sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4053 Location: Deep In My Own Psyche
Posted: Mon Aug 17, 2009 3:34 pm Post subject: shift rod (bushing) ...What the Hell! |
do i have to take the damn shift rod Out to put the bushing on
I must be stooopid or ???
i cant get the damn thing on
"special trick"??
Im hands deep in grease _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
| Me of Course wrote: |
| Extremity is relative to how far your willing to jump |
| Ward Cleaver wrote: |
| You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1900 Location: Feeling, Minnesota
Posted: Mon Aug 17, 2009 4:09 pm Post subject: |
You have to slide the shift rod most of the way out of the tunnel.
Remove the disc in the front apron and the front tunnel plate on the pan.
Disconnect the shift rod coupler and shifter plate.
Slide the rod forward until the end is in the shifter hole in the cockpit.
Replace the bushing on the shifter plate (don't forget the wire clip), slide the rod back and reassemble. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71856 Location: Phoenix 602
Posted: Mon Aug 17, 2009 4:20 pm Post subject: |
Thank you
ill tackle that tomorrow then
when i have more time
..........Just got back in from doing it Half in the dark
BUT
i slid it out
put the ring on and in the mount
and pushed from the front
Used the handle of a 26oz hammer(long)
to push it in the rest of the way
Now theres No Slop in the shifter
Awesome!  _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
yellow73 Samba Member
Posted: Wed Apr 28, 2010 3:24 pm Post subject: |
| Is it the same bushing as a Type 1? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Wed Apr 28, 2010 5:03 pm Post subject: |
Yes Sir. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Apr 29, 2010 8:14 am Post subject: |
| Thank you very much. |
DASLWST Samba Member
Joined: October 21, 2007 Posts: 194 Location: JACKSONVILLE
Posted: Fri Apr 30, 2010 3:48 pm Post subject: |
i really need to replace mine!!! it shifts like crap  _________________ #daslwst |
Posted: Sun May 02, 2010 1:32 pm Post subject: |
I thought I would share with you what I found when I replaced mine this weekend: -
Apparently one of the previous owner or their mechanics thought that there was a different way to quiet the rattling coming from the shifter....
I dug out over half a tub full of grease and a shop rag from the tunnel that I can only guess was put there in hopes of stopping the noise - it did not by the way!!!! |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Sun May 02, 2010 4:38 pm Post subject: |
| yellow73 wrote: |
I wonder how long that poor SOAB sat there with a grease gun pumping the tunnel full of grease  _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
