Score300 Samba Member
Joined: December 13, 2020 Posts: 5 Location: Jefferson, GA
Posted: Wed Mar 15, 2023 6:49 pm Post subject: 66 cal look |
I'll start with I'm almost clueless about tire sizes. I've been scanning through Thesamba hoping to find my answers without asking but I'm unsuccessful.
I'm building my '66 beetle that I had when I was a kid. I bought 15x4 rims for the front and 15x6 for the rear. Adjustable beam on the front 2" narrowed with disc conversion. The back has 2" dropped spring plates. I'm wanting a somewhat aggressive stance. I'm trying to figure out what size tires to use. Any help and suggestions are appreciated.
Right now, I'm thinking something like 135/60 15 on the front and 205/60 15 on the back. I really wished I could see it on the car before buying them though. _________________ '67 Doublecab
'67 Sportsmobile camper
'66 beetle (I sold this car in '94 and found it in 2021 by luck) in process of restomod back to '80s cal look.
'71 convertible (the wifes)
1963 ragtop
1961 ragto[
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80187 Location: Sneaking up behind you
Posted: Wed Mar 15, 2023 6:58 pm Post subject: Re: 66 cal look |
A 295/60 is too wide for a 6" rim and you'll need wider rear fender.
A 215/60 will fit and is pretty aggressive. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3005 Location: HdG, MD & NJ
Posted: Thu Mar 16, 2023 5:54 am Post subject: Re: 66 cal look |
I have 145’s on 4.5 rims and 205/60’s on 5.5 rims. 3” narrowed beam. I like the drag race look. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Thu Mar 16, 2023 6:00 am Post subject: Re: 66 cal look |
| NJ John wrote: |
| I have 145’s on 4.5 rims and 205/60’s on 5.5 rims. 3” narrowed beam. I like the drag race look. |
Would you mind showing me a pic of your setup? _________________ '67 Doublecab
1963 ragtop
1961 ragto[ |
slalombuggy Samba Member
Posted: Sun Mar 19, 2023 8:16 am Post subject: Re: 66 cal look |
135s SUCK. They don't turn, they don't stop, there are far better choices for tires.
205/60s are a good choice. I've put as big as 215/65/15 on a 6" wheel in the rear of a swing axles car. |
Glenn  Mr. 010
Posted: Sun Mar 19, 2023 8:19 am Post subject: Re: 66 cal look |
| slalombuggy wrote: |
| 135s SUCK. They don't turn, they don't stop, there are far better choices for tires. |
Yup.. 195/55-15 front and 205/60-15 rear
Member #1009
#BlueSquare
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Mon Mar 20, 2023 6:14 pm Post subject: Re: 66 cal look |
Since your title here says Cal Look. I`ll say 145/80X15 and 205/70x15. _________________ If you`re going to do something, do it right. |
Posted: Tue Mar 21, 2023 3:46 pm Post subject: Re: 66 cal look |
Yeah, yeah original Cal Look, we know. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Tue Mar 21, 2023 10:04 pm Post subject: Re: 66 cal look |
| NJ John wrote: |
| Yeah, yeah original Cal Look, we know. |
And if you don`t like skinny tires, try a 175/65X15. _________________ If you`re going to do something, do it right. |
Rattlecan Samba Member
Posted: Sat Sep 16, 2023 2:03 pm Post subject: Re: 66 cal look |
| Glenn wrote: |
[img]
I looked through 100s of pages for tire sizes trying to get an idea of what would fit on mine. I just got this set up on my with 5.5 wide on the front and 6 wide on the rear. Thanks for putting your information out there it helped.
OutbackUSA Samba Member
Joined: October 16, 2023 Posts: 18 Location: Las Vegas, Nevada USA
Posted: Mon Oct 16, 2023 11:19 am Post subject: Re: 66 cal look |
| Glenn wrote: |
Can you spec the offset and width of the rims you are using?
Thank you |
