That damned late bay Oil drain - strainer nut
danfromsyr
danfromsyr is offline
PostPosted: Wed Dec 13, 2023 6:30 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
I do in fact know a fella who broke his case, as he came to me for a replacement to rebuild
it not only can, but does happen.
Shonandb wrote:
I don't think I've ever come across anyone in the last 40 years who has actually overtightened their strainer nut and had a problem.
This is a similar to the warning not to start your engine without oil in it.
I think that these are old wives tales but I'm sure we will now hear the stories of my brother's sister's friend's brother who did one or the other.
Abscate wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Wed Dec 13, 2023 4:27 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
The error and damage is so common that there is a name for it - Type IV syndrome. The issue is that anyone who owned a type 1 engine VW got in the habit of changing the oil thru the strainer. Along comes a TIV engine and they do the same and hand tighten it. That is enough to break it. Very common problem - and expensive mistake. That is why we remind people about it.
George Carlin:
Skills@EuroCarsPlus:
timvw7476
timvw7476 is offline
PostPosted: Wed Dec 13, 2023 4:22 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
I cleaned the strainer every 3k on my first bus.
Then this one time I found -0- stuff in there & noticed the spin-on oil filter & asked myself wTf I was doing & gave that bad habit up.
Unless it's a New-To-You bus just clean it once & leave it alone.
......Like that Seinfeld episode where Costanza double-dips a chip....bad form.
Shonandb Premium Member
Shonandb is offline
PostPosted: Wed Dec 13, 2023 3:59 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
Previous 1973 Panel Bus:
Click to view image
dodger tom Premium Member
dodger tom is offline
PostPosted: Wed Dec 13, 2023 3:40 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
Wildthings wrote:
RWK wrote:
Always use oil drain plug to change oil, never remove strainer is the rule I would use.
I believe in cleaning the strainer every 100-150K miles when I reseal the engine.
isn't that damn close to never?
and, what's "reseal the engine?"
i've never done that, and can't wait to try.
MuzzcoVW
MuzzcoVW is offline
PostPosted: Wed Dec 13, 2023 2:35 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
SGKent wrote:
Since we have a plethora of new late bay VW owners suddenly making posts - it is time to warn y'all that you never tighten the oil strainer nut more than 9ft lbs if you take it off or a real expensive disaster will occur involving a complete teardown of your motor. DRILL that into your memory now.
This one circled in red:
Was it Ray G that came up with the mod to help avoid this issue? I was thinking of doing the same when I rebuild... but then again I know better than to use 200 ft lbs on the damn thing so Laughing
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Dec 13, 2023 12:49 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
As a reminder to you and others, maybe impact stamp a big "9" or "9 lb.ft." on the head? Paint it bright red maybe?
danfromsyr
PostPosted: Wed Dec 13, 2023 12:25 pm    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
maybe if someone could mfg a nut that didn't have such a big hex portion.
even if it's round you can get 9ft lbs on it with a pair of water pump pliers.
Abscate wrote:
Wildthings
Wildthings is offline
PostPosted: Wed Dec 13, 2023 9:10 am    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
RWK
RWK is offline
PostPosted: Wed Dec 13, 2023 5:47 am    Post subject: Re: That damned late bay Oil drain - strainer nut Reply with quote
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
SGKent is offline
PostPosted: Wed Dec 13, 2023 12:09 am    Post subject: That damned late bay Oil drain - strainer nut Reply with quote
George Carlin:
