iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2079 Location: M*ssholia
Posted: Fri Jul 25, 2025 2:55 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
why not weld outside pans and bolt middle ? |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Mon Mar 03, 2025 4:34 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
livnlow wrote: |
I made mine bolt in so I could still have access at a later date. I was installing a Dormobile top and didn’t have time to go into a full restoration but felt like I should have the pans. I noticed a difference in stiffness based off my cargo door alignment.
Lovely work by the way. LOTS of work, tho. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Mon Mar 03, 2025 4:32 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
I've a little perspective on torsional stiffness on type 2's: For many years I drove bay window buses in my contracting business. They are so great going into rather rough terrain and I would often put a wheel over the curb and just go from there. My 69 double cab had some pretty serious rocker rust and it would bend so much that it would often emit a loud TWANG! Pretty sure it was the center partition "oil-canning" so to speak. It had a solid partition and a 1 + 2 front seat with spare tire storage.
Also, at that time I had a rusty 1971 Dormobile. A full euro spec Dormie NOT a Westy with a Dormobile top. It was evil to work on replacing brake lines and I did cut some access holes.
I often figured if I were to properly restore one I would get new proper Gerson belly panels and attach them with PANEL ADHESIVE and self drilling pan head screws. If I ever had to service under the panels, it would be a simple matter to heat the adhered areas with a heat gun and remove them. Pretty sure this would work and only about $50-100 to find out. One could always weld them on later if it proved to not be strong enough. _________________ Al Brase
Vanagons:
thom Samba Member
Joined: October 12, 2000 Posts: 6176 Location: Sacramento
Posted: Mon Feb 24, 2025 10:27 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
I put a sunroof clip in a bus years ago, without any underside support, and you could feel the twist when going over bumps. The cargo door area would also distort enough that you could see marks at the top and bottom of the opening. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Feb 24, 2025 10:26 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Nice work. I would use heavy-duty washers, as that green metal is very soft. Or even better, a bolt-down strap for each side, but at that point you may as well just weld it.
livnlow wrote: |
1956 Single Cab
1963 Unimog 404
1965 E-Type |
livnlow Samba Member
Joined: May 03, 2005 Posts: 57 Location: Jacksonville, Florida
Posted: Sun Feb 23, 2025 11:03 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
_________________ 1963 356B Coupe
1965 sundial |
SolarPoweredPickles Samba Member
Joined: May 13, 2009 Posts: 1264 Location: California
Posted: Sat Feb 22, 2025 5:44 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Malokin Martin wrote: |
pyrOman wrote: |
One important thing I overlooked was the possibility of eventually having to replace the wiring loom. Factory belly panned buses have a tube/pipe to run the wiring through. So before doing the pans I suggest you provide for that too!  |
Ughhhh… and the fuel reserve cable… don’t forget the fuel reserve cable…. Make sure it works before the pans… Nightmare. |
Thanks, that's another thing! Yeah things need to be perfect before welding in belly pans, and even new parts as we all know go out, belly pans are mandatory for certain models and conversions like mine, support and safety, and they sure look clean underbody, but they also scare me because everything is behind a welded wall of steel. But this is the LAST thing I'll be doing on my build so I have time to consider options and chat with some structural pros on possible CORRECT bracing options.
As mentioned before it must be done right, not just tubing welded here and there. Also, non-belly pan option would save some big bucks, the cost of tubing, is must cheaper. But of course, I wouldnt choose money over safety, just saying, if bracing and tubing is an option, I plan to chat with some pros and maybe some race car peeps/ shops when the time comes. |
Malokin Martin Samba Member
Posted: Mon Jan 27, 2025 9:32 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
pyrOman wrote: |
Posted: Mon Jan 27, 2025 3:27 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Clara wrote: |
I had a SC that was off-road raced. They boxed in the frame rails, added a roll cage, and did some other mods to do things like this:
The current owner tidied it up under there:
That said, if you add a sunroof , or DD both sides, the generally idea is to add the belly pans |
Well thats damn pretty! Love it.
And agree on the other post, lots of math and geometry to get structural correct. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2368 Location: Graz, Austria, Europe
Posted: Mon Jan 27, 2025 2:34 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
even with added boxing plates to the main rails. imho the effect will be minimal. The whole design is made to allow for flexing. a Sc truck is something else, because it has a second floor structure and pan ( bed), which actually acts exactly like a space frame. a SC or DC is a better design from the start !
when you box the main rails, you also need to tie them together with huge tubular crossmembers, or a z shaped structure, much like a crane would look like.
Single structural elements will only add minimal strength. it is the space frame construction, with widely spaced reinforcements, that makes it rigid. It is mechanical engineering, not adding a lot of steel plating, which makes it solid. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Clara  Samba Member
Posted: Mon Jan 27, 2025 11:56 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
That said, if you add a sunroof , or DD both sides, the generally idea is to add the belly pans _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15235 Location: Casa de Oro, California
Posted: Mon Jan 27, 2025 11:32 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
electronictofu wrote: |
...Has anyone tried something different from the usual belly pans, or is that the "BEST ROUTE"? .... |
I see you are the guy doing the Double Door. One thing that you should do if you want to stay with VW factory stiffening support is inner skylight frames.
Double down on the welds everywhere.
Use your skills if you want to add tubing here and there by making cross structures anywhere you can sorta hide it and tie into other points of factory connective points, especially if you are adding skylights and sliding roof. |
Posted: Sun Jan 26, 2025 4:53 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Hot Rodder here, A, Deuce and 34 rails boxed.
You always need to think like in space frame. US iron mostly had ladder type or X frame and body bolted on top. later on unibody design ( from ca 1960s like Falcon, Mustang etc.). it is not the thickness of plate, but the distance of spaced elements. the belly pans in Vw buses are a terrific design and adding a lot of strength, but they are spaced only so much from the main rails and below the floorboards.
Boxing the main rails will hardly add any strength to a bus.
If your floor structure is rusted, you may think about replacing the I beams or open T hat crossbeams with square tubing. tying it all in with bracing and tubing like in a tube type sports car chassis. all of this sounds stupid and it is.
A set of belly pans will give your bus all the strength it needs. much like Barry told you in his first reply.
I am building a crazy space frame barndoor chassis, but in reality it isn't needed at all. after all, it's just a bus. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12546 Location: Over 2002 posts deleted!
Posted: Sun Jan 26, 2025 3:24 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
FWIW...
After cutting a YUGE chunk off the top of my bus to install a Dormobile top, I knew I'd need belly pans. Didn't have the $$$ to buy originals, if they were even available then, or the time to wait for them. So I made my own! This was done back in '09 and is still going strong!
One important thing I overlooked was the possibility of eventually having to replace the wiring loom. Factory belly panned buses have a tube/pipe to run the wiring through. So before doing the pans I suggest you provide for that too!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Sun Jan 26, 2025 2:57 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
pondoras box wrote: |
Belly pans are just flat steel with pressings to strengthen them up. You could fabricate your own and be fine. You would need a bead roller and a break but you could get them pretty stock looking to the untrained eye. Or if you had some tubing lying around do a Nuespeed style brace for it. |
I'll look them up! Yeah, no bead roller here, life would be a lot easier with metal work if I had access to one. I really like the idea of tubing style bracing, this will be the last thing I weld on my bus, but Ive been ordering metal, so I think I'll hold off on buying belly pans. I'll revisit the thread when I get close. Uncommon, but belly pans block off all kinds of stuff we might need to access, unlikely once putting in new brake lines, wiring, and once dialed in, I would still want to be able to get in there if something happened and stock belly pans might make life tricky. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1618 Location: Eerie PA
Posted: Sun Jan 26, 2025 6:52 am Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Belly pans are just flat steel with pressings to strengthen them up. You could fabricate your own and be fine. You would need a bead roller and a break but you could get them pretty stock looking to the untrained eye. Or if you had some tubing lying around do a Nuespeed style brace for it. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
Posted: Sat Jan 25, 2025 8:16 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
BarryL wrote: |
Those vehicles you mention all have much thicker steel for the frames as well as cross beams and stuff. Boxing those makes an enormous strengthening. Buses frames are like tin compared to those. The whole bus is part of the flex-strength. The pans are engineered to hook onto and spread and grasp the flex.
I have one bus with belly pans and one bus without. The belly pan bus flexes and the straight frame one flexes. I've always been on the lookout for cracks and tweaks as I've done major long and grueling off-road things and have yet to find any damage. Someone else will have to answer the boxing the VW frame scenario. |
Glad someone chimed in I was really curious. Yeah, my Chevy cars Ive had in the past had different types of frames, shape, gauge, etc.
Sounds like you put it through some hardcore stuff if you are doing off-road VW fun. But interesting, you are saying you are seeing flexing with and also without belly pans? Mines a slammed daily driver build, double door, maybe a ragtop, so belly pans seem smart. But looking at costs, I was curious is other types of steel and methods would be stronger, easier, etc. than factory belly pans. Nonetheless, with a double door, and or 21-23 window, or ragtop, etc. Anything along those lines, seem to need some support for sure.
I just like getting creative and my welding skills are pretty good. And lots of steel on hand. New methods, and alternatives always interest me, of course, within the reason of safety. |
BarryL  Samba Member
Posted: Sat Jan 25, 2025 6:46 pm Post subject: Re: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Posted: Fri Jan 24, 2025 9:12 pm Post subject: Belly Pans/ Frame Work/Ragtops and 21-23 Windows |
Hey everyone!
I’m feeling like diving into a chat about frame strengthening. Specifically, I want to talk about 21-23 window buses, double doors, ragtops, and belly pans. It’s pretty clear that most of the 21-23 window buses and double doors, whether they’re stock or modified, have those belly pans.
That said, I’ve worked on my fair share of Chevelles, C10s, and other Chevy rides. Usually, I just do a good frame cleanup and box the frame, and honestly, it’s a pretty straightforward project that makes a huge difference in performance and safety.
Now, when it comes to our buses (mine’s a 1961 previously chopped up panel with a double door conversion in progress, some previous owners doing and some mine) I really want to keep this conversation focused on safe, interesting, and creative frame work, chassis boxing and stock belly pans. Has anyone tried something different from the usual belly pans, or is that the "BEST ROUTE"?
I’m focusing on a few things, like cost, shipping, and how buying new belly pans stacks up against various frame strengthening options similar to the muscle and classic car scene. Is buying/using on-hand steel and going a custom route a path any of you have gone, if so, experiences and advice, sharing tips? Keep it stock stupid "KISS" applies to many avenues, and tried and true techniques are rock solid, that said, I am just a curious cat. |
