delliott101 Samba Member
Joined: February 22, 2008 Posts: 1315 Location: Caldwell - Lake Lowell ID
Posted: Tue Dec 09, 2008 10:11 pm Post subject: Putting the rear axle/seals/bearings back together |
I think I have it right... but does anyone have a blown apart diagram of how all the parts (axle tube to wheel backing plate) go back together? Simple non-CV joint '59 rear axle.
Thanks! _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
We don't own old VWs, we just take care of them for the next driver |
NOTAHONDA Vegas Don
Joined: September 30, 2006 Posts: 1411 Location: Arizona
Posted: Tue Dec 09, 2008 11:43 pm Post subject: |
Just replaced mine over the weekend, heres the pic i used...
li_gangyi Samba Member
Joined: August 15, 2008 Posts: 455 Location: Singapore
Posted: Wed Dec 10, 2008 12:04 am Post subject: |
When you get to the seal area, press the seal and slinger into the cover, put the axle spacer into the seal/cover 1st, before bolting it all up.
Often peeps will try to put the spacer on the axle and then get the cover on, it will most likely then not seat properly and leak... _________________ Me messing with the transmission and stuff...(includes pictures and the whole 'story')
http://vwbeetleadventure.blogspot.com/ |
Posted: Wed Dec 10, 2008 7:08 am Post subject: |
Wow.. thanks!!! _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
HBCRUZR Samba Member
Joined: April 23, 2004 Posts: 603 Location: The center of TheRoddersJournal #45 sucka's!!!
Posted: Sun Dec 21, 2008 4:52 am Post subject: |
Does anybody sell the bearings and spacer's as a kit? Best place to buy those?
Chris _________________ SBS #89 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Sun Dec 21, 2008 8:59 am Post subject: |
That picture is 65 and newer. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Sun Dec 21, 2008 11:30 am Post subject: |
Early with slinger, from the other Andy's site....
_________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
| bill may wrote: |
| I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Sun Dec 21, 2008 1:26 pm Post subject: |
My rear axle was put together like the first picture above... those are the parts on it when I took it apart. I don't have that oil deflector thing on the second picture and I had the paper gasket on there.
I already put it all back together, per picture number one. I will hold onto this thread for future reference, though _________________ Transplanted Jersey Boy living in Idaho by way of Northern California!
rcroane  Samba Member
Joined: January 03, 2013 Posts: 2020 Location: Springfield, Virginia
Posted: Mon Sep 25, 2017 9:21 am Post subject: Re: Putting the rear axle/seals/bearings back together |
Reviving this old thread, because I saw something in the Bug Me video on this subject that confused me. In the video, the narrator shows the removal of a grease seal on the FRONT side (wheel side) of the bearing cover. I don't see that seal in either of the diagrams shown in this thread.
My car is a '65....am I going to have that outer grease seal?
Thanks. _________________ '65 Sunroof Bug |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Posted: Mon Sep 25, 2017 11:30 am Post subject: Re: Putting the rear axle/seals/bearings back together |
| rcroane wrote: |
Thanks. |
Does the Bug Me video specify what your they are working on?
Up to 64 you can put the seal in the bearing cap from the outside.
65-> the bearing cap changed and you have to install the sealfrom the inner side.
Study the above illustrations carefully and you can see the visable difference in the caps. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Mon Sep 25, 2017 11:34 am Post subject: Re: Putting the rear axle/seals/bearings back together |
That might be it....they did both so maybe he was showing both versions. I watched it a couple of times and didn't hear him say that it was two different versions.
Thanks for clarifying. _________________ '65 Sunroof Bug |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11498 Location: Oregon
Posted: Mon Sep 25, 2017 5:37 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
In the 65 diagram make sure to put the oil slinger in the bearing cover before installing the seal through the back side of the cover. Use a seal installer. You'll be happy you did. You can rent one for free at the FLAPS.
Another poster in another forum suggested inserting the machined spacer that the seal rides on into the seal, then installing the entire cover and spacer as one piece on the axle. That way you don't catch the lip of the seal on the axle when installing the bearing cover.
Makes sense to me. I recently changed a rear axle bearing and snagged the seal when I installed the cover. Got to change the seal again the next weekend
Make sure to lube the seal very well before installing the bearing cover.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Mon Sep 25, 2017 6:20 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
Thanks for the replies. Finished step 1 this evening....draining the gear oil (will let drain overnight). Good news is that it looked very clean. Bad news is it seemed pretty low (rear end of car was jacked up...not sure if that made it seem lower than it actually was). I've dropped the car back to level while it drains overnight. I'm going to measure how much came out after it finishes draining.
Do I use gear oil to lube the seal? _________________ '65 Sunroof Bug |
Posted: Mon Sep 25, 2017 6:33 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
I used wheel bearing grease on the seal.
I really wouldn't sweat how much oil was left in the trans. Unless your anal retentive. Then go for it.
Just make sure that when you fill the trans that you give it time for the gear lube to settle into the case. In other words. Fill it slowly.
Buy Once, Cry Once!
61SNRF Samba Member
Posted: Mon Sep 25, 2017 7:58 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
Did you pull both drain plugs? That way ensures you have drained as much as practical with the trans in place.
Any lip seal with a garter spring needs to be pre-lubricated with something compatable with the main oil spec. With all the different wheel bearing grease compounds available nowadays, I'd suggest simply using a light film of your chosen gear oil on the seal and race.
Yes on installing the spacer/seal race into the installed seal from the wheel side before you install the assembly onto the axle/bearing/backing plate. This way you can look and verify that the garter spring remains safely intact and in place. _________________ -Bruce
Posted: Tue Sep 26, 2017 5:45 am Post subject: Re: Putting the rear axle/seals/bearings back together |
Crap...didn't realize there are two drain plugs! Looks like I'm back under there tonight  _________________ '65 Sunroof Bug |
Posted: Tue Sep 26, 2017 4:35 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
Ok....having trouble locating the second drain plug. My car has a camber compensator. It is attached in the center to a bracket/plate and it looks like there is a drain plug under there....does that sound correct? So, I will need to remove compensator and plate to access drain plug?
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Tue Sep 26, 2017 5:19 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
In this pic from the gallery, you can see the fill plug on the side, the forward drain plug at the forward end of the tunnel, and the rear drain plug pretty well centered under the differential.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Sep 26, 2017 5:37 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
Got it....like I thought, it was covered by the camber compensator and bracket.
Removed the second plug and about another 1/2 -3/4 cup of fluid drained out. Will leave it overnight.
I noticed that the compensator is EMPI....based on notes in my owners manual, the original owner had the dealer install it at the time of purchase.
Thanks again for all the advice so far. _________________ '65 Sunroof Bug |
61SNRF Samba Member
Posted: Tue Sep 26, 2017 7:54 pm Post subject: Re: Putting the rear axle/seals/bearings back together |
Yep, the unit assembly is called a a transaxle for a reason 😉
Transmission drain plug is forward, and the rear axle aka differential drain plug is rear most. Internal webbing in the housing prevents full drainage from only one plug.
The Manual and best practice would have you warm the engine and transaxle up to normal temp then driving the car over a pit or flat ramp before pulling both drain plugs to change the oil. Compromise and adapt as you must.
In a perfect world you would expect to recover ~3/4 of what full refill spec is. Less than that it might have been a little low. _________________ -Bruce
