Should this foam be here?
Yondermtn
Yondermtn is offline
PostPosted: Mon Apr 20, 2015 11:53 am    Post subject: Should this foam be here? Reply with quote
I was under the Vanagon yesterday and noticed this foam.
It is just in front of the front steps, right above the rusty bracket in the first pic. Should this be there and what is its purpose?
The foam is pretty much right behind the visible rust spot here.
I also noticed this foam. Do I need new foam here?
1977 Westfalia 2.0FI 4spd
1990 Multivan 2.1 Auto
svenakela
svenakela is offline
PostPosted: Mon Apr 20, 2015 12:02 pm    Post subject: Reply with quote
Yes, it's foam soaked in wax stuffed in there as a noise reduction and it works pretty darn good. The foam is not sucking up water so it's not to blame for the rust, but if you repair by welding you have to take it out.
Vanagon mirror end caps
insyncro
Banned
insyncro is offline
PostPosted: Mon Apr 20, 2015 12:40 pm    Post subject: Reply with quote
Yes, later models and dealer serviced early vans have that foam.
I pull it out, fix anything around that area and replace with brand new, soaked in Wurth wax as noted previously.
Yondermtn
PostPosted: Mon Apr 20, 2015 1:00 pm    Post subject: Reply with quote
Great, just the answers I was looking for. Thanks.
I thought it looked factory, but I know some people like to stick insulation where it shouldn't go.
morymob
morymob is offline
PostPosted: Mon Apr 20, 2015 1:04 pm    Post subject: Reply with quote
They mostly walk funny.
dhaavers
dhaavers is offline
PostPosted: Mon Apr 20, 2015 7:12 pm    Post subject: Reply with quote
Yondermtn wrote:
...I know some people like to stick insulation where it shouldn't go.
<ouch>
Wink
"The WonderVan"
