high rev points?
scotty timmerman
scotty timmerman is offline
PostPosted: Mon Jul 23, 2012 11:00 pm    Post subject: high rev points? Reply with quote
i have a Brazilian 009 and i was wondering what kind of points i should run with my high rev motor? thanks
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
66brm
66brm is offline
PostPosted: Mon Jul 23, 2012 11:14 pm    Post subject: Reply with quote
How high rev is high rev?
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
scotty timmerman
PostPosted: Mon Jul 23, 2012 11:20 pm    Post subject: Reply with quote
probably around 7000 rpm. i have a 76X94 with a 130 cam and 42x37.5 heads
73 super beetle
SRP1
SRP1 is offline
PostPosted: Mon Jul 23, 2012 11:23 pm    Post subject: Reply with quote
Throw the points away, and install a compufire pick up module.
http://www.dansperformanceparts.com/buggy/ic/buggyic.htm
66brm
66brm is offline
Thought about points replacement kits?
Aust. RHD 66 Type 1
scotty timmerman
PostPosted: Mon Jul 23, 2012 11:34 pm    Post subject: Reply with quote
i just didnt want to spend a lot of money on it because i still need a lot of other parts for the restoration. and if i can save some money, points are good enough right now. just want to know what a good set of points i should run.
73 super beetle
66brm
66brm is offline
PostPosted: Mon Jul 23, 2012 11:41 pm    Post subject: Reply with quote
Ok finish the car, drive it with points but keep the revs down till you can afford the replacement module. Easy solution
Aust. RHD 66 Type 1
SRP1
SRP1 is offline
PostPosted: Mon Jul 23, 2012 11:45 pm    Post subject: Reply with quote
Look for a set of Bosch OEM points, change out to the electronics if the points are not getting the job done.
I have had engines up to 7000rpm with the OEM points, does not mean it was the "best" but it did work.
scotty timmerman
PostPosted: Tue Jul 24, 2012 12:05 am    Post subject: Reply with quote
ok thanks guys
73 super beetle
yamaducci
yamaducci is offline
PostPosted: Tue Jul 24, 2012 9:26 am    Post subject: Reply with quote
To answer your question the Bosch "Tiger tail" Points are the performance version noted by the white striped black wire on the points. They are known to handle 6000+
http://vwparts.aircooled.net/Bosch-009-050-Tiger-Stripe-Ignition-Points-p/01-030.htm
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
