SolarPoweredPickles Samba Member
Joined: May 13, 2009 Posts: 1260 Location: California
Posted: Thu Jun 12, 2025 3:26 pm Post subject: Is there Asbestos in the heat tube fabric wrap? |
Im replacing my outriggers and cross brace soon and part of my heat tube is roached out, Im not running heat, so either way I have to cut the tube and I'll need to clean up and remove that fiberglass looking fabric, what's in that stuff? Does it contain asbestos? I'll be wear full covers and a mask for sure, but want to be extra cautious.
Thanks all.
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35832 Location: Conejo Valley, CA
Posted: Thu Jun 12, 2025 3:45 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
https://www.google.com/search?q=thesamba.com+asbes...p;ie=UTF-8
Consensus is that the only asbestos was:
(1) sealing collars where the accordions meet the HE and body:
(2) The little flat pieces sealing the heat riser tubes to the rear tin:
_________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Thu Jun 12, 2025 4:04 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Awesome! Thanks. I don't think that collar will be on a 61' bus? Either way I'll rip off the itchy fiberglass first. Fully suited up of course! Then see if there are any of those collars on the metal tubes.
Thanks for the info! |
swharris Samba Member
Joined: September 10, 2010 Posts: 640 Location: N. Orange County
Posted: Thu Jun 12, 2025 4:24 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Early brake shoes definitely had asbestos in them. Most are all long since replaced, but still good practice to wear protection when doing brakes and keep them wet if there is a lot of dust present. |
Posted: Thu Jun 12, 2025 7:33 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Yeah no old brakes here. I do remember reading that old pads used it. Nasty stuff. |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 803 Location: Reno NV
Posted: Thu Jun 12, 2025 8:49 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
just spray it with soapy water and keep damp double bag it in plastic bags and put it in the garbage, It is the dust that is dangerous long term exposure. don't over think it. |
KTPhil  Samba Member
Posted: Fri Jun 13, 2025 7:42 am Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Yep, brake shoes and pads definitely had asbestos! I was just looking at heater system components.
I wouldn't be surprised if there was asbestos insulation in some electrical components, but I've not seen confirmation. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Fri Jun 13, 2025 11:28 am Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Thanks guys! Safety is crazy important, spraying with soapy water is a great idea, I also read wetting the area and garage or driveway, but spray bottle with some dawn sounds easy enough, and a mask.
Thanks for the tips and confirmation!
Posted: Fri Jun 13, 2025 12:59 pm Post subject: Re: Is there Asbestos in the heat tube fabric wrap? |
Asbestos like PCB's and many others are way overblown.
Yes asbestos is dangerous over long term exposure, and a dust storm like the trade centers with out proper face mask and PPE, no a N95 will not work no way to get a proper seal, just use caution but don't go overboard and you will be ok. |
