Headlight Bowls and Deluxe trim questions
samcocker
samcocker is offline
PostPosted: Sun Nov 10, 2013 11:20 am    Post subject: Headlight Bowls and Deluxe trim questions Reply with quote
Does any one have any info and picture on headlight bowls to suit a 54 so I can make sure I get the right type. lenses and everything Very Happy
Also is there a difference between Barndoor and post Barndoor deluxe trim?
Can you buy it new?
Many thanks, Sam
Rusting Hulk
Rusting Hulk is offline
PostPosted: Sun Nov 10, 2013 2:27 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=180652&highlight=barndoor+headlights
Not sure if the trim is different, although I had a piece missing from my bus and I used another used piece... from memory it was slightly narrower than the original stuff, like 1mm. I had to 'spread' it out slightly to match.
64 356 C Coupe
PostPosted: Sun Nov 10, 2013 10:29 pm    Post subject: Re: Headlight Bowls and Deluxe trim questions Reply with quote
Some of the lengths are different since it wraps around the rear a different distance than later Buses - you may already know that.
samcocker
PostPosted: Sun Nov 17, 2013 12:27 pm    Post subject: Reply with quote
Big thanks for the help chaps.
Think i will have to repo all round as i wont find original and i don't want a mix match of original and repo.
Thanks again Sam
