Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23558 Location: Kimball, Mi
Posted: Fri Dec 13, 2019 2:48 pm Post subject: Re: 73 square noise over speed bumps? |
| blues90 wrote: |
| Bobnotch wrote: |
You're probably coming due for them then. However, it's not just the 4 bolts that need to be removed, but the other 3 at the end of the spring plate too, maybe even the brake line and parking brake cable (to get enough swing out of the trailing arm). Hardest part is getting the spring plate off it's stop. Then getting a degree measurement at rest off the stop, so you can return it there.
A little trick I found is to get a couple of M10 bolts about 3 inches long to help get the cover back on. |
What size of pry bar doea one need to pull the spring plate off the stop? |
I used a big damn crowbar and a floor jack. The jack to get it just off the stop, and the crowbar to pry it out of the torsion tube. Just watch your fingers and toes around those parts, and they'll chop them off like nothing flat. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Thu Dec 12, 2019 4:11 pm Post subject: Re: 73 square noise over speed bumps? |
| Bobnotch wrote: |
Posted: Thu Dec 12, 2019 2:19 pm Post subject: Re: 73 square noise over speed bumps? |
| KTPhil wrote: |
| Tips when removing the spring plate to replace the inner bushing are to (1) of course mark the spline position with a sharp scribe or knife, and (2) tap the end of the bar back into the center splines as you pull the spring assembly off, so it never disengages the inner splines. This way you can ensure it's put back to the original setting. Though some cars sag over the years, requiring you to reset them, many will return to proper ride height/camber just with the new bushings; a little negative camber is not bad for handling, anyway, as long as it's even side to side. (3) coat the rubber (NOT urethane!) with talcum powder to lube them. (4) get longer bolts to start the covers and pull them in tighter, thus allowing the other two stock bolts to engage threads, then replace the longs with the remaining two regulars. |
My 73 ends look like they are covered , I can't see the bar to tap it back in. Doesn't look like paint or under coat. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36287 Location: Conejo Valley, CA
Posted: Thu Dec 12, 2019 1:46 pm Post subject: Re: 73 square noise over speed bumps? |
| Mr.Duncan wrote: |
| The bushings have worn so much the spring plate "tube" is rubbing and grinding through the metal outer covers. |
Mine were worn, too, so I cleaned them, primed and painted, then swapped mine side to side and upside down, so I had a new unworn surface on the top, good for another 200K miles! |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Thu Dec 12, 2019 1:41 pm Post subject: Re: 73 square noise over speed bumps? |
| KTPhil wrote: |
| Tips when removing the spring plate to replace the inner bushing are to (1) of course mark the spline position with a sharp scribe or knife, and (2) tap the end of the bar back into the center splines as you pull the spring assembly off, so it never disengages the inner splines. This was you can ensure it's put back to the original setting. Though some cars sag over the years, requiring you to reset them, many will return to proper ride height/camber just with the new bushings; a little negative camber is not bad for handling, anyway, as long as it's even side to side. (3) coat the rubber (NOT urethane!) with talcum powder to lube them. (4) get longer bolts to start the covers and pull them in tighter, thus allowing the other two stock bolts to engage threads, then replace the longs with the remaining two regulars. |
Thank you for the tips!
Yep my Squareback has some serious negative camber going on.
I have new un-worn outer metal covers to install as replacements. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
KTPhil  Samba Member
Posted: Thu Dec 12, 2019 1:39 pm Post subject: Re: 73 square noise over speed bumps? |
Posted: Thu Dec 12, 2019 10:06 am Post subject: Re: 73 square noise over speed bumps? |
| Mr.Duncan wrote: |
| I'll be doing this bushing job in about 4-6 weeks and will update with photos. |
Sounds like a fun job. Three things as a tech for 50 years I never liked were brake work . suspension work and gas tanks and fuel . I did my tie rod ends and replaced the fuel pump and all the lines . It's one thing working on a hoist then these repairs are much easier yet on the floor not so much . I did it when I was much younger in my 30's and 40's even 50's yet at 71 it becomes more and more difficult.
One task I need to do is clean off the oil on the engine and lower tins and CV joints then all the under coat on the torsion bar covers. just to be able to do this job. |
Posted: Wed Dec 11, 2019 3:32 pm Post subject: Re: 73 square noise over speed bumps? |
I'll be doing this bushing job in about 4-6 weeks and will update with photos. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Wed Dec 11, 2019 12:40 pm Post subject: Re: 73 square noise over speed bumps? |
| Bobnotch wrote: |
Here is the only video I could find or at least one of them.
https://www.youtube.com/watch?v=WefAipiNeUQ
There is another yet the fellow calls himself a hack it show the process.
All I can say is it sounds like a real job. My bushing plates and 4 bolts and the tube where the torsion bar fits in that sticks out where one slides the bushings on is just covered in undercoat.
I'll see if I can deal with it at some point. It seems you need to remove the lower shock bolt and CV joint to be able to swing the arm down enough to move the spring plate down then go from there. It seems you don't need to remove the brake lines or cables. |
Posted: Wed Dec 11, 2019 11:43 am Post subject: Re: 73 square noise over speed bumps? |
A little trick I found is to get a couple of M10 bolts about 3 inches long to help get the cover back on. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Tue Dec 10, 2019 4:12 pm Post subject: Re: 73 square noise over speed bumps? |
I looked at the spring plate bushings and both sides where the torsion bar end sticks past the bushing 4 bolt cover are very close to rubbing the top of the hole in the cover plate.
I never touched them and they are original. I read through the Bentley and it does not mention anything about this. I imagine they should be centered so this would require replacing both the inner and outer bushings right? This would mean pulling the spring plate off the torsion bar and from what I've read the torsion bar seems to always stick in the spring arm or outer splines of the bar.
From what I can tell the inner bushing carries most of the weight since it fits in the tube.
Isn't it the bushings that are the actual pivot point of the spring plate?
I did a search yet everything is now photo bucket logo covered and the videos no longer exist. |
Posted: Tue Nov 26, 2019 12:32 pm Post subject: Re: 73 square noise over speed bumps? |
| Bobnotch wrote: |
| blues90 wrote: |
| Bobnotch wrote: |
| One possibility is that the shock on that side isn't working correctly (dead rebound), and is allowing the trailing arm to slam against the positive stop on the rear sub/trailing arm mount. |
Their gas filled shocks and work , the noise is not loud it's slight creak like a lower rear seat cushion rubbing against the back. |
Ok, sounds like it needs to be taken apart and fresh talc applied. |
I noticed after driving a while the noise stops , they are original at least never changed since 1985. There are two right a notched inner and smooth outer. The bentley only shows one. These are all the swing arm has to pivot on right. I've never had them apart is why I ask. |
Posted: Tue Nov 26, 2019 12:13 pm Post subject: Re: 73 square noise over speed bumps? |
| blues90 wrote: |
| Bobnotch wrote: |
Ok, sounds like it needs to be taken apart and fresh talc applied. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Mon Nov 25, 2019 2:18 pm Post subject: Re: 73 square noise over speed bumps? |
| Bobnotch wrote: |
Posted: Mon Nov 25, 2019 12:40 pm Post subject: Re: 73 square noise over speed bumps? |
One possibility is that the shock on that side isn't working correctly (dead rebound), and is allowing the trailing arm to slam against the positive stop on the rear sub/trailing arm mount. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Mon Nov 25, 2019 11:08 am Post subject: Re: 73 square noise over speed bumps? |
| blues90 wrote: |
I hear a noise on the right rear sounds like rubber and I only hear it when both rear wheels go over a speed bump. I don't hear it bouncing the rear or on corners or jacking it up the entire rear one side at a time to get it on jack stands or lowering it back down.
Is it possible it's a trailing arm bushing at the end of the torsion bar cover? I think there is only one per side and both sides are centered in the covers.
On some sites that sell these bushings show two on each side or is that to cover beetles or is there an inner and out bush?
It doesn't make any noise or handle any different it's only when both sides move down at the same time it makes no noise going up the speed bump and it makes no noise going up the driveway which is steep incline or going down and it's only on the right side. It must be the action of the rear moving the up into the speed bump then the weight of the rear going down.
I toyed with the idea of raising the rear up a bit yet not so sure I want to deal with that.
One more thing I just want to say Photo Bucket , think about a phrase that fits the description to a tee. |
95% sure its your trailing arm bushings. Mine does the same thing.
Are they OG? -probably due for replacement.
If they are still centered in the covers you might not have to replace them if you are okay with the slight noise.
If they sag in the covers its time for replacement.
Should be two per side, ISP west sells them. (inner and outer) _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Sun Nov 24, 2019 5:49 pm Post subject: 73 square noise over speed bumps? |
