Cusser Samba Member
Joined: October 02, 2006 Posts: 33033 Location: Hot Arizona
Posted: Fri Jun 13, 2025 6:53 am Post subject: Re: 74 super beetle brake fluid reservoir blue hose installation |
1. I would've put the hose over the plastic barbs first, easier access. The other ends can be connected afterwards.
2. I would warm up the blue hose a little (of course, I'm in Arizona, so already warm).
3. I always use brake fluid to lubricate the plastic barbs and the inside of the blue hoses and carefully push/twist to get the hose on. Yes, the plastic elbows can bend, better to find out before installation of the mater cylinder ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
maddave2000 Samba Member
Joined: September 30, 2024 Posts: 20 Location: United Kingdom
Posted: Fri Jun 13, 2025 6:38 am Post subject: Re: 74 super beetle brake fluid reservoir blue hose installation |
RUNWAY13 wrote: |
I have a 74 super bug. Had a guy put in a new brake master cylinder but could get the blue hose to fit over the nipples on the m/c. he destroyed the m/c. so now i have to install a new m/c along with the blue hoses to the brake fluid reservoir and the metal lines.
here is the question: what is the easiest way to get the blue hose slid onto the reservoir metal lines and the master cylinder?
can i use dielectric grease to slide the blue hose on nipples and metal lines and then clamp the hose?
any suggestions??
thanks for the help! |
Did he destroy the master cylinder or just the blue hose connectors? These just pull out and can be replaced if the latter - example:
https://www.justkampers.com/air-cooled-vw-parts/vw...-1998.html |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2024 Location: Wichita, KS
Posted: Fri Jun 13, 2025 5:36 am Post subject: Re: 74 super beetle brake fluid reservoir blue hose installation |
I’ve always just liberally wetted the inside of those hoses and outside of mating metal lines or nipples w/ soapy water (or even saliva) to lubricate, prior to fitting/pressing them together. Then lightly blow out w/ compressed air or otherwise let dry, prior to putting into service. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
alex857 Samba Member
Joined: December 26, 2010 Posts: 767 Location: Stuttgart/Germany
Posted: Fri Jun 13, 2025 2:52 am Post subject: Re: 74 super beetle brake fluid reservoir blue hose installation |
Hi, I used brake cleaner spray. Careful with grease, it might affect the rubber parts of the hose. The blue hoses have no pressure on them and are not clamped (picture second row, on the right):
RUNWAY13 Samba Member
Joined: November 13, 2024 Posts: 50 Location: Colorado
Posted: Fri Jun 13, 2025 1:41 am Post subject: 74 super beetle brake fluid reservoir blue hose installation |
any suggestions??
