Aftermarket tachometer questions.
DoubleOSeven
DoubleOSeven is offline
PostPosted: Thu Apr 04, 2019 7:17 am    Post subject: Re: Aftermarket tachometer questions. Reply with quote
Brickwerks sell these nice pods LHD & RHD for early vans needing rev counters or for any other 52mm gauge for that matter.
Wire up to front from coil neg -
cs44
cs44 is offline
PostPosted: Wed Apr 03, 2019 8:32 pm    Post subject: Re: Aftermarket tachometer questions. Reply with quote
shwokagon wrote:
Did you get the tach installed? I have an '84 too and I'd like to do the same
Heh, a year and a half later -- no.
Never made the time and just stumbling back onto the forums.
Did you get your tach installed?
shwokagon
shwokagon is offline
PostPosted: Sat Sep 02, 2017 8:57 am    Post subject: Re: Aftermarket tachometer questions. Reply with quote
'84 Vanagon 1.9 7-Passenger
'85 Cabriolet Convertible
cs44
cs44 is offline
PostPosted: Sat Jul 22, 2017 7:20 am    Post subject: Re: Aftermarket tachometer questions. Reply with quote
ALIKA T3 wrote:
yes green arrow goes to dash for tachometer.
Nice!
I've yet to peek under the dash, any chance you know where I'll find it?
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Jul 21, 2017 9:34 pm    Post subject: Re: Aftermarket tachometer questions. Reply with quote
cs44 wrote:
Van: 1984, no tach.
Issue: I'm looking to install an aftermarket tach, specifically the Auto Meter 2306. I'm under the impression that vans *with* factory tach installed, are associated with a green wire running from the coil to the dashboard.
Questions:
1) Is the green arrow below pointing to said wire? Or is that headed elsewhere?
2) With regards to the blue arrow, how does one generally make a connection to the coil, given the large plastic connector in place?
As always, thank you!
My coil:
Tach diagram:
You can unscrew the spade connector from the coil and add another one to make some kind of dual connector with 2 wires.Some coils are equipped like that.
cs44
cs44 is offline
PostPosted: Fri Jul 21, 2017 3:51 pm    Post subject: Aftermarket tachometer questions. Reply with quote
Van: 1984, no tach.
Questions:
My coil:
Tach diagram:
