MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Tue Aug 12, 2014 4:05 pm Post subject: 5 Speed transaxle swap (for shorter first gear) |
We want to look into the options of swapping our 091 transaxle for a 5 speed unit so we can fit a "granny" gear, basically an extra short first gear. The reason why we want a shorter first is for offroading and climbing steep inclines. We'd like to keep the stock ratio's for first to fourth more or less the same as stock. We just need an extra gear on the low end.
What transaxle would be the easiest to do this with? Can we fit a 094 box without cutting the torsion bar tube? I've been searching the forums but couldn't find anyone who fitted a 094. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Tue Aug 12, 2014 9:37 pm Post subject: |
I had been thinking the same thing in the past months. It would be ideal to use a vanagon diesel 5 speed box with the really short first gear. You could them add an LSD or possibly a syncro locker. Certainly interested in what you find out. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Wed Aug 13, 2014 2:39 am Post subject: |
levi20AE wrote: |
I had been thinking the same thing in the past months. It would be ideal to use a vanagon diesel 5 speed box with the really short first gear. You could them add an LSD or possibly a syncro locker. Certainly interested in what you find out. |
Exactly! We currently have a Peloquins LSD in our 091, which is an awesome piece of kit. So we'll definitely have to fit the new transaxle with another LSD or a locker.
http://www.weddleindustries.com/transaxles/vw-transaxles/094-heavy-duty-vanagon
This looks like a good option, but it will require cutting the torsion bar tube...
chazz79 Samba Member
Posted: Wed Aug 13, 2014 3:43 am Post subject: |
No, you should be good.
The nose of the van trans is smooth without the mount in place. I don't think you'll have any issues. The 2wd 5spd is a rare bird here in the states. If you find one you'll pay for it . First gear also isn't used in normal driving. It's a off road gear, the nob is labeled g-4 on our vans.
There's also a full side shift conversion, all the way up to the shifter and floor bucket from a five speed van you'll need. Price all parts accordingly. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Bursch Samba Member
Joined: October 28, 2006 Posts: 448 Location: Netherlands
Posted: Wed Aug 13, 2014 11:07 am Post subject: |
chazz79 wrote: |
There's also a full side shift conversion, all the way up to the shifter and floor bucket from a five speed van you'll need. Price all parts accordingly. |
Yup, we'll need it to be more comfortable offroad and especially overcoming steep inclines and rocky surfaces on high altitude (up to 16.000ft, robs a LOT of power). Stop-and-go city traffic in La Paz, Bolivia, is a real b*tch on the clutch _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Bursch Samba Member
Posted: Wed Aug 13, 2014 11:15 am Post subject: |
094 five-speed
091
The 091 fits snug, maybe 1/4" between the mounting bolts and the torsion bar housing. The shifter fits over the torsion bar housing
also
http://www.thesamba.com/vw/forum/viewtopic.php?t=143138 _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3185 Location: South Benfleet, Essex, UK
Posted: Tue Nov 03, 2015 9:17 am Post subject: Five-speed transaxle for 1972~79 VW Type 2 |
The five-speed transaxle for the VW Transporter T3 (aka Vanagon in North America), was available as factory-stock with the 1·6 litre turbo-diesel engine and the 2·1 litre high-compression, flat-four petrol engine.
It was also available as a factory-fitted option, with the 1·6 & 1·7 litre diesel engine and 1·9 litre flat-four petrol engine.
I have details of the gear & final-drive ratios. _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
