Headlights not working, again!
thomast
thomast is offline
PostPosted: Mon Jul 08, 2019 9:51 am    Post subject: Headlights not working, again! Reply with quote
They were working great. Stopped for gas and when I started the motor again, no headlights.
I put in a new switch
Redid the grounds
Checked the fuses
The yellow running light work.
The blue high beam indicator light comes on, but get no lights to come on.
Thoughts on what else I might check?
Thanks!
1986 Westy Syncro SVX
1970 Bay Window
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jul 08, 2019 9:54 am    Post subject: Re: Headlights not working, again! Reply with quote
Does the blue indicator consistently turn on/off when the high/low switch is actuated?
Does it then stay on when you release the high/low lever in the high position?
Mark
thomast
thomast is offline
PostPosted: Mon Jul 08, 2019 10:19 am    Post subject: Re: Headlights not working, again! Reply with quote
Yes, blue high beam indicator light stays on like it normally would
1970 Bay Window
crazyvwvanman
PostPosted: Mon Jul 08, 2019 10:39 am    Post subject: Re: Headlights not working, again! Reply with quote
My question is does the blue indicator stay in both the OFF and the ON modes as it should, when you take your hand away from the lever after selecting each mode?
Mark
levi
levi is offline
PostPosted: Mon Jul 08, 2019 1:30 pm    Post subject: Re: Headlights not working, again! Reply with quote
Connector plug immediately behind the headlights?
A few years ago I was driving at night when one went out.
Noticed a little slack there so some tinfoil got me home.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
tjet
tjet is offline
PostPosted: Mon Jul 08, 2019 3:58 pm    Post subject: Re: Headlights not working, again! Reply with quote
I ended up re-wiring my headlights because I had a similar issue. I tied off and stowed away the factory h/l harness and installed a good used harness with the addition of relays. I also went to a "key-on" power source. For switches, I installed a pair of high quality toggle switches from a vintage Cessna. I wired it in a way that I can turn on the headlight only and use them as DRL lights.
I still use the factory headlight switch to turn on the parking lights.
thomast
thomast is offline
PostPosted: Mon Jul 08, 2019 9:54 pm    Post subject: Re: Headlights not working, again! Reply with quote
Crazyvwvanman, the blue light stays on after I click it. I don’t have to hold it to stay on.
1970 Bay Window
VicVan
VicVan is offline
PostPosted: Mon Jul 08, 2019 10:08 pm    Post subject: Re: Headlights not working, again! Reply with quote
Redid the grounds
Checked the fuses
Thanks!
This might sound trivial, but your list doesn't show that you've tested or changed the bulbs themselves.
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
thomast
thomast is offline
PostPosted: Wed Jul 10, 2019 9:14 am    Post subject: Re: Headlights not working, again! Reply with quote
Bulbs all look good.
Recap:
-Ground is good
-Bulbs are good
-Fuses are good
-Installed new headlight switch
-Blue high beam light will stay on without holding in the lever
-Yellow running lights work.
-Low and High Beams do not work at all
Hitting the road home tomorrow. Would love to figure this out today.
If anyone has any other suggestions on what to look for, I’d appreciate it.
1970 Bay Window
crazyvwvanman
PostPosted: Wed Jul 10, 2019 9:28 am    Post subject: Re: Headlights not working, again! Reply with quote
That only answers half of my question. The fine details matter for solving problems.
Mark
SCM
SCM is offline
PostPosted: Wed Jul 10, 2019 9:44 am    Post subject: Re: Headlights not working, again! Reply with quote
Mark
Mark, I'm a little confused by your question too. Are you asking whether the blue light stays ON even when the high beams would be OFF if they were operating normally?
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
crazyvwvanman
PostPosted: Wed Jul 10, 2019 9:54 am    Post subject: Re: Headlights not working, again! Reply with quote
Here is my question again. Read the whole thing, paying attention to the last 4 words.
Mark
Mark
dobryan Premium Member
dobryan is offline
PostPosted: Wed Jul 10, 2019 9:58 am    Post subject: Re: Headlights not working, again! Reply with quote
Mark
Mark
Mark, are you asking if the blue light stays on regardless if the high beams are selected as ON or OFF (lever released after selection)?
Dave O
The Western Syncro build
outcaststudios
outcaststudios is offline
PostPosted: Wed Jul 10, 2019 10:19 am    Post subject: Re: Headlights not working, again! Reply with quote
Test the bulbs. ( I see that you did) also be sure to recheck the connectors on the back of the bulb housing, rubber cover etc.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791
thomast
thomast is offline
PostPosted: Wed Jul 10, 2019 1:15 pm    Post subject: Re: Headlights not working, again! Reply with quote
The blue hi beam light works as it should. Pull back the lever, it clicks and it’s on. Pull it back again, it clicks and it goes off.
T
1970 Bay Window
crazyvwvanman
PostPosted: Wed Jul 10, 2019 1:36 pm    Post subject: Re: Headlights not working, again! Reply with quote
Assuming the led is switching completely off when you click the lever to that mode, then you likely have more than 1 problem.
Assuming again, this is your 86 with a 22 fuse panel and not some other year?
Also you have a 4 headlight setup?
With the KEY OFF, if someone stands in front and looks closely at the headlights while you pull the hi/lo lever up and hold it, do any bulbs come on at all?
The dash indicator should come on and stay on while you hold the lever up. Does it?
Mark
thomast
thomast is offline
PostPosted: Wed Jul 24, 2019 1:15 am    Post subject: Re: Headlights not working, again! (Solved) Reply with quote
I replaced the GW high-power headlight relays and the lights are again working.
Thanks everyone for the help!
1970 Bay Window
