Vanagon repair shop labor rates?
Page: 1, 2, 3, 4  Next
fknmovin60
fknmovin60 is offline
PostPosted: Thu Jul 17, 2025 9:16 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
What you guys seeing for Vanagon shop labor rates in Florida?
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Jul 17, 2025 10:54 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
not going to help but I'm in CT and at 165/hr for cars up to 10 years old and 190/hr for anything 10 and older IF I take it in. Porsche....well somewhere in the middle of both of those numbers added together
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
fknmovin60
PostPosted: Thu Jul 17, 2025 11:17 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
OK... any more responses?
What you guys seeing for Vanagon shop labor rates in Florida... or anywhere esle... chime in.
Abscate
Abscate is offline
PostPosted: Thu Jul 17, 2025 4:21 pm    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
Just go to any local Midas muffler shop. Look at the labour rate and add50%
E1
E1 is offline
PostPosted: Thu Jul 17, 2025 4:26 pm    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
$145/hour in Durango, CO, including their paying about as high of shop rent as anywhere in Colorado.
If ever twice as rich, weโ€™re gettinโ€™ a double-wide
โ€™84 โ€œWestfailureโ€/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
SCM
SCM is offline
PostPosted: Thu Jul 17, 2025 7:36 pm    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
You might want to make a new thread with โ€œFloridaโ€ in the title so other folks in that state know to check in. Iโ€™m guessing thereโ€™s only a small number of Floridians here and they may not be clicking on this thread.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
fknmovin60
PostPosted: Fri Jul 18, 2025 10:28 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
"What you guys seeing for Vanagon shop labor rates in Florida... or anywhere esle... chime in
DanHoug
DanHoug is offline
PostPosted: Fri Jul 18, 2025 11:43 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
not being snarky but are you rate shopping mechanics? because that is the wrong criteria for having someone work on a vintage vehicle. find a shop that knows what they are doing, is willing to work on your van, and their rate is what it is. if you DO find that shop, even if the rate is $200/hr, it could be far less expensive than an inexperienced shop hunting and pecking around for $95/hr but wasting many hours trying to find/fix the problem.
also, high shop rates do not always equate to high quality work. so again, it gets back to that the shop *rate* is the wrong criteria but it is the shop itself that should guide your spending on an older vehicle.
-dan
www.thefixitworkshop.com
kamzcab86
kamzcab86 is offline
PostPosted: Fri Jul 18, 2025 12:55 pm    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
Done. The prior thread was about shops no longer working on vans, not specifically about labor rates.
As to the OP's question, can't answer as my van hasn't seen the inside of a shop in a long while.
2016 Golf GTI S
"Real knowledge is to know the extent of one's ignorance." - ๅญ”ๅญ
mikemtnbike
mikemtnbike is offline
PostPosted: Fri Jul 18, 2025 1:23 pm    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
Quoted for emphasis. I have no idea what the shop I use when I have to charges per hour- it might be on the receipt, but I haven't paid attention. I do know I have been happy with their work and prices on both my old vanagon and my current eurovan.
2020 GTI SE manual
MarkWard
MarkWard is offline
PostPosted: Fri Jul 18, 2025 1:35 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
$160 hour Palm Beach County. Straight time, no flat rate. Mainly supporting existing customers. We have found it is not profitable taking in unknown to us classics.
blyhigh
blyhigh is offline
PostPosted: Fri Jul 18, 2025 2:01 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
FWIW - Just had my snapped in half alternator pivot bolt replaced in Benton, AR. Shop rate was $130.
'89 Syncro Westy
zerotofifty
zerotofifty is offline
PostPosted: Fri Jul 18, 2025 2:12 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
What they charge you for the snapped bolt repair?
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Westified
Westified is offline
PostPosted: Fri Jul 18, 2025 3:38 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
In Miami my mechanic for my Vanagon Westy is charging $175.00/hr but told me he is going up to $230/hr. I said WHAT. He does know my Vanagon and had previously worked on Vanagons when he was at a VW dealer. He has had his own shop for years. I think I got sticker shock on the time he charged for removing and replacing my windows for a windows out paint job. I did put in Jalousie windows on the center windows and I helped hiim. I also put sliders in the rear quarter windows. I also thought my paiint job was a bit pricey. Not sure these vans are worth it anymore. I see a lot of people selling.
1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022.
raygreenwood
raygreenwood is offline
PostPosted: Fri Jul 18, 2025 4:33 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
So.....what did your point job Cost?
Paint jobs are astronomically higher now than they were 20 years ago. It's a combination of the cost for paint and solvents, air quality fees in certain states, disposal fees....and high labor costs because less and less people can be find that knkw how to paint.
Ray
Westified
PostPosted: Fri Jul 18, 2025 4:50 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
Paint job cost $13,900. My van is brown and tan two tone. They did replace the right rear fender, which requires a little tack welding.. I purchased the parts needed which was an additional expense.. Window removal and install plus powder coat the handles by my Mechanic cost $3,700.
raygreenwood
PostPosted: Fri Jul 18, 2025 5:25 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
The window removal install sounds....a little pricey. Just labor right? About 8 windows? Then again....$175 an hour is 21 hours. Powder coat aside, that's 1.3 hours each for removal and and 1.3 hours each for install. Some take longer than others. That's not bad.
$14k for a two-tone? .....two tone runs more than a single color. A bus/van....lots more paint and work. $10-$11k for a GOOD single color paint job from my research for a larger vehicle.
Good quality work with good quality paint ($400-700 a gallon) for a mid to large size car these days is $5-7k.
Ray
Edit: i guess the real question is how good is the paint job. If it's factory or better....you got a good deal.
Westified
PostPosted: Fri Jul 18, 2025 6:52 pm    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
I wouldnโ€™t call it a factory paint job, at least not like my original VW paint. Factory paint today isnโ€™t as good as the past, except for the rust proofing. This shop is a very high end paint shop. They specialize in Corvettes and are also working on restoring a Jaguar XKE. They have been in business for about 30 years which is saying something in Miami. Most shops here just want collision work with insurance payments. They did do a nice job and tried hard to please me and my mechanic who is very picky. Also, the cost of living in Miami is very high. It is getting expensive to maintain these old Vans. There arenโ€™t many Vanagons in Miami.
fknmovin60
PostPosted: Sat Jul 19, 2025 1:34 am    Post subject: Re: Vanagon repair shop labor rates? Reply with quote
Westified wrote:
In Miami my mechanic for my Vanagon Westy is charging $175.00/hr but told me he is going up to $230/hr. .... previously worked on Vanagons when he was at a VW dealer.
$230 per hour for a VW dealer tech to work on your Westy is high?...sounds like a good deal.
"Miami's cost of living being 21% higher than the national average"
and he is increasing his rate by about 25% to keep up with increased costs
Eat some humble pie, and be thankful, that he is still wiling to work on it for that price.
He must be doing good work, correct?
So, he removed all of your windows, for you to get a good paint job, and reinstalled all of the glass with the old seals, or did he put new ones in? The front door seals can be a real pain, especially the vent window seals
How did the Jalousie window install go...how good is their fit?
Did you install the sliders or did he... the cabinet window is a real bear of a job, let alone aftermarket sliding windows...they are a tad bit big
Abscate
Abscate is offline
PostPosted: Sat Jul 19, 2025 1:37 am    Post subject: Re: One less Vanagon mechanic (soon) Reply with quote
And grump Volvo owners like me pay $335 but he did give me a $20 discount for having a 1999 p80
Page 1 of 4
