OIl levels with aftermarket dipstic, external oil filter
crapweasel
crapweasel is offline
PostPosted: Mon Aug 15, 2011 12:23 pm    Post subject: OIl levels with aftermarket dipstic, external oil filter Reply with quote
I am tracking down some smoke issues as discussed in another thread, but assumed it would be wiser to start a new one on this specific topic.
I have an external full size http://www.summitracing.com/parts/SUM-G4985-1/?rtype=10 oil filter mounted underneath the engine compartment.
I have noticed that the smoke seems to correlate with oil levels. I have been trying to use the dipstick, but I noticed an oddity. When I stick the dipstick in straight (round handle towards the back) it would sometimes read a quart low. If I rotate it towards the driver side, it reads dead on the line.
What's the relaitonship between external oil filters, deep sumps (which I don't have, yet)and the stock dipstick? How much oil should the engine have in it? I always assumed "to the line" regardless, since that's indicative of what the block has in it at the moment.
Any input appreciated as always. Thanks again for your guidance.
Edit: the reason I ask is I am concerned that my oil may be "too high" which is contributing to the smoke I see.
Please note I am in the process of also doing leakdown testing for other sources, original thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=476660
Engine: 2110
Pistons: 90.5
Heads 050
Crank 82 mm porsche journals
earthquake
earthquake is offline
PostPosted: Mon Aug 15, 2011 12:48 pm    Post subject: Reply with quote
Have you tried a stock dip stick in it? that way you can mark your after market stick to see if you have too much oil.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
crapweasel
PostPosted: Mon Aug 15, 2011 1:30 pm    Post subject: Reply with quote
I don't have one available, maybe I can find the measurement from the hole to the stick somewhere online. The aftermarket one AFAIK is the same length, but want to confirm.
I also need to determine what the proper level for a car with the extra reservoir is. I assume the same, but asking doesn't hurt.
