Auxiliary battery/ no power to solenoid
Thrill707
Thrill707 is offline
PostPosted: Tue Sep 22, 2015 2:27 pm    Post subject: Auxiliary battery/ no power to solenoid Reply with quote
I have a stock 86 Westfalia. I received the Gowesty auxiliary battery kit as a gift, I know not the best option. I have power from the alternator blue wire to the relay #86 pin. The problem is I don't have power from the relay #30 pin to the solenoid with the new blue wire provided in the kit. I bought a new relay, still no power. My OXS light is on and when i unplug the alternator blue wire from #86 pin the OXS light goes out. Not sure if the two are connected. Any ideas what the issue could be? Thanks
termuehlen Premium Member
termuehlen is offline
PostPosted: Tue Sep 22, 2015 6:24 pm    Post subject: Reply with quote
Need a little more information than "I have power from the alternator blue wire". What is the voltage with the engine running? Does revving the engine help? Check the voltage at pin #30 on the relay when you do this, as well. Verify that you either (1)have enough voltage to power the relay and it is not functioning or (2) you do not have enough voltage to operate the relay. You will probably find this very useful...
http://www.thesamba.com/vw/forum/viewtopic.php?t=606057&highlight=oxs+circuit
If you do additional searches for "aux battery", "OXS sensor" and "blue alternator circuit" you will find lots of information about this topic.
1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx
Thrill707
PostPosted: Tue Sep 22, 2015 7:47 pm    Post subject: Reply with quote
I have 10.80 V from the blue wire to the relay #86 when the engine is running. I connected a 12 gauge wire straight from alternator to relay,with this I had 13.04 V at the #86 pin and the relay clicked and charged the auxiliary battery. I have 12.74 V at the #30 pin. Revving the engine doesn't help. When I put power straight to the relay my OXS light went off. I also removed the black and red wire and put in a direct ground. This did not help. What should my next step be. Thanks for the help.
goffoz
goffoz is offline
PostPosted: Tue Sep 22, 2015 9:46 pm    Post subject: Reply with quote
"Furry little otter" is in your town.
cranky guy, but has great skills, you might reach out to him.
The GW kit is problematic...I junked mine and went yandina, you should consider this
0to60in6min
0to60in6min is offline
PostPosted: Tue Sep 22, 2015 9:56 pm    Post subject: Reply with quote
either Yandina or SurePower are good....
PostPosted: Wed Sep 23, 2015 9:16 am    Post subject: Reply with quote
If I am understanding you correctly, when you connect a 12+ wire to pin 86 on the relay, everything works as intended. When you connect the blue alternator wire as the power source to pin 86 you get about 10.8V and the relay will not engage.
I would suggest you carefully inspect the connection of the blue wire at the alternator. If all is good, it may be time for you to look at the alternator. You could either have it checked out by someone, or you could inspect it yourself. Take out the brush/regulator assembly, slightly stretch the brush leads and put it back to see if it improves. Or, just go ahead and replace the brushes if you are going to the trouble of removing them.
This thread may provide you with more information...
http://www.thesamba.com/vw/forum/viewtopic.php?t=569002&highlight=bat+oxs+light
Thrill707
PostPosted: Wed Sep 23, 2015 4:14 pm    Post subject: Reply with quote
It's a new alternator. The folks at Gowesty told me that the relay only takes a couple volts to click. I have two relays and they won't click with 10.80 volts. I'm thinking that the blue wire from the alternator is compromised, but it still gets 10.80 Volts to pin#86. Maybe the van has a wiring gremlin!
fxr
fxr is offline
PostPosted: Wed Sep 23, 2015 4:27 pm    Post subject: Reply with quote
Duff relay (unlikely) or duff ground on the relay coil (on pin 85 - my prime suspect with your description).
Jim Crowther
Vespa GTS 300
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Sep 23, 2015 4:36 pm    Post subject: Reply with quote
Did you measure the blue wire voltage on relay pin 86 while the other pins on that same relay were properly hooked up? Perhaps that would show much less than 10 volts. If so, then look for a problem with the blue wire from the alternator. Inside the engine wiring box is a connector in the blue wire path. That connection could be weak.
Mark
Thrill707
PostPosted: Wed Sep 23, 2015 8:20 pm    Post subject: Reply with quote
I did some more tests and I have the 10.80 V when the blue wire is not hooked up to 86 pin. When the blue wire is hooked up I have 1.50 V. Inside the engine wiring box I have 12.79 V on both sides of the blue wire connection in that box.
