Screw/nuts/bolts
Bbuggin68
Bbuggin68 is offline
PostPosted: Thu Sep 14, 2023 3:30 pm    Post subject: Screw/nuts/bolts Reply with quote
Does anyone know of a resource (website,book,whatever) for some kinda bolt/screw diagram for beetles? I purchased a stripped down, newly painted 68 beetle with all hardware removed. As I’m purchasing parts, it’s super time consuming to find what size bolts or screws are required to install a part.
Much appreciated.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Sep 14, 2023 3:37 pm    Post subject: Re: Screw/nuts/bolts Reply with quote
I would start with a box of M6x12, M8x25 and assorted M10
https://volkswagen.7zap.com/en/usa/vw+1200+1300+1302+1303/1200/1968-31/
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
baldessariclan
baldessariclan is offline
PostPosted: Thu Sep 14, 2023 4:39 pm    Post subject: Re: Screw/nuts/bolts Reply with quote
You can also try referring to an old official VW parts catalog, like the one scanned in at this website:
http://oacdp.org/type1part.html
Bbuggin68
PostPosted: Thu Sep 14, 2023 7:04 pm    Post subject: Re: Screw/nuts/bolts Reply with quote
Awesome. Great info. Thanks guys
54bug
54bug is offline
PostPosted: Fri Sep 15, 2023 5:53 am    Post subject: Re: Screw/nuts/bolts Reply with quote
Hi, All
I'm going to recommend Totally Stainless at https://www.totallystainless.com/. Lots of kits to replace hardware sets throughout the car as needed. I'm a fan of non rusting stainless hardware, although it requires the use of Anti-seize when doing assembly.
Your mileage may vary, but I've had good luck dealing with this company. I also bought an package assortment of metric bolts, washers, and nuts in an organizer. It's been a very handy solution to a bunch of headaches
Scott
doug bugg
doug bugg is offline
PostPosted: Fri Sep 15, 2023 6:00 am    Post subject: Re: Screw/nuts/bolts Reply with quote
Great site!
"Knowledge is Good" - Faber College
Mr. 010
Glenn is offline
PostPosted: Fri Sep 15, 2023 7:18 am    Post subject: Re: Screw/nuts/bolts Reply with quote
54bug wrote:
Hi, All
Scott
Most stainless hardware is not as strong as grade 8.8 or 10.8
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
ashman40
ashman40 is offline
PostPosted: Fri Sep 15, 2023 12:35 pm    Post subject: Re: Screw/nuts/bolts Reply with quote
54bug wrote:
Hi, All
I found the specific VW Beetle page:
https://shop.totallystainless.com/productlistv.php?a=Volkswagen&b=Beetle
The different full kits come w/ different style heads of the bolts (hex, button, socket, cheese, phillips, etc.) depending on which kit you buy.
Also, here is an old thread on the same topic with suggestions, but I'm not certain all the sources are still around.
Stainless steel bolt kits
AshMan40
viiking
viiking is offline
PostPosted: Fri Sep 15, 2023 7:39 pm    Post subject: Re: Screw/nuts/bolts Reply with quote
Glenn wrote:
54bug wrote:
Hi, All
Scott
Absolutely correct. I wouldn’t use standard SS grade on anything critical or structural without understanding the bolt strength. OK for running boards, fenders and body connections. And there are many grades of SS. Not all SS is rustproof in all conditions e.g. in salt ridden areas,
