Syncro R&P Gears-exact same gearset physical size front & back?
Steve M.
Steve M. is offline
PostPosted: Sun Oct 28, 2018 3:00 pm    Post subject: Syncro R&P Gears-exact same gearset physical size front & back? Reply with quote
So my question is if the R&P on the front differential is the same one as on the rear in regards to being the same part numbers?
I know the ratios have to match obviously, but is the shaft the same length as the one used in the transaxle?
If I wanted to replace both R&P's in the rear and front can I just order two of the same part number?
Thanks.
gears
gears is offline
PostPosted: Sun Oct 28, 2018 3:27 pm    Post subject: Re: Syncro R&P Gears-exact same gearset physical size front & back? Reply with quote
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
Steve M.
Steve M. is offline
PostPosted: Sun Oct 28, 2018 3:28 pm    Post subject: Re: Syncro R&P Gears-exact same gearset physical size front & back? Reply with quote
Exactly what I wanted to see! Thank you very much.
Sodo
Sodo is offline
PostPosted: Sun Oct 28, 2018 5:00 pm    Post subject: Re: Syncro R&P Gears-exact same gearset physical size front & back? Reply with quote
And he was kind enough to NOT include the price. Or the price of installation either.
I'm apparently not so kind. Is it $4,000, $5,000?
....KTMs, GasGas, SPOT mtb
MarkWard
MarkWard is offline
PostPosted: Sun Oct 28, 2018 6:36 pm    Post subject: Re: Syncro R&P Gears-exact same gearset physical size front & back? Reply with quote
We are lucky new parts are available. I watch the syncro part classifieds and good used transaxle parts just don't come up often. And better yet, different matching ratios.
