Checking fuel pressure correctly
bill may
bill may is offline
PostPosted: Thu Dec 31, 2009 5:55 am    Post subject: Reply with quote
Last time I checked mine, I got a more steady reading when it was not at idle.
correct.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
PostPosted: Wed Dec 30, 2009 7:28 pm    Post subject: Reply with quote
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Dec 30, 2009 4:02 pm    Post subject: Reply with quote
I think he got that 3000RPM spec because that is what you see in the big blue Bentley - maximum of 2.8 PSI at 3000 RPM. ( and I like that spec a lot better than the 3-5 PSI at 4000RPM that you see in the 70-79 Bentley! ) Still, a lower speed reading should be fine, but it does need to be faster than starter cranking speed.
drscope
drscope is offline
PostPosted: Tue Dec 29, 2009 4:58 pm    Post subject: Reply with quote
You should start the engine and let it idle. No need to run the rpm's up.
Just be aware, you will see fluctuation in the pressure as the needle valve opens and shuts
TurkTurk
TurkTurk is offline
PostPosted: Tue Dec 29, 2009 3:17 pm    Post subject: Checking fuel pressure correctly Reply with quote
I need to check my fuel pressure and have a gauge that reads 0-5 psi. I have it installed with a T-fitting between the pump and carb.
My question is: can I check the pressure just by cranking the engine a few times or do I need to check pressure my starting the engine, running it at 3000 rpm, and checking the pressure there?
Thanks
