Need some help id'ing this 1965
notchboy
notchboy is offline
PostPosted: Thu Jan 09, 2020 9:30 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Your squareback, most likely was brought back to the US by a Serviceman/Woman. I say that due to your proximity to AFBases. There are lots of Euro spec VWs in Texas. Coupled with a moderate climate, nice examples like this pop up. They were either a direct purchase from a dealer in Europe or was part of a Tourist program that featured a new VW with a vacation package.
Most VW's don't have their original motor. They are so easy to pull out like batteries, most previous owners did as well as dealer/service shops.
Little reading on the side markers.
http://www.type34.com/library/34-authenticity-lights/754
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Bobnotch
Bobnotch is offline
PostPosted: Mon Jan 06, 2020 12:15 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
rustyfastback wrote:
I would not worry about having the original engine. You can make it look just the same as a '65 engine.
Yup. I agree whole heartedly.
About the only thing I'd worry about is what they did to put the later engine in. Did they start a 12 volt conversion? Swap out the flywheel for an O ringed 6 volt flywheel to keep it all 6 volt? And if so, did they swap out the big alloy cooling fan shroud? These will be questions you'll have to look into.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Bobnotch
Bobnotch is offline
PostPosted: Mon Jan 06, 2020 12:14 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
sjbartnik wrote:
Yeah having the original engine is pretty uncommon these days.
Agreed. It's not a really big deal. It only becomes a really big deal when you buy a car with the original engine. However with time and age, the OE engine may have been over heated several times and the case warped. Then it's time for a replacement. I have zero regrets replacing the engine in my 65 Notch with a new all aluminum case engine (did that 13+ years ago). I've also driven the car many places without worry as a result.
Tram wrote:
Tram wrote:
sjbartnik
sjbartnik is offline
PostPosted: Sun Jan 05, 2020 4:12 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
rustyfastback
rustyfastback is offline
PostPosted: Sun Jan 05, 2020 3:33 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
ghiafreek
ghiafreek is offline
PostPosted: Sun Jan 05, 2020 1:02 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Engine id
rustyfastback
PostPosted: Sun Jan 05, 2020 12:50 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Those small holes are for the correct emblems. Top Volkswagen script uses 4 holes (2 upper & 2 lower). Middle Variant script uses 4 holes (2 upper & 2 lower). Bottom 2 (upper towards right side lower towards left side) are for the S badge. That larger hole in the middle was added by a previous owner maybe for a different badge. Later engine cases are commonly used for all models as they are more common.
ghiafreek
PostPosted: Sun Jan 05, 2020 12:17 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Still not sure because it a later motor.
sjbartnik
PostPosted: Sun Jan 05, 2020 11:45 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
The S was the twin-carb version.
2000 Kawasaki W650
ghiafreek
PostPosted: Sun Jan 05, 2020 11:24 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Then I guessing variant S given the holes on hatch.
sjbartnik
PostPosted: Sun Jan 05, 2020 9:39 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Usually the hatch script is 1500 for the Canadian market & Variant for the European market.
Good point. Here's the hatch script on my '65 (with side markers)
2000 Kawasaki W650
rustyfastback
PostPosted: Sun Jan 05, 2020 9:34 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Some '64 & '65 models have no side markers as they were built for the Canadian market. The '64 & '65 models with side markers were built for the European market. Usually the hatch script is 1500 for the Canadian market & Variant for the European market.
ghiafreek
PostPosted: Sun Jan 05, 2020 8:19 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Thanks. I just got it home yesterday and I'm looking closely at everything. First type 3, you know. I have noticed some on some '65 threads that they don't have the side markers. I understand from earlier reply that all '65s were imports. So, they all didn't have the side markers? Mine does. Is it a different model?
Bobnotch
Bobnotch is offline
PostPosted: Sat Jan 04, 2020 10:59 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
sjbartnik wrote:
ghiafreek wrote:
Yep those are the Euro-market parking lights.
When you park on the street and turn the car off, you move the turn signal stalk to turn on either the left or right side, whichever is the street side. That lights up the bulb on that side only.
Nice looking, mostly complete unmolested car you have there.
Some of us turn those "parking lights" into side marker or turn signals. It's not hard to do, just a little rewiring (move the power wire on the fuse box to one that is hot with the key on) and adding a flasher unit in between. Wink
Have fun with it. The differences you'll run into are mainly the engine cooling lay out (uses basically the same long block as a bug or Ghia), and the front axle.
Just remember the golden rule, don't throw away anything you replace, until it's installed and working correctly. And even then, you still might want to hang on to it.
Tram wrote:
Tram wrote:
gt1953
gt1953 is offline
PostPosted: Sat Jan 04, 2020 7:21 am    Post subject: Re: Need some help id'ing this 1965 Reply with quote
Oh my nice ride, an Euro squareback. Don't be afraid of the type 3 they ride better then the type 1.
Whats the plan for the car? Sorta like you the type 3 is the same as type ones but different. I was lucky and scored several type three manuals that cover the side marker lights. Welcome to type 3!
72 type 1
72 Squareback
sjbartnik
PostPosted: Fri Jan 03, 2020 8:17 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
2000 Kawasaki W650
halfassleatherworks
PostPosted: Fri Jan 03, 2020 7:59 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
U0 1968-1973 1600cc - fuel injected for USA
U0 1970 1600cc - dual-relief case
ghiafreek
PostPosted: Fri Jan 03, 2020 7:23 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
sjbartnik
PostPosted: Fri Jan 03, 2020 5:54 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
ghiafreek wrote:
By looking at VIN chart it seems engine is 1963. Am I wrong?
Yes, you can't leave off the U when looking at engine number. Early engines did not have a letter prefix.
Looking at the chart it seems U cases didn't show up until around '67.
As for the side marker, are you talking about a light on the front fender? If so, that is not a side marker but a parking light. They were on Euro-spec cars but not US-spec cars. Since VW did not officially start selling the Type 3 in the US until 1966 model year then that would make sense.
The parking light should come on when 1) ignition is OFF and 2) the turn signal lever is moved to that side.
2000 Kawasaki W650
ghiafreek
PostPosted: Fri Jan 03, 2020 5:52 pm    Post subject: Re: Need some help id'ing this 1965 Reply with quote
By looking at VIN chart it seems engine is 1963. Am I wrong? Do all '65s have front side markers ( small type blinker)?
