Thump noise in rear of bug
MichaelSpark
MichaelSpark is offline
PostPosted: Sat Apr 23, 2011 8:04 am    Post subject: Thump noise in rear of bug Reply with quote
I have a thump noise in the rear when I go over a bump -- it's a 67 bug. I've replaced shocks, put new rubber in the Z bar and it's still there. It sounds like the rear wheel is hitting the wheel well but I dont see any indication of that.
Any ideas from anyone? [/list]
Raymond73
Raymond73 is offline
PostPosted: Sat Apr 23, 2011 8:40 am    Post subject: Reply with quote
Take off the rear fender and have someone drive over a bump while you watch?
wbrown45
wbrown45 is offline
PostPosted: Sat Apr 23, 2011 10:55 am    Post subject: Reply with quote
I would inspect the rear body mounts, by the shocks. They have a habit of loosening up. If not that, then take a large prybar and start pulling, pushing, and investigating.
OK Thang
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Apr 23, 2011 11:23 am    Post subject: Reply with quote
Worn torsion arm rubber bushing.
drscope
drscope is offline
PostPosted: Sat Apr 23, 2011 5:38 pm    Post subject: Reply with quote
Is the deck lid fastened and tight?
Rear bumper mounts in good shape and bolts tight so the bumper isn't bouncing?
Check the 3 big bolts that hold the spring plate to the axle.
Look close at your shock rubbers.
You don't have a flash light or other lost device rolling around under the rear seat or back in the package tray area?
MichaelSpark
PostPosted: Sat Apr 23, 2011 5:40 pm    Post subject: Reply with quote
Thanks for all of your suggestions, I had the rubber in the torsion bars replaced as well.
KTPhil is offline
PostPosted: Sat Apr 23, 2011 6:02 pm    Post subject: Reply with quote
Loose battery hold-down clamp?
KingWeazle
KingWeazle is offline
PostPosted: Tue Apr 26, 2011 6:55 am    Post subject: Reply with quote
Inside or outside of the car ? My noise was the bottom of the back seat lifting and crashing down. A buddy of mine had his battery tie down clamp loosen up, banging the battery around on bumps.
