philippe1 Samba Member
Posted: Sat May 24, 2025 12:15 pm Post subject: Benefits of a straight cut camshaft gears gear on à performance |
Hello enthusiast of sport mechanics, Volkswagen and Porsche 356
Porsche 356 which is basically the same as a VV engine. What are the advantages of having a set of Straight cut cam gears?
In terms of performance, is there a gain to be hoped for?
I've heard that noise is increased…
My engine is a 1900cc for street use and I do. It want to have a few hp against tons of decibels!!!
Furthermore it add 400 more grams..
what is your feedback? |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7822 Location: Videbaek Denmark
Posted: Sat May 24, 2025 1:02 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
On a street engine, not worth it.
IF you had an engine which needed hefty dual springs and reved high there would be an idea in going straight cut because it would take a lot odf stress away from the cam bearings. Some tuners claim 1 hp gain @ 6000 due to less friction which may well be true. I believe that is a calculated numberthough, but I do not know.
Some people love the noise from straight cuts, some don´t. I belong to the latter group. I would never use straight cuts unless I had to. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
liquidrush Samba Member
Posted: Sat May 24, 2025 1:15 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
I'm one that likes the mechanical whine they make. Mines in a buggy so to me it sounds great. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79424 Location: Sneaking up behind you
Posted: Sat May 24, 2025 1:24 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
Knock yourself out, i'm sure you won't hear it over the dual cannon exhaust. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
txoval Samba Member
Joined: January 23, 2004 Posts: 3839 Location: The Woodlands, TX
Posted: Sat May 24, 2025 2:51 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
Different brands result in more or less noise.
Straight cuts provide less pressure on cam bearings, whether using regular VW dual springs or something more. To me it’s worth it.
Different gear sizing with the original gears becomes a non-issue.
Loud straight cuts can be annoying, but I still say cruising with the windows down you aren’t going to hear it.
CB Pro Straight Cuts are loud, regular CB straight cuts aren’t |
BFB Samba Member
Posted: Sat May 24, 2025 5:54 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
I use straight cut in every engine unless someone requests otherwise . 1 i like the sound as does 90% of the people ive built for. 2 ive seen too many posts of stripped aluminum and mag gears and straight cuts are reasonably priced especially for the assurance.
And i have yet to find a set that are as loud as the “noisey” geardrive in a SBC i have _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
early Samba Member
Joined: January 19, 2012 Posts: 255 Location: Glen Carbon, IL
Posted: Sun May 25, 2025 8:46 am Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
BFB wrote: |
And i have yet to find a set that are as loud as the “noisey” geardrive in a SBC i have |
Which do you prefer? CB straight cuts or Magnum? Or something else. _________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
WaterBuggy_24 Samba Member
Posted: Sun May 25, 2025 12:20 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
I have aluminum straight cut gears on my 1915cc. I don't even hear them over the exhaust. Maybe a little just above idle. _________________ One day, I may learn.
Probably not today though. |
txoval Samba Member
Posted: Sun May 25, 2025 7:05 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
CB sells two different series
1399 are quiet
1400 are loud |
richparker Samba Member
Joined: November 24, 2011 Posts: 7490 Location: Durango, CO
Posted: Sun May 25, 2025 7:43 pm Post subject: Re: Benefits of a straight cut camshaft gears gear on à performance |
I have the CB 1399 in both of my engines, I can’t hear them at all. Switched over because I had 2 different engines wear the thrust faces of the cam bearings. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
