Poly Fuel Tank Venting Issue
Bkhansen93
Bkhansen93 is offline
PostPosted: Sat Aug 10, 2019 5:52 am    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
I was considering it. I may do it. Should onlt take a minute or two
slalombuggy
slalombuggy is offline
PostPosted: Fri Aug 09, 2019 9:10 am    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
You could trim the brass barb back a bit also. Makes it less obtrusive when taking the cap off the tank.
brad
Bkhansen93
PostPosted: Fri Aug 09, 2019 8:57 am    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
So this is my 1st iteration of the cap to vent and prevent spillage. Some may be familiar with this. It is a valve commonly used on dirt bike gas tanks to prevent spillage while upside-down. I later found that I only have about 1.5-2” of room from the top of the tank to the trunk lid so this hose has been shortened. Will go hit some bumps on my lunch break to see how it does.
andk5591
andk5591 is offline
PostPosted: Wed Aug 07, 2019 5:06 pm    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
One more thing - run your vent hose up and put a loop in it if not using the check valve...
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
Dale M.
Dale M. is offline
PostPosted: Tue Aug 06, 2019 3:53 pm    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
Another option I have used is metal valve stem....
Ditch the schrade valve and use as barbed fitting...
Does no have to be mounted in cap IF you are willing to drill tank...
Though Slalom Buggy idea seems best...
Dale
Bkhansen93
PostPosted: Tue Aug 06, 2019 9:57 am    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
Awesome. Didn't even know those existed. Thanks alot.
slalombuggy
PostPosted: Tue Aug 06, 2019 9:31 am    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
Go to a hydraulic shop tell them what you're doing and ask for a barbed bulkhead fitting. See if they make one with a reversion valve in it, then you won't need to thread the cap. And with the reversion valve you won't have to worry about fuel pouring out of the vent in a rollover.
brad
Bkhansen93
PostPosted: Mon Aug 05, 2019 7:22 pm    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
Thats the ideal scenario. I bought a couple different caps that will fit. Finding on that has some meat on it to tap is the issue. Most john deere riding mower caps are the same size.
jspbtown
jspbtown is offline
PostPosted: Mon Aug 05, 2019 12:56 pm    Post subject: Re: Poly Fuel Tank Venting Issue Reply with quote
drill the cap. Install a barbed fitting and install a rubber hose to allow vapors fuel splash to drain?
Bkhansen93
PostPosted: Mon Aug 05, 2019 9:22 am    Post subject: Poly Fuel Tank Venting Issue Reply with quote
Hey guys, I have a poly tank in by buggy that is not vented. To provide the tank with the necessary venting I tried using a vented cap. This provided the venting but also allows fuel to splash out of the vents and out of the tank. The tank is only about 1/2 full and it is still doing it. I imagine this is because the tank is just a cylindrical fuel cell with no baffles or real filler neck of any kind. the cap sits about 3/4 of an inch from the fuel line when the tank is full. I am looking for a non vented cap that is one piece that I can attach a hose barb to and run a hose for venting like on many dirt bikes and four wheelers. Any other solutions? I thought maybe a screen filter at the fill nozzle would cut down on some splashing but am having trouble finding one to fit the 3.5" wide filler hole. The other option I have come up with is to tap the tank like I would the cap and vent with a hose from there and just use a non-vented cap. The only real problem with this is that I'd rather not have to cut into my only gas tank. Any ideas?
The tank I am using is one of these:https://www2.cip1.com/ProductDetails.asp?ProductCode=C26%2DTKPS1030BK
