warmblood58 Samba Member
Posted: Wed Jan 20, 2016 8:10 pm Post subject: EJ22 Phenolic Spacers for Intake Runners |
With the rain coming down and the intake off for cleaning and maintenance, I thought I would make some phenolic spacers. They came out great but man does phenolic put out some serious dust! Wear a mask . . .
[/code] |
Franklinstower Samba Member
Posted: Thu Jan 21, 2016 10:03 am Post subject: Re: EJ22 Phenolic Spacers for Intake Runners |
Won't those put your throttle body to high? Or do you have enough clearance? Purpose of these being to keep the intake runners cooler, colder combustion air? _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
Posted: Fri Jan 22, 2016 11:53 am Post subject: Re: EJ22 Phenolic Spacers for Intake Runners |
| Where do you find affordable sheets of that stuff? |
Posted: Fri Jan 22, 2016 1:44 pm Post subject: Re: EJ22 Phenolic Spacers for Intake Runners |
| The spacers keep the intake charge much cooler resulting in better efficiency and power. In my syncro, I have the clearance (just 9mm higher) to clear the deck lid. I purchased a 12x12 piece at Interstate Plastics for 20.00. GrimmSpeed sells them for I believe about 80.00 . . . |
ejimmi Samba Member
Posted: Thu Jan 28, 2016 10:06 pm Post subject: Re: EJ22 Phenolic Spacers for Intake Runners |
| warmblood58 wrote: |
I have a set of these for my SVX H6, that i still need to put on. I got them for a different reason, there is a whole bunch of stuff under the manifold on an H6. The vacuum lines and all of the little plastic valves that are NLA are kept much cooler with the Phenolic spacers. It also makes getting to the parts much easier if they need replaced rather than pulling the manifold. |
