40 horse's of fury
joebug1956
joebug1956 is offline
PostPosted: Thu Sep 15, 2011 6:56 pm    Post subject: Reply with quote
Here is a video of the motor running:
joebug1956
PostPosted: Sun Sep 11, 2011 6:12 pm    Post subject: Reply with quote
Thanks for the pistons! Got it all back together and put about 70 miles on the car today!
Got the valve seat re ground replaced all the exhaust valves and springs. Replaced the cracked piston and rod also. Finally got to drive this pile today and it was great! Been a long time !!!!!!
This morning:
VIDEO:
VIDEO:
RockCrusher
RockCrusher is offline
PostPosted: Sun Sep 11, 2011 9:06 am    Post subject: Reply with quote
Yep....the spring was the root of the failure....that sucks. Don't get time to come to the vintage forum too much but your thread caught my eye. Just not much call for vintage work in our area or I'd be doing more of it if I could.
Hope you can grab some new or NOS springs for that thing so you don't have a repeat performance. Sound like someone stuck a twig in the fan before it broke the head off? That was my experience with a broken spring before. Anyway...good luck and glad you found some new pistons.
RC
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
joebug1956
PostPosted: Thu Sep 08, 2011 5:43 pm    Post subject: Reply with quote
joebug1956
PostPosted: Wed Sep 07, 2011 4:54 am    Post subject: Reply with quote
Whoever built the motor used all new stuff except the springs. The valve springs had some minor pitting in them and looked to have been used. I'm thinking the spring broke, rocker arm pushed the valve in and had no way to return itself to the seat. After a few times of smacking the piston the valve broke, and was then wedged between the head and the piston.
Jacks
Jacks is offline
PostPosted: Tue Sep 06, 2011 9:44 pm    Post subject: Reply with quote
I wonder the same thing. How does a rebuilt engine with "new valves..." have a valve "head" break loose in the cylinder and imbed itself half way through the piston in 10 minutes of running???
64vdub
64vdub is offline
PostPosted: Tue Sep 06, 2011 2:32 pm    Post subject: Reply with quote
What was the problem? Deck height too close? Connecting rod come apart? Just wondering cause I'm building a very similar setup right now.
64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money Smile
GO SF GIANTS!
joebug1956
PostPosted: Tue Sep 06, 2011 3:45 am    Post subject: Reply with quote
got some pistons on the way. Should be running by the weekend.
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Sep 06, 2011 12:56 am    Post subject: Reply with quote
joebug1956 wrote:
rezidu wrote:
Damn Joe.....that sucks! Get that junk fixed.
Got a set of 83 mm big bore pistons laying around? Haha
Mr Motorhead is the Big Bore expert around here...he'll have some. Smile
John.
joebug1956
PostPosted: Mon Sep 05, 2011 2:30 pm    Post subject: Reply with quote
rezidu
rezidu is offline
PostPosted: Sun Sep 04, 2011 5:19 pm    Post subject: Reply with quote
joebug1956
PostPosted: Sun Sep 04, 2011 3:47 pm    Post subject: Reply with quote
Got the motor timed, and carbs sync'd. Ran nice for about 10 minutes then locked up. Tore it down today to find the head of #4 exhaust valve halfway through the piston.
Jake Martinez
The VW Kid
Jake Martinez is offline
PostPosted: Wed Aug 31, 2011 9:40 am    Post subject: Reply with quote
some others that are more http://www.thesamba.com/vw/classifieds/detail.php?id=902878
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
zombie wrote:
buslife wrote:
10 inch narrowed beam
Congrats, that's going to look like shit.
PostPosted: Wed Aug 31, 2011 7:52 am    Post subject: Reply with quote
WW sell the elbows, not cheap though: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111129615OK
John.
WesleyGarrard
WesleyGarrard is offline
PostPosted: Wed Aug 31, 2011 7:22 am    Post subject: Reply with quote
Weren't they just some ghia elbows? The Australian setup you may be thinking of were actually curved intakes using side draft carbs. These used a regular thin line air cleaner.
joebug1956
PostPosted: Wed Aug 31, 2011 5:41 am    Post subject: Reply with quote
Jake: Im trying like hell to get it done for bugout! Gonna be some late nights this week! I like the filter ideas, I have been debating getting the old school style elbows from an austrailian carb setup i've seen. Cant remember the name of them though.
didget69
didget69 is offline
PostPosted: Tue Aug 30, 2011 4:24 pm    Post subject: Reply with quote
skyto wrote:
didget69 wrote:
Nice build!
Have you considered finding a pair of period filter housings that would allow you to run modern filter medium, be it K&N or similar?
bnc
here's one solution to this - link
Very nice solution! And it carries a period look...
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
skyto
skyto is offline
PostPosted: Tue Aug 30, 2011 1:30 am    Post subject: Reply with quote
didget69 wrote:
Nice build!
bnc
didget69
didget69 is offline
PostPosted: Mon Aug 29, 2011 6:02 pm    Post subject: Reply with quote
Nice build!
But don't ruin the engine by running simple mesh 'airfilters'. Those screens are only used to keep the engine from inhaling rocks, squirrels, and small children, NOT for filtering sand, silt, and larger micron abrasive particles from the air.
Have you considered finding a pair of period filter housings that would allow you to run modern filter medium, be it K&N or similar? Maybe a pair of early Mann or Knecht filters from a 356, or modified oil bath filters from a 36 or 40 horse motor that have more performance-oriented filtering medium inside - with the airhorns/velocity stacks hidden inside.
bnc
Jake Martinez
The VW Kid
PostPosted: Mon Aug 29, 2011 5:04 pm    Post subject: Reply with quote
will this be at bugout? i woul like to take some pics of it for my senior project.
58 euro vert
63 bug ruby
64 sunroof notch
65 bug
67 standard
