, 2009 11:51 pm Post subject: Power off switch for stereo amplifier? |
All stereo gear in my van is powered off the house battery.
I have a 50 watt amp powering the front door speakers, and a powered subwoofer (Boss 600) under the driver seat.
When camping, it'd be nice to be able to power down one or both of these units so low volume tunes can be enjoyed while putting minimum drain on the battery.
Has anyone added a "power down the amplifier(s) when parked" type switch?
Can you tell us some details / share photos about how you wired it so even a 12 volt dumblefutz like me can understand?
Cheers! _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Dingchowping Samba Member
Joined: March 31, 2009 Posts: 134 Location: Seattle, WA.
Posted: Sat Jul 25, 2009 12:03 am Post subject: |
So is it reasonable to assume from your description that the rear speakers are powered off the deck's internal amplifiers? How is the subwoofer's power on/off triggered? Separate trigger wire or does it sense the presence of an audio signal? If its the former then it would be simple to wire a switch into the remote turn-on lead from the deck. With the switch "on" the system will function as it does now. With the switch "off" whatever is hooked up to the remote turn-on lead will remain off.
TTFN,
Adam |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Sat Jul 25, 2009 12:50 am Post subject: |
That's a great idea Ding. I'm going to have to do that myself. On the couple of occasions that I've wanted to turn off my sub amp, I've just pulled the fuse from my aux panel behind the drivers seat. But I usually forget to put it back in and have to wait until I stop to have bass again. Dohh! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Sat Jul 25, 2009 7:26 am Post subject: |
Ding, I think that's the answer.
There are several approaches to this, but yours seems the simplest.
Thanks, I'll give it a go! _________________ '86 Westy, 2.5 Subaru power
90Doka_Guy Samba Member
Posted: Sat Jul 25, 2009 9:27 am Post subject: |
I bought a fog light switch off of ebay for 10 bucks and used that in the blank space in my dash. It powers down the sub when i dont want to use it. |
