Assembling the body onto the floor pan
oniondeluxe
oniondeluxe is offline
PostPosted: Thu Feb 23, 2017 3:14 pm    Post subject: Assembling the body onto the floor pan Reply with quote
I'm considering building a adjustable, computer controlled frame for the Beetle body. It is supposed to be able to tilt and/or rise. But I need some dimensions..
Does anyone know:
1 What is the minimum clearance of the body (with respect to the floor pan) needed when the body should be lowered back to the floor pan, with engine mounted?
2What angles are needed when lowering the body down to the floor pan?
Keith
Keith is offline
PostPosted: Thu Feb 23, 2017 6:23 pm    Post subject: Re: Assembling the body onto the floor pan Reply with quote
Trying to understand why you need to go through all the work of building this.
Are you plan on taking a LOT of bodies on and off?
4 people can easily lift a body and it only costs a few beers.
A single person can do it in several different manners. With lifts, hoists, jacks etc.
Lifting and dropping the body sraight up and down on or off the chassis is the easiest method.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
DDub
DDub is offline
PostPosted: Thu Feb 23, 2017 6:31 pm    Post subject: Re: Assembling the body onto the floor pan Reply with quote
You must enjoy the effort? I put my split body back on by myself, no glass, doors or fenders. Not a big deal.
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Thu Feb 23, 2017 6:49 pm    Post subject: Re: Assembling the body onto the floor pan Reply with quote
... I have a friend who is a mechanical engineer and performs the simplest tasks using his complex mind, to make things work. Most methods he employs really impress me though, but is not the way, I would do it... That's okay as there are many ways to approach everything... my simple mind just lifts things up.
Looking forward to see what you come up with.
... when working alone, I use jacks, 2x4s and pedestals and slowly lift the body off. When it's at 24 inches, I remove the wheels and slide the pan out, pulling with my single cab... then slide a pan in and lower everything. I have always installed an engine at a later time...
strait up, off and strait down on... but more than one way to do everything.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
oniondeluxe
PostPosted: Fri Feb 24, 2017 3:09 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
Interesting feedback....
Well, it will need a lot of work, but beside the fact that I find it fun to build such things, it could be convenient to have:
I don't have the ceiling clearance to install a two pillar lift, which would be the easiest solution. And I would like to have the precision of of repeatedly tweaking the body small distances up and down, for instance when adjusting heater channels fit onto the floor pan. The sway when people are holding the body in the air will be a problem.
So, you say, 24 inches it the required height? Counted from ground level?
Is not any tilt/angle required at all? Even when all equipment is installed on the floor pan?
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Fri Feb 24, 2017 10:07 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
If you do insist on doing this with a tool, maybe you should do it how the factory did..,the lift points were in the wheel wells. I'm sure someone can post an assembly line photo. I would definitely use the 4 friends method though.
https://instagram.com/mr.ogpaint
Patrick Hall
ZENVWDRIVER
PostPosted: Fri Feb 24, 2017 8:25 pm    Post subject: Re: Assembling the body onto the floor pan Reply with quote
... yes sir, 24 inches from the ground, with the wheels off will allow the pan to be slid out... and no angle is considered for my simple mind... just strait up and strait down... then, nudge the body around, until the mounting holes line up.
I rarely can muster 4 helpers and do most everything utilizing the solo
method.
... below see another solo method, I tried... jacking the body up a little and sliding it off. Man, that was cumbersome and not efficient (to me)... just goes to show, there are more than one way, to do everything... I did it, but not recommended.
1960 single cab
'87 Toyota MR2
DDub
DDub is offline
PostPosted: Sat Feb 25, 2017 4:51 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
You guys make it look hard. Two 2X8's on piers and ROLL the chassis under, then lower each end.
ZENVWDRIVER
PostPosted: Sat Feb 25, 2017 8:51 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
... oh, looks hard? Sorry, it's not difficult at all... thanks for your input though
Mr DDub.
1960 single cab
'87 Toyota MR2
Mr. OGPaint
PostPosted: Sat Feb 25, 2017 8:56 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
Here is one way body's were moved at the factory
Patrick Hall
oniondeluxe
PostPosted: Sat Feb 25, 2017 9:03 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
That's Dreamland....
Do you think you have pics of the corresponding lifting equipment later in the production? Ie when headliner and glass has been assembled?
hopkin Premium Member
hopkin is offline
PostPosted: Sat Feb 25, 2017 9:17 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
I don't if this will help, but here's some dimension info that was posted a while back here on Samba:
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (past)
2017 Dune Edition (daughter's car)
oniondeluxe
PostPosted: Sat Feb 25, 2017 9:35 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
Great pics! However, the first seem to be a 1958-1964 body?
hopkin is offline
PostPosted: Sat Feb 25, 2017 9:40 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
Could be, I didn't look at the pictures closely, but I thought they might be helpful as a starting point for you.
1974 SunBug (past)
1972 914 (past)
2015 Golf (past)
Isbrand52
Isbrand52 is offline
PostPosted: Sun Feb 26, 2017 6:19 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
A bare body I just slide a 2X4 thru door opening just in front of B piller, a strap over roof attached to an ATV winch on ceiling. Straight up One person. To put body back on pan I put two 10mm engine studs in floor pan under back seat one on each side and two in front on body at front of body at front cross member right in front of your feet. These guide pins align the body to pan correctly One person and its on Maybe someone can use this method Works for me Thanks Bob
obieoberstar
obieoberstar is offline
PostPosted: Sun Feb 26, 2017 5:09 pm    Post subject: Re: Assembling the body onto the floor pan Reply with quote
instead or reinventing the wheel, why not take the challenge and make the VW tool listed in the archives? Technical drawings are listed also.
http://www.thesamba.com/vw/archives/manuals/local_manufacture/605a.jpg
oniondeluxe
PostPosted: Mon Feb 27, 2017 4:22 am    Post subject: Re: Assembling the body onto the floor pan Reply with quote
That was really cool! Now, we are getting closer.
