mfemenel Samba Member
Joined: August 03, 2014 Posts: 292 Location: Matthews, NC
Posted: Sat Mar 08, 2025 4:02 am Post subject: Koni shocks for lowered ghia |
'70 Ghia lowered about 2 inches in the front via beam, not drop spindles. I was trying to decide if I needed the Porsche 356 shocks or the stock recommended shocks both by Koni.
I couldn't find any info on the samba about the stock shocks but I was able to locate the specs on another site.
Leaving it here for comparison in case anyone else crosses this road.
Koni 80-1044SP20
352 mm ->13.86"
243 mm ->9.57"
Koni 80-1787 (stock recommendation)
426mm -> 16.8"
337.82mm -> 13.3 or 10.7 (stopper removed)
I measured my existing shocks this morning at a little over 16 inches (hard to get in and under when it's on the ground). In my case I clearly can just run the stock shocks and be fine.
Currently the price difference is not much either, $144 for the shorter shocks, $135 for the stock (based on amazon comparison)..
Anyway, hope it helps someones research down the road.
I just put Koni's on the rear and look forward to the fronts arriving later this week. I have them on my 79 Westy and they're so comfortable. _________________ '79 Westy FI/AC/Auto
'78 Tin Top FI/Manual
'70 Ghia |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 476 Location: South Bay LA, California
Posted: Sat Mar 08, 2025 5:36 am Post subject: Re: Koni shocks for lowered ghia |
I run the 1787s lowered about 1.5 to 2”.
I removed ~ ¾ inch from the shocks’ bump stops before installing. Seems to have plenty of travel with no bottomming out. |
Posted: Sun May 11, 2025 2:46 am Post subject: Re: Koni shocks for lowered ghia |
Follow up. It took a while to work things out on the front end but all 4 shocks are on now and the ride is AWESOME. Totally worth it. _________________ '79 Westy FI/AC/Auto
'70 Ghia |
dave1 Samba Member
Joined: September 12, 2003 Posts: 527 Location: United Kingdom, London
Posted: Sat May 17, 2025 7:31 am Post subject: Re: Koni shocks for lowered ghia |
Hi Mfemenel,
Can you post a picture of your car to show the stance
Thanks Dave |
Posted: Fri May 23, 2025 6:25 am Post subject: Re: Koni shocks for lowered ghia |
dave1 wrote: |
Hi Mfemenel,
Thanks Dave |
Happy to but may take a bit. It's up on the quickjacks now while I sort out some of the electrical gremlins. _________________ '79 Westy FI/AC/Auto
'70 Ghia |
dave1 Samba Member
Posted: Sat May 24, 2025 9:23 am Post subject: Re: Koni shocks for lowered ghia |
Hi Mfemenel,
Thanks for reply. No rush when ready
Thanks Dave |
