how does that look when finished ?
57BLITZ
57BLITZ is offline
PostPosted: Wed Sep 05, 2018 11:49 am    Post subject: Re: how does that look when finished ? Reply with quote
Glad it helps!
BTW . . . FYI . . . your repair panel is a one-size-fits-all kinda deal . . . It has an extra fender bolt hole . . . the bottom hole is for early models (like on my '62) . . . your 1969 lower-most fender bolt (should) go through the second hole from the bottom . . .
Darkbrador wrote:
Jesucristo es mi Señor y Salvador!
Darkbrador
Darkbrador is offline
PostPosted: Wed Sep 05, 2018 11:28 am    Post subject: Re: how does that look when finished ? Reply with quote
Excellent, thanks Blitz !
57BLITZ
57BLITZ is offline
PostPosted: Wed Sep 05, 2018 11:19 am    Post subject: Re: how does that look when finished ? Reply with quote
Darkbrador wrote:
. . . question regarding the rear right wheel area on my 69 std beetle :
What does the area look like when all the pieces are fitted together ?
hoping you can hold this up to a mirror because these photos are of the left side . . . hope it will help ya . . . I'm guessing the last one is what yer asking for . . .
theKbStockpiler
theKbStockpiler is offline
PostPosted: Tue Sep 04, 2018 2:54 pm    Post subject: Re: how does that look when finished ? Reply with quote
I can't tell exactly what you are referring to.
It looks like you are doing butt and overlap joints with the same panel so it's not going to be flush like the original. I can't tell if it will make a noticeable difference or not though.
I think that quarter panel patch piece has part of the running board mount on it. Are you planning on notching out the running board mount so they don't overlap?
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
Darkbrador
PostPosted: Tue Sep 04, 2018 9:24 am    Post subject: how does that look when finished ? Reply with quote
Hi folks,
I have a question regarding the rear right wheel area on my 69 std beetle : I'm replacing the rear cross-member, inside fender/wheel well area, and quarter panel, along a new heater channel that's already in place. The body in this area was pretty much all gone, a few rusty sheets and lots of holes, so I don't have much reference... When I try-fit the parts together, it seems there is a few gaps in there/
What does the area look like when all the pieces are fitted together ? Looking from the point of view of the yellow arrow in the pic attached ...
Thanks !
