amishman Samba Member
Joined: March 09, 2004 Posts: 3239 Location: California
Posted: Fri Apr 12, 2024 2:47 pm Post subject: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
Considering the new 67 only master cylinder that CIP1 sells.
Found here
https://www2.cip1.com/vwc-211-611-011-q/
Anyone using this and other than it using a non stock reservoir, anything need to make the swap?
Appears it is made for the 67 Only new so curious.
Thanks
TJ _________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
BruceFD Samba Member
Joined: August 31, 2020 Posts: 20 Location: Placentia, CA
Posted: Fri Apr 12, 2024 2:57 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
I used this master when I was doing a front disk brake conversion (1960 bus). The only other thing I bought was the 1967 reservoir that CIP1 mentions you need when doing the swap.
I have roughly 600 miles on this master with no issues so far. |
Posted: Fri Apr 12, 2024 3:03 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
| BruceFD wrote: |
Thank you for the note.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26194 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 12, 2024 5:52 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
| amishman wrote: |
| anything need to make the swap? |
From the "Split Bus FAQ / How To's / Topic Catalog- *Read before posting*" :
https://www.thesamba.com/vw/forum/viewtopic.php?t=242594 _________________ In Stereo, Where Available! |
Posted: Fri Apr 12, 2024 6:17 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
Appreciate the link but I had already perused and searched before I posted my question.
I was asking specifically about the CIP1 branded 67 Master and for anyone that actually purchased and installed one, if they had any surprises basically other than the known need of a different reservoir.
But thanks again for the link. I read all sorts of Master Cylinder posts in the last couple of days.
TJ
Posted: Sat Apr 13, 2024 8:30 am Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
I went ahead and ordered the CIP1 67-Only Master Cylinder and Reservoir, at the price, and I always worry some 1-year Only stuff gets hard to find sometimes, nice to have at least.
Unsure if I ill replace mine this year as I work on rear brakes but if I do, will report here my own findings.
59 dormi Samba Member
Joined: September 06, 2006 Posts: 622 Location: Ontario Canada
Posted: Thu Apr 18, 2024 6:30 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
I bought this and am having issues with the resovoir bungs leaking _________________ 1959 Dormobile
Mini R53 bob the tomato
Range Rover L322 |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1363 Location: Yulee FL
Posted: Fri Apr 19, 2024 10:12 am Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
I had the same issue too, I had to carefully trim some of the "flashing" from the bungs, it's just flaps of rubber left over from the molding process.
| 66 dormi wrote: |
| I bought this and am having issues with the resovoir bungs leaking |
Posted: Fri Apr 19, 2024 11:06 am Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
| 66 dormi wrote: |
Are you saying the leak is under or on top of where the rubber rings (I guess these are the bungs you mean) push into the Master Cylinder and where the plastic bottle pushes into?
Just trying to better understand where the leak is at so I can look into this.
Thanks
Posted: Fri Apr 19, 2024 11:07 am Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
| ryans65 wrote: |
| 66 dormi wrote: |
Can you elaborate a little on the trimming you did?
I take it you somehow smoothed out the rubber bungs where the plastic bottle inserts to so it gets a better seal and fit?
Posted: Sat Apr 20, 2024 10:46 am Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
I just reseated the rubber bungs Eric and Barb gave me a tip about making sure there’s no moulding edges on the rubber the front one wasn’t right so trimmed it and refit it
Seems to be ok at the moment haven’t driven it yet _________________ 1959 Dormobile
Range Rover L322 |
Posted: Sat Apr 20, 2024 4:04 pm Post subject: Re: 1967 - Only Master Cylinder from CIP1 - anyone here use? |
| 66 dormi wrote: |
Seems to be ok at the moment haven’t driven it yet |
OK thanks!
