Westfalia trailer hitch conversion
highsierra
highsierra is offline
PostPosted: Sat Mar 12, 2016 7:17 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
Depending on how much weight you plan to carry you may want to consider air shocks. They were just the ticket for me carrying a 300 lb dirtbike.
http://www.thesamba.com/vw/forum/viewtopic.php?t=407359
Welcome to the Insanity!
walkingupstream
walkingupstream is offline
PostPosted: Sat Mar 12, 2016 6:47 pm    Post subject: Re: Westfalia trailer hitch conversionlly Reply with quote
Hi. I've been seeking advice on a hitch for my van as well.
10 minutes ago I just bought the bullet on a Burley Motorsports hitch.
I really just want to be able to use my 3 bike rack, but the center mount on the GoWesty won't work with my Subie conversion (and your diesel too, I think) and folks tell me there's a bit of sway and instability without that center mount.
I could have saved an extra $250 and tried the GoWesty or done something like you're trying to do, but in the end I figure the extra $250 is worth the security of a stout hitch with the benefit of being able to tow whatever I might want to tow in the future. This, and the fact that the Burley hitch sits a bit higher and will avert the potential clearance issue on my sloped driveway entry.
Hope this helps.
Cass
highsierra
PostPosted: Sat Mar 12, 2016 6:28 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
I also recommend a Burley hitch
Wolfram
Wolfram is offline
PostPosted: Sat Mar 12, 2016 6:25 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
We have a Burley and use it to carry a cargo tray. It's solid, well built and easy to install.
Geoff
Waiheke Island
New Zealand
88 Westy.
88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage.
fxr
fxr is offline
PostPosted: Sat Mar 12, 2016 5:31 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
If you want to carry heavier loads on the back, I can personally recommend the Burley heavy duty receiver hitch.
http://burleysmotorsports.com/index.php?main_page=product_info&cPath=25_14&products_id=55
Jim Crowther
Vespa GTS 300
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Mar 12, 2016 4:26 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
I definitely don't recommend that type of tow hook style of hitch to be used with vertical loads
Casey--
'01 Weekender --> full camper
y u rune klassik?
davevickery
davevickery is offline
PostPosted: Sat Mar 12, 2016 4:21 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
http://www.harborfreight.com/atv-hitch-adapter-65961.html
nickgiles101
nickgiles101 is offline
PostPosted: Sat Mar 12, 2016 4:16 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
This is the hitch we have now.
Zeitgeist 13
PostPosted: Sat Mar 12, 2016 3:23 pm    Post subject: Re: Westfalia trailer hitch conversion Reply with quote
We need to see what kind of hitch you have. I converted a regular ball hitch over to a 1.25" receiver hitch. If it attaches to the tow hooks, then I don't recommend that approach
Casey--
y u rune klassik?
nickgiles101
PostPosted: Sat Mar 12, 2016 3:12 pm    Post subject: Westfalia trailer hitch conversion Reply with quote
My wife and I just bought an 82' Westfalia with a 1.9L diesel engine. It came with a hitch but not a receiver. We would like to use our Curt basket cargo carrier for extra storage. Is there a conversion kit, an easy modification or new hitch set-up that will work? GoWesty has a receiver hitch set up but it will not work on a diesel. Thought and wisdom please!
Thank you!
