Mallory unilite w/ vac and FI?
type11969
type11969 is offline
PostPosted: Sat Nov 23, 2013 3:04 pm    Post subject: Reply with quote
Phil-
Thanks. The challenge is fitting the vac can next to the cold start valve used on the stock FI . . . but I think I may be able to weasel it in the way you have it. Good to know you can dial the timing in with the dist in that position.
-Chris
1969 VW Beetle - t4ed indeed
1971 Porsche 914 - jackstanded
1976 Westy - DD
whip618
whip618 is offline
PostPosted: Fri Nov 22, 2013 7:00 pm    Post subject: Reply with quote
This is on a dual carbed type IV 2.0 but i had to reindex the drive gear to get mine to work.
Phil
Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307
type11969
PostPosted: Fri Nov 22, 2013 11:15 am    Post subject: Reply with quote
Yeah, I'm assuming the plug wires will go where they need to (reindexed) in order to get everything to fit - assuming it can to begin with.
-Chris
1976 Westy - DD
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Nov 22, 2013 9:06 am    Post subject: Re: Mallory unilite w/ vac and FI? Reply with quote
type11969 wrote:
Anyone running stock FI with a vac advance Mallory? If so, how did you get the can to clear the CSV, maintain enough sweep to dial in timing, etc. Did you have to dent the tin around the dist or? It's close, but I'm not seeing a way around some hammering - and I'd like another way.
Thanks,
Chris
I don't know the setup, but could you reindex the drive gear?
www.airschooled.com
type11969
PostPosted: Thu Nov 21, 2013 8:25 pm    Post subject: Mallory unilite w/ vac and FI? Reply with quote
Thanks,
Chris
1976 Westy - DD
