69911e Samba Member
Posted: Tue May 08, 2007 2:31 pm Post subject: |
The bracket is thick, mild steel so it is fine to bend without weakening it. The weakest point is the entire firewall which is just as weak as the original center mount for the lap belt. So, at the very least it should be as strong or stonger than original because the load is now distributed over 3 point instead of 2.
Than being said, I am in no legally binding way stating this is a safe modification, only that I have done it. As with all things you find on the internet use your own judgement. _________________ '78 super conv. - project with my kids (3&6)
'69 911E daily driver + AutoX car
'71 1800E wife's weekend car |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4610 Location: Central Maryland
Posted: Mon May 07, 2007 6:05 pm Post subject: |
I'd be a little concerned that bending the bracket would weaken it. _________________ Mike
‘74 bug vert
Parts... |
69911e Samba Member
Posted: Mon May 07, 2007 5:03 pm Post subject: |
Here are the pics.
The belts should be placed on the side of the seat for small children just above the seat back latch mechanism. This places the belts in the correct position.
The bracket went right into the existing threads which were covered by a plastic plug. The bracket needed to be bent at a right angle.
This pic is to demo how I will modify this when the kids are bigger. I plan on adding a headrest when needed with a padded spaced (shown here by the 2 x4 ). the spacer will position the belt to avoid a downward angle which could cause shoulder compression. The headrest supports will have a secondary function of postioning the seatbelt strap near the edge of the seatback. _________________ '78 super conv. - project with my kids (3&6)
MIKE+4 Samba Member
Joined: July 30, 2006 Posts: 28 Location: NEW ALBANY INDIANA
Posted: Mon May 07, 2007 12:53 pm Post subject: vert seat belts |
| Ed would you please send the pictures? Im wanting to put 3 points in the rear of my 73 vert. Thanks Mike. |
69911e Samba Member
Posted: Fri May 04, 2007 11:29 am Post subject: |
Yes, it works fine. I needed belts for my kids (3&6), so the desired angle is different than an adult. The angle would not be suitable for a tall person whose shoulders were significantly above the seat back. I did it using the attachments on the firewall with non-retractable belts from BugCity ($60 for the pair). It required bending the rear attactment assembly of the belts to a right angle. Let me know if you would like pics.
Ed _________________ '78 super conv. - project with my kids (3&6)
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
Posted: Sat Mar 03, 2007 8:05 am Post subject: |
| 69911e wrote: |
| I was looking at using the threaded holes which exist holding up the rear panel carpet. These threads look to have the same reinforcement the seat belts have (I need to double check this), so they should be strong enough. |
Did you have any luck with that? I would like to install 3-point seat belts in the rear of my convertible, too. _________________ 1978 Super Beetle Convertible (Project)
Post a Photo in the Forums
Rescue Man's Best Friend |
69911e Samba Member
Posted: Sat Jan 20, 2007 12:38 pm Post subject: |
The top I have is trashed so I can't check clearence with the top mechanism down accurately. I plan on using the plastic window top without the headliner or padding so I may have a little more room than a conventional top.
Has any one try ever tried this approach?
VW Vet Samba Member
Posted: Fri Jan 19, 2007 11:18 pm Post subject: |
Is this part of what you need to know?:
As the shoulder harness leaves the shoulder and goes aft, it should be no more than 5 degrees below or 30 degrees above the shoulder. Not exceeding 5 degrees below is the most important one to observe. |
WolvenGoth Samba Member
Joined: July 12, 2006 Posts: 403 Location: Memphis, TN
Posted: Fri Jan 19, 2007 10:44 pm Post subject: Re: 3 point rear seatbelts for convertible |
| ach60 wrote: |
| Are we talking front or rear? |
| 69911e wrote: |
| I have read a few post looking for information about 3 point rear seat belts in a convertible |
_________________ --WolvenGoth
1972 Beetle Automatic Stickshift (LuLuBell)
1976 Beetle (Herman) New Daily Driver
VW's. Betcha can't own just one! |
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Fri Jan 19, 2007 7:31 pm Post subject: |
Are we talking front or rear? _________________ Good Luck
Al |
Posted: Fri Jan 19, 2007 7:24 pm Post subject: |
Good luck finding info on this, I've been unsuccessful as well. I think the upper mount or belt travel would be blocked by the top mechanism. _________________ Mike
‘74 bug vert
Parts... |
69911e Samba Member
Posted: Fri Jan 19, 2007 9:24 am Post subject: 3 point rear seatbelts for convertible |
I have read a few post looking for information about 3 point rear seat belts in a convertible, but not anyone posting they have actually done this. Does anyone have pics or a description of a completed install?
Thanks
