Loctite 518 / Permatex 51813
Page: 1, 2, 3  Next
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 5:18 am    Post subject: Loctite 518 / Permatex 51813 Reply with quote
Loctite 518 is frequently brought up in these forums as the miracle sealant savior solving multiple Vanagon woes.
In many areas, such as mine, finding Loctite 518 is difficult at best. Yes I can order it online or from Graingers but sometimes it's nice to get a needed product today.
On the other hand around here Permatex is everywhere!
Permatex 51813 can be had from almost every parts store around.
(51817, 51813, 51845 are the same product but different sized containers)
(Loctite has similar numbers for container sizes ... 51817, 51831, 51845)
Many online forum contributors make broad claims that they are the same product without any factual backing.........they simply boldly state that Loctite owns Permatex.
Well, that used to be true but is no longer.
Loctite acquired Permatex in 1972 but sold it in 1999.
http://www.permatex.com/about-us/company-overview/history
The MSDS sheets are very similar but not exactly the same.....
http://www.permatex.com/component/documents/?view=...SA-English
http://hybris.cms.henkel.com/henkel/msdspdf?country=US&language=EN&matnr=135481
Is Permatex 51813 a functional substitute for Loctite 518
For example.........
When Mercedes owned Dodge, the Mercedes Van was basically duplicated as the Dodge Sprinter van. After the company was sold by Mercedes the same Van, basically a Mercedes product, was still produced for years, even with FiAT's management.
Is it a similar situation with 518? The company was sold with the proprietary formulas?
I'm not against ordering Loctite 518, but if Permatex is the same product..... Why bother doing so?
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 5:44 am    Post subject: Reply with quote
I may have just answered my own question........
Looking around I went to Ben's Place...
http://www.benplace.com/vanagon_engine2.htm
To quote Ben's list of sealants he recommends.......
-Heads gasket (rubber one) = Dirco OR The right Stuff
-Pushrods tube and other low pressure parts = Loctite / Permatex 518
-High pressure parts = Curil K2 and Permatex Aviation
If it is Good enough for a respected technician like Ben....... It's Good enough for a nobody like me!
Dave
Ghia
Vanagon
Beetle
DAV!D
DAV!D is offline
PostPosted: Sun Jan 12, 2014 6:59 am    Post subject: Reply with quote
TY for this post, I've looked everywhere for loctite 518 but everyone has the permatex instead. I actually haven't found the loctite brand anywhere for even thread lock. I was just going to use the permatex and call it close enough., Laughing
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
insyncro
Banned
insyncro is offline
PostPosted: Sun Jan 12, 2014 7:34 am    Post subject: Reply with quote
They are NOT the same.
518 is superior.
Just as with Swepco fluids, plan ahead and order it before you need it.
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 7:43 am    Post subject: Reply with quote
518 is superior.
Demonstratively with specific measurable instances noted or just an opinion?
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Sun Jan 12, 2014 8:15 am    Post subject: Reply with quote
Experience Exclamation
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 8:22 am    Post subject: Reply with quote
Early failure?
Poor consistency?
Doesn't stick?
Blows out under pressure?
Temperature affects it?
Takes too long to set up?
Sets up too quickly?
Red is a nicer color than blue? Wink
Your responses are no more helpful than the they are both made by the same company response.
Why is one superior and does it really matter to us the occasional user?
It isn't like you to contradict Ben...... Ben says either one....... Question
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Sun Jan 12, 2014 8:34 am    Post subject: Reply with quote
If you want to do a taste test go for it.
I have been using 518 and recommending it since I joined here.
It is not hard to order 518.
My experiences have shown Loctite and Wurth products to be superior to Permatex and the generics.
Yes Loctite is a part of Henkels, but there are levels and grades of the products.
Certain manufacturers require certain products and have them made especially for them and the purpose.
518 was designed and manufactured for Porsche.
That is how and why I found it and use it.
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 8:48 am    Post subject: Reply with quote
I've no preference here and no axe to grind but your earlier statement that "518 is superior" makes one think that you've used both and through that experience of professional use, 518 reigns supreme.
What I am now hearing is that 518 is a Porsche product.........
that's why you use it,
Can I assume that you've no experience with the Permatex product in a similar application?
I'm just trying to wrap my head around this, not trying to offend or stir a pot.......
Dave
Ghia
Vanagon
Beetle
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sun Jan 12, 2014 8:50 am    Post subject: Reply with quote
Just try it and report back with your results
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 8:56 am    Post subject: Reply with quote
Well, if it's an inferior product...... Why would I try it?
I would just order the Loctite tomorrow.
I'm simply trying to harvest a consensus from the vast amount of experience represented on this site.
I also KNOW that there is a Henkles employee on this site.
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Sun Jan 12, 2014 9:08 am    Post subject: Reply with quote
I have used many of the available sealants on the market.
I have also been paid to test each.
When I recommend a product, it has been tested and is of the highest quality of all that I tested.
Most of what I use at my shop for materials such as sealants are not available at Walmart, Lowes or FLAPS.
Specialty stores, race shops, motorcycle shops and numerous online vendors carry the good stuff.
Amazon, ebay, JEGS, Summit Racing, Paragon.....all will be able to deliver the higher quality products.
Summit and JEGS have shown to send the freshest products as they move the most of them.
dobryan Premium Member
dobryan is offline
PostPosted: Sun Jan 12, 2014 9:09 am    Post subject: Reply with quote
Dave,
You do a great job of documenting what you do and it is a real benefit. Keep up the good work. I like a lot of what you do. Very Happy
But sometimes when you want information you can come across as somewhat demanding. It's the problem with the internet not allowing a quick back and forth verbally. I believe that your intentions are good. But sometimes I accept that someone likes one product vs another and that they are not obligated to give me specific reasons. I am OK with that.
Not trying to argue with you or criticize, just trying to help you see what I see from the outside looking in... Very Happy
(Full disclosure, I have ordered Loctitie 518 from eBay)
Peace,
Dave O
Dave O
The Western Syncro build
Zeitgeist 13
PostPosted: Sun Jan 12, 2014 9:12 am    Post subject: Reply with quote
I'm willing to bet that for many tasks, it's more than adequate. The Loctite product is probably up to even more tasks and harsher environments, hence the premium price and exclusivity. Hell, I'll try it and report back if no one else will
Casey--
'89 Bluestar ALH
NEAT, no ICE.
djkeev
djkeev is offline
PostPosted: Sun Jan 12, 2014 9:26 am    Post subject: Reply with quote
dobryan wrote:
Dave,
Peace,
Dave O
Thanks, I appreciate the feedback and constructive criticism.
I'm looking for concrete "it's better because it ............" Type information.
This is not an opinion driven answer. This is a measurable and repeatable thing.
If the sealant is inferior, it is inferior for a reason.
It isn't like saying Pepsi is better than Coke, that is my opinion only, a subjective unmeasurable personal opinion.
I'm sorry if I'm coming across as pushy but a statement saying one is superior with no facts is basically meaningless.
I do consider the source from which it came and that I have very high respect for what he does and his experiences he freely shares with us.
But then Ben's place whom I also respect says use either.
My quandary is that those others whom I respect frequently send us to Ben's place for answers!
I'll shut up now and sit on my hands while waiting to see what others have to add towards answering this question.
Dave
Ghia
Vanagon
Beetle
DAV!D
DAV!D is offline
PostPosted: Sun Jan 12, 2014 10:03 am    Post subject: Reply with quote
I was going to try the permatex but as I've had to order replacement float valves, I decided to just order the 518 being I'll have to wait to put my gas tank back in. Pulling the tank out was a PITA and if there is a chance 518 is even slightly better I'd say a few bucks extra is worth it.
Merian
Merian is offline
PostPosted: Sun Jan 12, 2014 12:54 pm    Post subject: Reply with quote
Loctite says on their product sheets that Loctite 518 is for two hard surfaces. I thought I saw it touted on here for sealing rubber fuel hose connections, etc.
Can someone explain that?
dobryan is offline
PostPosted: Sun Jan 12, 2014 2:51 pm    Post subject: Reply with quote
Because it stays flexible it is good to use on hose connections that may undergo expansion/contraction. This past cold snap I had some coolant leaks from hose fittings and I am going to redo all my coolant hose connections with Loctite 518 on the junctions as a help to this issue. Makes sense to me.
Dave O
vanagonjr
vanagonjr is offline
PostPosted: Sun Jan 12, 2014 3:28 pm    Post subject: Reply with quote
Me too, I just ordered on Amazon with free shipping 50ml tube.
Will be a while before I use it though.
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Jan 12, 2014 10:07 pm    Post subject: Reply with quote
GM pt. # 1237 8521 Engine Assembly adhesive is as good as, if not better than the Loctite 518, and is available at any GM dealer parts counter--anywhere, anytime.
T.K.
Page: 1, 2, 3  Next
