Basic Questions...what do you guys run?
lowslowauto
lowslowauto is offline
PostPosted: Tue Jun 21, 2011 6:15 pm    Post subject: Reply with quote
Thanks for all of the help!
I ended up putting quaker state high mileage, and have notice a difference already in sound and performance....
Thanks again!
It's air filter/oil bath attention time! Smile
presidential
presidential is offline
PostPosted: Fri Jun 17, 2011 5:13 am    Post subject: Reply with quote
FastyinaField wrote:
Zinc helps reduce wear on flat-tappet cams. I'm not sure how important it is because a lot of modern engines use aluminum cam followers, and they don't get smoked using low-zinc oil. Roller cam engines don't care what you run.
Well, I've noticed Rotella makes a decent difference in high-mileage modern cars as well. Ran it in my smokey, 380,000 mile Nissan for a bit and it helped it out by leaps and bounds. I knew the valve guides were shot and it cut the smoke show down to a minor puff after a few oil changes. Oil consumption was down as well.
~Craig
2007 Husky Sled dog
FastyinaField
FastyinaField is offline
PostPosted: Fri Jun 17, 2011 12:31 am    Post subject: Reply with quote
lowslowauto
PostPosted: Thu Jun 16, 2011 11:04 pm    Post subject: Reply with quote
pardon the ingorance but why is the higher zinc content oil a better option?
Brent
Brent is offline
PostPosted: Wed Jun 15, 2011 9:07 pm    Post subject: Reply with quote
I just bought a set of the NGK plugs for my build. I don't think the old Bosch ones are available anymore other than NOS. The new ones have a resistor in them. Not sure how it affects performance.
vdubin
vdubin is offline
PostPosted: Wed Jun 15, 2011 7:48 pm    Post subject: Reply with quote
I use mobil 10-30 and bosch plugs and wires.
Notchback65
Notchback65 is offline
PostPosted: Wed Jun 15, 2011 10:35 am    Post subject: Reply with quote
I use Rotella
'65 Notchback
dLK
www.dlkweb.org
luckystiff
luckystiff is offline
PostPosted: Wed Jun 15, 2011 10:22 am    Post subject: Reply with quote
don't get me wrong it's still better than most conventional oils but not as good as it was a few years ago. trust me i was die hard rotella for many years. when they changed the content i hit every local spot i could an bought up the old higher content version. vr-1 has higher content and i see it on sale for $4(usually $5ish) or so a quart every so often...ken....
ITMC
Secret Service
OhHerrooo
OhHerrooo is offline
PostPosted: Wed Jun 15, 2011 10:15 am    Post subject: Reply with quote
chaosisme wrote:
luckystiff wrote:
you guys know they changed the Rotella formula a few years ago and it's not the same high zinc content anymore right?
the closest i've found now is delvac. i've been using valvoline vr-1 racing oil recently. if brad penn were stocked some where local i'd probably try it but i've heard nearly as good a feed back on the vr-1.
NGK have been my favorite plugs for a while.
and Bosch wires...ken...
I had heard that, but from what I read it still has higher zinc levels than other conventional oils.
i'm still running rotella T as well. NGK plugs and bosch wires.
'67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com
chaosisme
chaosisme is offline
PostPosted: Wed Jun 15, 2011 9:59 am    Post subject: Reply with quote
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
presidential
PostPosted: Wed Jun 15, 2011 9:03 am    Post subject: Reply with quote
It's not as high zinc content but still acceptable for me.
~Craig
2007 Husky Sled dog
luckystiff
PostPosted: Wed Jun 15, 2011 6:13 am    Post subject: Reply with quote
ITMC
Secret Service
presidential
PostPosted: Wed Jun 15, 2011 5:21 am    Post subject: Reply with quote
Rotella or Castrol GTX high mileage here. I'd recommend Rotella in anything higher mileage, it works wonders.
~Craig
2007 Husky Sled dog
chaosisme
PostPosted: Tue Jun 14, 2011 9:11 pm    Post subject: Reply with quote
In my square I use Shell Rotella T 15W40. For plugs I use the stock Bosch stuff, dont know what the part number is for the wires, plugs are WR8AC.
Ive heard the NGK's are good. Use this to figure out what you need if you run them.
http://www.spark-plugs.co.uk/pages/technical/boschw5a-y6dc.htm
Oil filter? Whats that?
Again this is just what I run, you might find you need to run something else. I noticed you are up north, so maybe you might want to run a lighter vicosity oil?
'70 Westy
lowslowauto
PostPosted: Tue Jun 14, 2011 9:04 pm    Post subject: Basic Questions...what do you guys run? Reply with quote
What do you guys recommend for oil, oil weight?
plugs?
wires?
Anything else you would recommend for a yearly tune up!
This is for a 73 fuel injected fastback.
TIA
lol put oil filter in the last one...lmao. Its been a LONG week so far
