squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4025 Location: San Jose, CA
Posted: Mon Jun 05, 2023 2:27 pm Post subject: Re: Door Card Removal and Window Winder Confusion. |
tjmartin317 wrote: |
I hope they sell replacements of those... otherwise, I'll just use a lot of scotch tape  |
Take some plastic, cut it to a rough shape, and glue it on there.
_________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
tjmartin317 Samba Member
Joined: March 18, 2022 Posts: 289 Location: West Virginia
Posted: Mon Jun 05, 2023 2:19 pm Post subject: Re: Door Card Removal and Window Winder Confusion. |
GjMan wrote: |
No plastic barrier between card and door. So rain will soak the card. Which it obviously did. |
Oh, there was a plastic barrier, but it wasn't good for much anymore. I hope they sell replacements of those... otherwise, I'll just use a lot of scotch tape  |
GjMan Samba Member
Joined: June 05, 2004 Posts: 834 Location: Grand Junction, CO
Posted: Mon Jun 05, 2023 12:10 pm Post subject: Re: Door Card Removal and Window Winder Confusion. |
Posted: Mon Jun 05, 2023 7:58 am Post subject: Re: Door Card Removal and Window Winder Confusion. |
I was worried about breaking something with the amount of gentle persuasion I was giving it. Good to know I just have to keep banging at it.
Also, very nice art! |
jaransonT3  Samba Member
Joined: January 01, 2005 Posts: 1310 Location: Dearborn, MI
Posted: Mon Jun 05, 2023 6:05 am Post subject: Re: Door Card Removal and Window Winder Confusion. |
Remove the small Philips screw and then you should be able to wiggle the handle off the shaft like Allwagons said. If they are corroded onto the shaft, it might take a little gentle persuasion to break them loose. A couple of light taps with a hammer should do it.
The conical spring is there to locally push the trim panel out to close an gap to the handle. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2024Invasion/ |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4612 Location: Pasadena CA/DTLA soon China
Posted: Sun Jun 04, 2023 11:19 am Post subject: Re: Door Card Removal and Window Winder Confusion. |
just wiggle them off! _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Posted: Sun Jun 04, 2023 9:09 am Post subject: Door Card Removal and Window Winder Confusion. |
I'm getting ready to remove the doors on Fargo, my 72 Squareback, which meant unplugging the speakers in the door cards, which meant removing the door cards. I don't think I'll be reusing these because they're kinda gross (bare metal would honestly look better, once I vacuum all the debris out of the door), but I tried to remove them carefully and, for the most part, succeeded.
However, I'm confused about my window winders.
There's a little phillips screw that I removed which seemed to do nothing. The handle wouldn't come off and the window still rolled up and down normally. With this car, things being rusted together is a common theme, but even after some semi-firm prying it wouldn't pop off or do anything to make removing the door cards or the handle easier.
Furthermore, there's a conical spring (as it's called in the Bentley book) which I guess pressed the door card against the little rubber gasket so the handle could spin without interfering with anything...
Well, now the springs are half hanging out, and the cards are still in because the PO decided that, rather than crimping a spade connector on, they'd just solder the wires right to the speakers.
Photo dump of all this stuff below:
In other news, this also happened:
Never posted it to The Samba because I post all my updates and adventures on Oppositelock, another general car forum. I come here mostly for expert advice, and am never disappointed.
Restoration is moving right along. Once the doors are off, we weld bracing into place, undo the little bits and bobs holding the engine and frame, and then separate! Then I have to learn how to cut and weld, which should be... interesting...
Hope you're having a swell weekend too! |
