Snap Placement Into 1967 Ghia Convertible Top Chrome Trim
RCTScott
RCTScott is offline
PostPosted: Sun Nov 03, 2019 10:19 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Wow, that tiny little tip made a huge difference. This is as far as I could pull it, but the whole section lays nicely now. Fantastic attention to detail Nicholas! Thank you!
sputnick60
sputnick60 is offline
PostPosted: Fri Nov 01, 2019 1:00 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Nice work Scott.
I have a suggestion for improvement. The trim over the lock channel top should be under bottom edge of the roof fabric. By removing the bull nose screw and slipping the fabric in there so it is sandwiched between rather than the trim it can be remedied. These next two shots of my car just catch that detail so you can compare with your car.
Overall, your roof looks nice and tight and stretched in properly. Leave it up over winter so it settles into shape over the next few months
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
RCTScott
RCTScott is offline
PostPosted: Thu Oct 31, 2019 10:18 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Well, this chrome trim and snap placement has been a journey. I had already known that the shop that installed my top used a composite bow at the rear of my convertible top and not a wooden bow like I had asked. I know it was not ideal and they had lots of excuses, but we ended up trying to make the best of it as he is a friend. Most of you probably already know this, but for those who don't, the nails that hold in the chrome trim pull out of the composite material very easily. Literally when bending and forming one end of the trim, the nails were popping up at the other end. Ugh. So as opposed to making the shop remove the top and replace it with a wooden bow, I decided to think outside the box. My thought was to use 1" screws to hold the boot snaps in place, as opposed to the typical 3/8" screws. That way, the screws would now pass through the chrome trim and screw into the composite bow, which does hold easily in the composite material. So the screw were double purposed as they now hold both the trim and snaps in place, as opposed to the typical depth where they would only screw into the chrome trim. This worked beautifully.
I had to make one tiny addition that most people would either not catch nor care. I had to add one extra snap, directly through the center cover clip to assure that the chrome trim was held in place there. It also seems to balance out the boot as well. So in the end, I don't think anyone will notice that there is an extra snap and in all actuality, it kind of looks appropriate anyway. Either way, everything holds really well now.
One other not so well known part that I used here is the saddle washers that rcooled had 3D scanned. These saddle washers allow the flat underside of the snap to have a more balanced support and resist the lateral forces when the snaps are under a load. So this is yet another amazing part that rcooled had 3D scanned so we can now have a part that nobody manufactures. Just send the 3D file to Shapewise or any other 3D printing company online if you don't have access to a 3D printer, which now even most local libraries have these and can print them for pennies. It worked incredibly well.
Here are some images of the saddle washers:
And here are some images of the snaps installed. Please note the extra snap in the middle which is not necessary nor per original if you are using a wooden bow:
I hope that these tips help.
Scott
RCTScott
RCTScott is offline
PostPosted: Wed May 22, 2019 11:24 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
The KGPR trim came and I thought it would be nice to show the differences between the KGPR trim and the Chuck's Convertible Parts trim.
First, here is the KGPR trim with the correct screw:
Now here is a comparisson between the KGPR trim (top with the screw) and the Chuck's Convertible Parts trim:
I hope that this helps anyone in the future that might be looking at this trim.
Scott
RCTScott
RCTScott is offline
PostPosted: Wed May 22, 2019 10:46 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Update on the screw to hold the bull-nose down. These two pictures confirm that 2,9 X 16 means 2.9mm X 16mm screw. You all probably knew that, but maybe some readers in the future will be like myself and not realize the obvious translation.
sputnick60
PostPosted: Mon May 20, 2019 3:42 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
The awl is used to make a path through the fabric past the metal edge and into the wood. With a guide hole made thus the nail can be inserted with confidence knowing it will hold in the right position before being hammered in fully.
I made each hole like that and removing the awl was just a matter of gripping it with pliers or vise grips and twisting it out
Nicholas
RCTScott
RCTScott is offline
PostPosted: Sun May 19, 2019 8:00 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
sputnick60 wrote:
This hole accepts the dome top stainless philips screw at the bullnose of the chrome trim that’s been the subject of this discussion.
I have now ordered the chrome trim from KGPR (thank you Rcooled) as their trim DOES have the countersunk hole in the end per original, where others did not. They do not supply the screw you describe above. Any idea about the specific size for this screw? In searching through Nemigaparts.com to find the parts catalog for the Ghia, they list the screw here and describe it as:
https://nemigaparts.com/cat_spares/etka/volkswagen/ghia/38u/026000
"oval hd. csk. self-tapp. screw 2,9X16"
Is it correct to assume that they mean 2.9mm X 16mm self tapping screw?
It is also listed in the second photo from the Parts Book at the top of the thread as item #8, but since I don't have an original parts book I looked at the nemigaparts.com.
If you have a link to this screw, that would be great, otherwise I am off to see if I can find one at Home Depot or search online.
sputnick60 wrote:
You might use the awl progressively rather than doing all the holes in one shot. You might find the nails need to go in a slightly different place than determined by the template, if so, it’s probably best to let that occur but clear the way with the awl so the nail has a start past the body metal and into he tack bow.
Bon chance.
Nicholas
Is the awl just to penetrate through the fabric, or are you using it also to start or pre-drill the hole in the wood? When I searched online regarding how to use an awl, it was usually depicted as a tool to make a hole in fabric, which obviously makes perfect sense here.
Just making sure I have all the parts in order, and a clear understanding before I start.
Thank you!
Scott
rcooled
rcooled is offline
PostPosted: Tue May 14, 2019 11:25 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
RCTScott wrote:
What is the distance from the one body snap to the inset screw at the bull-nose of the chrome trim?
Measured in a straight line, that distance is exactly 14 3/4".
Great info there sputnick60...thanks.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
sputnick60
PostPosted: Tue May 14, 2019 7:21 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
KGCoupe wrote:
I can't help but wonder if there was a very good reason that Karmann made the mounting location switch, as they weren't really known to make changes just for the sake of change or style.
Do you suppose that the pressure necessary to get the boot snaps to properly mate with the snaps mounted to the car would be enough to eventually deform that chrome trim?
I think bthe change occurred in ‘67 because of the revised mounting method.
The 67 model year introduces the folded edge of metal for the support wire in the bottom rear edge of the roof fabric. The earlier 67 cars still used the wooden tack bow method . To dress the outer edge is a length of piping over which goes the chrome dress trim is nailed into the wood. This hides the staples and the frayed edges of fabric. The studs for the boot have designated holes in the dress trim.
The cars with the wire support will not have thls layer of piping, roof edges and dress trip. The press studs will have to go in the metal. Presumably these are positioned close by the equivalent locations of the earlier style.
Nicholas
KGCoupe
KGCoupe is offline
PostPosted: Tue May 14, 2019 7:18 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
sputnick60
PostPosted: Tue May 14, 2019 7:15 am    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Hi Scott.
I’d like to add a picture in this thread for you.
This shows my car just after paint where I want to draw your attention to a couple of holes. At the front, labeled “hole for plastic trim” is a hole for fixing the folded plastic trim on top of the lock pillar. This takes a 12 or 13 mm tubular rivet as already discussed here.....
https://www.thesamba.com/vw/forum/viewtopic.php?p=3338846. .....and we note your worthwhile contributions to that. This trim goes all the way along the edge and covers the hole at the back labeled “holes for chrome dress trim” . This hole accepts the dome top stainless philips screw at the bullnose of the chrome trim that’s been the subject of this discussion. This can only be placed after the roof has been installed because the screw must go through the chrome trim, the roof material, the lock pillar trim and finally into the metal.
Here is a repost from my other thread showing the template I made to transfer the nail positions to the car. The hole for the bull nose is occupied with a temporary screw and stud to keep the template in place. A white marker twiddled in each hole was enough to mark the nail positions.
This is a picture showing an awl being used to create holes that would start the nails.
Further , this picture shows the bottom side of the trim with the template in place alongside the awl used to make the guide holes plus the tool used with a hammer to tap the trim into place. This tool is mentioned in the VW special tools book and in this instance was made by my trusted friend Kevin Ferguson and given to me in anticipation that I’d need it one day Very Happy
If you buy the trim from KGPR, it will be straight and you will need to bend the trim in two axes from the near vertical at the car’s side to near horizontal at the car’s centerline. It’s okay to have a sizable gap in the centre because there is a dress clip that’s long enough to straddle 10mm.
Protect the car with a blanket taped to the back near the work. I also had a flat board that could be moved around to take the occasional slap from protruding nails.
To create new holes for the studs do so off the car. You don’t want to slip witha drill, The following steps are logical. 1: cover the target with masking tape. 2: Measure and mark the hole locations on the tape. 3: on an anvil or similar solid surface use a centre punch to mark the centre for the holes. 4: hold the trims in a flat vise with soft jaws on a drill press and drill small pilot holes with the drill press. Swap a larger drill to the required size. A counter sink is not required. You can use the dimensions already provided before bending the trim because its linearly the same, but it’s also not critical since the boot will get the buttons fitted to match the studs.
I started attaching the trim by locating the bullnose and it’s screw through the layers to the metal. Again it was the awl that’s used to poke a path through.
Instead of using a template that doesn’t flex maybe using something that’s flexible that can transfer the nail locations to the car. Possibly some masking tape laid reversed on the straight trim so the holes are perforated, then placed on the car whilst making sure holes miss the metal edge. Remember that the nail going in square means that the true angle moves from sideways to vertical relative to the car.
The complex angles actually work in your favour. There’s only a few nails that are in contact with the car as you work around the major bend. It’s possible to apply a bending force as you progress. The nails are hammered in as soon as they touch down while other ones are “still in the air”. The nails around the curve are close together but as you progress to the straighter top section they are further apart. Along the straight section they’re closer to where they need to be and easier to get in. You might use the awl progressively rather than doing all the holes in one shot. You might find the nails need to go in a slightly different place than determined by the template, if so, it’s probably best to let that occur but clear the way with the awl so the nail has a start past the body metal and into he tack bow.
Bon chance.
Nicholas
RCTScott
RCTScott is offline
PostPosted: Mon May 13, 2019 8:38 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Wow, just wow what great responses!! Thank you.
Crocteau, I just looked at Sputnick60's thread and that was quite helpful. Thank you!
Rcooled, you have helped me so many times already and yet again you offer up more pearls of wisdom and precision. Really appreciate it!!
Can I trouble you for one more measurement if possible? What is the distance from the one body snap to the inset screw at the bull-nose of the chrome trim? I think that distance might also help an installer and make the definitive answer complete.
I called KGPR Airhead Parts and they weren't so sure that the chrome trim has the countersunk hole anymore. The person to check will be there tomorrow. I will let you know if that is the case and we might need to find another constant, such as the edge of the bull-nose of the trim. But lets hold off on that for now in hopes that it is the same as the one that you used.
You guys are awesome.
Scott
Scott
rcooled
rcooled is offline
PostPosted: Mon May 13, 2019 3:25 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
RCTScott wrote:
Does anybody have the specs on where to place them if you were to install them into the chrome trim?
All but two of the male snaps should be in the chrome strip on an early '67...not in the body. The two snaps that are in the body are located just behind the door openings as seen in this pic from the gallery ↓
On my '67, they are .60" down from that crease just above it (which aligns with the chrome window scraper trim on the door) and 1.2" back from the door opening.
RCTScott wrote:
...neither of the aftermarket chrome trim pieces have the small countersunk screw that is depicted near the end of the bull-nose on the chrome trim.
The 2-piece rear molding sold by KGPR does appear to have the countersunk holes at each end. Using these as a starting point, the snap locations on my car, as measured inward along the strip from these holes, are as follows: 1st snap is 6 1/8" away, 2nd is 14 3/8" and the 3rd is 22 5/8". Both sides measure the same. The molding on my car is aftermarket and there were no issues with mounting the snaps to it.
https://airheadparts.com/vw-part/convertible-rear-support-molding-chrome-141-871-431-a/
RCTScott wrote:
...the parts book image shows #10 as white plastic 'saddles', or spacers, that sit underneath each male snap on the trim strip. Does anyone have a source for these?
These spacers are not available anywhere. I had a friend machine some for me from white nylon and I may still have a few extras. If I can find one, I'll send you a sketch with the necessary dimensions to replicate it. And yes, they'd be an ideal candidate for 3D printing.
crocteau
crocteau is offline
PostPosted: Mon May 13, 2019 2:46 pm    Post subject: Re: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
RCTScott wrote:
Please, if this has been covered, then I apologize and hope that someone might direct me to the thread.
No apologies needed, I just read something related in sputnick60's Aussie Road Trip thread, just scroll down, and if the detail you need isn't there I'll bet he'll be along any minute to help you out. Wink
RCTScott
RCTScott is offline
PostPosted: Mon May 13, 2019 1:39 pm    Post subject: Snap Placement Into 1967 Ghia Convertible Top Chrome Trim Reply with quote
Hello,
I know that there are a couple other snap placement threads but I could not find one specifically talking about where to place them when installing them into the chrome trim. Please, if this has been covered, then I apologize and hope that someone might direct me to the thread.
I am replacing my convertible top on my 1967 KG and have found that the original snaps were placed into the chrome trim and not into the metal area just behind the chrome trim as seen in later years. My understanding is that '67 is a transition year for this particular item, so there are two possible locations for the snap placement. It is dependent upon if the car was an early '67 (which mine is) where the snaps are installed into the chrome trim (see photos), or a later '67 where they are installed into the painted body metal just behind the chrome trim. The two photos attached here are from Rcooled from his original 1967 convertible prior to restoration, as well as the VW Parts Book.
I have seen some discussion about the later snap placement, but not on the earlier. In purchasing the chrome trim, both Chucks Convertible Parts and M&T MFG say to just install the chrome trim as original, but then to install the snaps into the pained body metal and not the trim. Also, neither of the aftermarket chrome trim pieces have the small countersunk screw that is depicted near the end of the bull-nose on the chrome trim as shown in the parts book diagram (see below).
Also, is there an issue with installing them into the trim? Is the newer trim that is available not as robust as the original trim, thereby prohibiting the snap placement? It seems puzzling that the two suppliers of the chrome trim both say to not install the snaps into the trim.
I certainly understand that the wood bow is what holds the snap in and not the chrome trim, but if the aftermarket trim is more delicate than the original trim, I do wonder if it might split upon the compression when installing the snap.
One final question is that the parts book image shows #10 as white plastic 'saddles', or spacers, that sit underneath each male snap on the trim strip. Does anyone have a source for these? Or if anyone has an original one, I have the ability to 3D scan it and make a 3D printed version.
Thank you for the help.
Sincerely,
Scott
