Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2510 Location: UK (South)
Posted: Mon Mar 15, 2021 11:17 am Post subject: Re: Any idea what this plug could be? |
hazetguy wrote: |
there is no need to remove it, as it isn't doing any harm being there.
OK. And thanks for the info. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10796 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Mar 15, 2021 10:25 am Post subject: Re: Any idea what this plug could be? |
the center of the tab melts out if the temp exceeds the heat rating of the tab. the tab doesn't fall off the case if overheated. that's why it gets epoxied to the case.
a new heat tab:
Posted: Mon Mar 15, 2021 10:24 am Post subject: Re: Any idea what this plug could be? |
Thanks guys.
I'm not surprised if it indicated that the engine had overheated at some point. I reckon it had been run hard.
It had poor quality tinware and the bottom tinware was missing entirely.
It's been rebuilt since.
Is it safe to remove it or is it best left where it is? I couldn't see a hole from the inside of the sump, but would they have drilled the case to fit it? _________________ Andy
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1333 Location: south san francisco
Posted: Mon Mar 15, 2021 9:53 am Post subject: Re: Any idea what this plug could be? |
it is a temp warning thingy. some re-builders used them back in the day. I don't know if anyone uses them anymore. it was a warrantee deal .the center would blow out? if the case overheated. like if you ran without a fan belt or abused /neglected your motor. I haven't seen one in years. never seen one blow out? not sure how it told you it got too hot? I think revco? used them.? years ago.
Steve _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Mon Mar 15, 2021 9:50 am Post subject: Re: Any idea what this plug could be? |
i agree that is a heat tab, and it looks like the center melted out of it (overheated). difficult to tell from the poor pic.
that is the location where GEX typically puts them. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 3961 Location: Rapid City, South Dakota
Posted: Mon Mar 15, 2021 9:41 am Post subject: Any idea what this plug could be? |
My engine case has this disk on the left hand side rear-most wall of the sump. It's glued in place with what looks like permatex. It looks to be a plug or bung. If there's a hole behind it, the hole doesn't penetrate through in to the sump (confirmed through pictures from when I rebuilt it).
I'd assumed that it was covering an oil gallery, but I've realised that it lines up with the sump, not the oil galleries.
Anyone know what the disk might be for? The case is a genuine VW dual-relief case, part no. 211.101.102D prefixed with a 40 before the VW logo.
This engine is a bit oily in this pic because it's from before I rebuilt the engine. _________________ Andy
